Panasonic SA-HE75 Receiver F70 Error - Power Supply or Terminals Issue?
Krzysztof T 16650 3
  • #1 3918388
    Krzysztof T
    Rate: 78
    As in the subject, the device switched on from the stand-by to work after a few seconds displays F70. The manual says that the device should be switched off from the network and switched on again. If the problem persists, contact an authorized service.
    Can the problem concern power terminals or power supply?
    Thanks.
  • #2 3924601
    Bzyczek999
    User under supervision
    Help: 26
    Rate: 25
    Yes, maybe you had some kind of surge, and just the end of the power was falling. how do you want to play? for sure, face the tension at the output of each channel. as the bedziesh had some voltage above 1V, it means that you have a damaged power end
