Connecting 4 Ohm Speakers to Yamaha AX-540 Amplifier: A Comprehensive Guide
cwanish 42476 17
How should I connect 4 Ω speakers to a Yamaha AX-540 amplifier without damaging it?
Connect the 4 Ω speakers in series, then connect each series pair to one amplifier channel on A or B; do not wire two 4 Ω speakers in parallel, because that would drop the load to 2 Ω and can overload the amplifier [#6284403][#6284521] The rear panel of the AX-540 states: A or B = minimum 8 Ω speaker, and A + B = minimum 16 Ω speaker, so the amplifier is intended to see at least 8 Ω per channel on A or B [#6284061][#6284403] In series wiring, connect the “+” of one speaker to the “-” of the other, then use the two remaining free ends as the pair’s terminals to the amplifier [#6284521] Connecting 4 Ω speakers directly to an 8 Ω/16 Ω output can damage the amplifier [#6284030]
  • #1 6283939
    cwanish
    Rate: 15
    Hello. I have a problem connecting the speakers to the amplifier. The speakers are 4 Ohm and the amplifier also has the same impedance, but I don't know which channels they are for because it is not clearly visible in the photos.
    http://audio.mm-team.com/opis.htm,301,Yamaha%20AX-540
    There it says in the parameters of this amplifier that it has 2x110W for 4 Ohms, so, Ok.
    A or B, definitely 4 ohms/speeker, except that I just auctioned it on Allegro and I don't know what exactly it says there. and A+B, I have no idea.
    So it turns out that I have to connect it like this, right?
    Thank you in advance for your help, I'm new to these matters.
  • #2 6283951
    ajpier
    Level 36  
    Help: 363
    Rate: 480
    You have 4 speaker outputs and the same number of speakers. Why put them together.
  • #3 6283962
    cwanish
    Rate: 15
    A or B 4Ohm/speaker
    A + B probably 8 or 16 Ohm/speaker
    I guess 4 ohm speakers connected to the outputs of an 8 or 16 ohm amplifier will sound poorly. That's what I've heard
    Moderated By dj-MatyAS:
    Advice or irony?
    Regulations p.10.2
    Warning.
  • #4 6284030
    ajpier
    Level 36  
    Help: 363
    Rate: 480
    If you connect 4Ω speakers to 8 or 16Ω outputs, there may be a problem and it is not about the volume of the music but about damage to the amplifier.
  • #5 6284050
    cwanish
    Rate: 15
    Yes, that's right. Did I connect it correctly? (see diagram)
  • #6 6284061
    Grzegorz Markowski
    Help: 900
    Rate: 754
    On the back panel of this amplifier, under the speaker terminals, it is written:
    A or B: minimum 8Ω speaker
    A + B: minimum 16Ω speaker
    And who to believe?
    You connect the speakers in pairs in series and connect the pairs of speakers to the A or B terminals.
    GM
  • #7 6284066
    ajpier
    Level 36  
    Help: 363
    Rate: 480
    If the speakers in the picture have 4Ω, connecting two in parallel will give you 2Ω, which is not good. Use all 4 exits, i.e. A+B.
  • #8 6284112
    Grzegorz Markowski
    Help: 900
    Rate: 754
    How does this relate to the description of the speaker terminals on the rear panel of the amplifier?
    GM
  • #9 6284133
    cwanish
    Rate: 15
    GM
    Wait a minute, I don't understand something here... why is it written in the parameters of this amplifier 2x110W for 4 ohms?
    So I can't connect these 4 ohm speakers?
    and this is what it wrote in the description on Allegro when I bought the amplifier
    ...The rated power of the amplifier is 2x110W on a 4ohm load,...
    Added after 9 [minutes]:
    so what?
  • #10 6284251
    Grzegorz Markowski
    Help: 900
    Rate: 754
    Certainly not like that. Look at the photo
    GM
  • #11 6284338
    cwanish
    Rate: 15
    well, I connected it correctly. The column is L on the left and R on the right.
    so what if I connect my 4 speakers, will they play? does this amplifier have impedances of 8 and 16 ohms?
  • #12 6284386
    jockey7o2
    Help: 8
    Rate: 11
    Let's start with the fact that the AB switches switch zones, are you sure that two zones work at the same time? I have a Kenwood amplifier and zone A or B works, never together!
  • #13 6284392
    Pablo1964
    Moderator
    Help: 507
    Rate: 642
    It will play, but probably for a while and at best it will turn off.
  • #14 6284403
  • #15 6284438
    cwanish
    Rate: 15
    That is, two speakers from one channel in series and the remaining ends to the amplifier, and similarly with the second channel.
    hey, sorry to be intrusive, but I've read this sentence several times and I still don't understand how to do it. Can you draw it out for me?
  • #17 6284572
    cwanish
    Rate: 15
    So it will look like this?
    and with such a connection I will not lose their power?
    ps. Thank you for your help.
    and to think that a year ago I graduated from Electronics Technical School; Mr
  • #18 6284642
The discussion revolves around connecting 4 Ohm speakers to a Yamaha AX-540 amplifier. Users clarify that the amplifier's specifications indicate it can handle 4 Ohm loads, but caution is given regarding the connection method. It is advised that connecting two 4 Ohm speakers in parallel would result in a 2 Ohm load, which could damage the amplifier. Instead, users recommend connecting the speakers in series to maintain a safe impedance level. The correct wiring involves connecting the "+" terminal of one speaker to the "-" terminal of another, leaving the remaining terminals to connect to the amplifier. The importance of adhering to the amplifier's specifications for speaker impedance is emphasized to avoid potential damage.
