Connecting 4 Ohm Speakers to 8 Ohm Amplifier: Is It Safe and What Are the Risks?
beziak 35227 13
Can I connect 4 ohm speakers to an amplifier designed for an 8 ohm minimum load, and what are the risks?
No, not if the amplifier’s minimum load is 8 ohms, because a 4 ohm speaker can overload and damage the power amplifier [#3740477] You can add a resistor in series, but it must be a high-power resistor; a 4Ω/10W resistor was suggested, though this is only a workaround and not recommended as the normal solution [#3740518] [#3740623] A coil was discouraged because it would attenuate high frequencies and act like a low-pass filter [#3740596] Measure the speaker with a decent multimeter first, because if it really is 8 ohms you can connect it directly without any extra parts [#3740960]
  • #1 3740303
    beziak
    Rate: 10
    Hello, I have a question: can I connect 4 Ohm speakers to an 8 Ohm amplifier, if not, why not?
  • #2 3740477
    rafal8916
    Welding machines specialist
    Help: 143
    Rate: 326
    If the amplifier is designed for a minimum impedance of 8R, you cannot connect 4R speakers because if you do this the power amplifier will be damaged.
  • #3 3740497
    beziak
    Rate: 10
    and if I add a 4 Ohm resistor to the speakers, it will be 8 in total, can you do that?
    For now, 4 ohm speakers for an 8 ohm amplifier work for me, but I don't raise more than 5/10
  • #4 3740518
    rafal8916
    Help: 143
    Rate: 326
    You can add a resistor by connecting it in series with the speakers, but it would have to be a high-power resistor. As for the volume, if you have 4R instead of 8R, you can't turn up the volume too much, if you can already hear the distortion, you should definitely turn it down so as not to break the power amplifier. i.e. theoretically, you can turn up the volume until distortion starts to appear, no further, but I do not recommend connecting 4R speakers to the 8R amp at all
  • #5 3740539
    beziak
    Rate: 10
    Can you make a resistor out of a coil? Can I measure speaker resistances with a meter? Because my meter shows something around 25.6 Ohm, I think I have a screwed meter or something else is wrong ;/
  • #6 3740596
    rafal8916
    Help: 143
    Rate: 326
    Yes you can measure it with a multimeter. I do not recommend the coil because it will attenuate high frequencies when switched on in series (it will work more or less like a pseudo low-pass filter - if I am not mistaken)
    PS as for the indication of your ohmmeter, 25 ohms is something too much.
  • #7 3740605
    beziak
    Rate: 10
    is the only thing left for me to buy new speakers or a high power resistor? and if the amplifier has fuses on the output?
  • #8 3740623
    rafal8916
    Help: 143
    Rate: 326
    Fuses can help, but they don't have to. How strong are these columns? As for the resistor, try to put a 4R / 10Watt in series with the column, maybe it will last.
  • #9 3740628
    beziak
    Rate: 10
    Moc = 2 x 80 Watt
  • #10 3740637
    rafal8916
    Help: 143
    Rate: 326
    Try with this resistor, maybe it can withstand it, if you have 4 columns of 4R, you can do it so that you connect 2 per channel in series and then you will have 8R.
  • #11 3740823
    beziak
    Rate: 10
    no, I don't understand something here, I check with my friend's meter and it is 8r and on the back of the column it is written that it is 4r, wtf? what's up ?
  • #12 3740960
    rafal8916
    Help: 143
    Rate: 326
    Check with a decent meter, e.g. some metex, if it is 8R, you can safely connect it to the amplifier and do not combine anything
  • #13 3741174
    beziak
    Rate: 10
    well, it pops up elegantly for me, if the resistor is 100 ohm, it is 100 on the meter, and if the speakers are 8 :/
  • #14 3741454
    hefid
    Rest in Peace
    Help: 546
    Rate: 6174
    The post was reported.
    Transferred from: Audio
Connecting 4 Ohm speakers to an 8 Ohm amplifier is generally not recommended, as it can lead to amplifier damage due to impedance mismatch. While it is possible to add a high-power resistor in series with the speakers to achieve a total impedance of 8 Ohms, this may still result in distortion at higher volumes. Users are advised to measure speaker impedance accurately with a multimeter, as discrepancies can occur. If the amplifier has output fuses, they may provide some protection, but it is safer to use speakers that match the amplifier's impedance rating. Alternatively, connecting multiple 4 Ohm speakers in series can achieve the desired impedance.
