Vestel 17IPS71 power supply 190814 - Faulty Vestel 17IPS71 Telefunken power supp
Digi500 10221 10
Can I replace a FAN6300HMY PWM controller with a FAN6300AMY in a Vestel 17IPS71 power supply, and what else should I repair on the damaged board?
No, FAN6300AMY is not a direct replacement for FAN6300HMY because the AMY version is a 100 kHz QR flyback controller while the HMY version is 190 kHz. [#16824416][#16830682] The reply also notes that this would only be safe if the operating frequency is not internally fixed, but that is not confirmed here. [#16830682] Besides the controller, the board has other damaged parts such as Q15 (FQPF8N60C) and several SMD resistors and diodes, so those must be checked and replaced. [#19799421] The exact Vestel 17IPS71 board revision matters, because different 17IPS71 versions can differ significantly and the schematic for 17IPS-r3 may not match this 190814R4 board. [#16829453][#16829587]
  • FAN6300AMY substitution question for Vestel 17IPS71
    #1 16822324
    Digi500
    I have a Telefunken 43 to repair "
    Vestel 17IPS 71 190814R4 power supply is damaged. All output voltages are missing
    Can I use a FAN 6300AMY instead of a FAN 6300HMY
    The deal is after a little bang
    The Q 15 FQPF8N60C transistor and several SMD components, resistors and diodes are also damaged
    The Vestel 17IPS-r3 schematic does not match my power supply
    Of course, you can buy a working power supply, but that's not the point
    Please help
  • #2 16823627
    skała
    Help: 29
    Rate: 117
    In the attachment I am sending you a diagram of the power supply. Maybe this one will suit you.
    • vestel_17ips71-r3_sch.pdf (395.41 KB) You must be logged in to download this attachment.
  • #3 16824416
    lisek
    Service technician RTV
    Help: 6352
    Rate: 6883
    FAN6300AMY - PWM CONTROLLER, QR FLYBACK, 100kHz
    FAN6300HMY - PWM CONTROLLER, QR FLYBACK, 190kHz
    The rest in app.
    • FAN6300A-or H.pdf (737.01 KB) You must be logged in to download this attachment.
  • #4 16824625
    mirex
    Help: 1950
    Rate: 1990
    Maybe you could write what exactly does not agree to you?
    Be so nice and rewrite the data exactly as the manufacturer wrote!
    There is no such thing
    Digi500 wrote:
    17 IPS 71 190814R4
    nor such
    Digi500 wrote:
    17 IPS-r3
  • FAN6300AMY replacement question for 17IPS71 variant
    #5 16829453
    Digi500
    Buddy mirex
    A little explanation is something like the Vestel 17IPS71 19081 4R4 power supply
    Therefore, there are differences between the Vestel 17IPS71 series and this number 19081 4R4 is important
    My question was whether it is possible to replace the FAN 6300 HMY IC in the power supply with the FAN 6300AMY and its diagram
    The scheme of such a Vestel 17IPS71 -r3 power supply does not match my damaged one
  • Clarifies FAN6300HMY replacement and schematic mismatch
    #6 16829555
    mirex
    Help: 1950
    Rate: 1990
    Digi500 wrote:
    Buddy mirex
    Yes.
    But
    Digi500 wrote:
    17 IPS 71 190814R4
    there is no.
    Learn to write correctly. Do not litter with stupid things on the electrode and on the Internet!
    Digi500 wrote:
    My question was whether the IC FAN 6300 HMY in the power supply can be replaced
    And wrong again!
    And I asked a simple question, which doesn't exactly fit.
    Because if there is a problem, other people may find this information useful.
  • #7 16829562
    GanCegall
    Help: 339
    Rate: 1631
    Digi500 wrote:
    the number 19081 4R4 is valid
    Prove it, it doesn't matter in my mind.
  • #8 16829587
    mirex
    Help: 1950
    Rate: 1990
    It is so much that it is another version of the board for 17IPS71.
    But as with the cast of elements and the purpose for a specific matrix, this is a different story. :)
  • #9 16829834
    GanCegall
    Help: 339
    Rate: 1631
    Exactly, they differ significantly, depending on what type, size of the matrix and the connection to the main are made, someone will read that this number is important, replace it using it and may have fireworks in the cottage :-)
  • #10 16830682
    mieszaczwcz
    Help: 185
    Rate: 258
    Hello, I'm talking about replacing "... is it possible to replace the FAN 6300 HMY IC in the power supply with the FAN 6300AMY"
    according to me, I cannot, because the limit f for 6300HMY is 190 kHz and 6300AMY f is 100kHz
    conversely, nothing will happen, provided that the operating frequency is not internally rigid.
  • #11 19799421
    electrotogo
    We must change the defective parts
The discussion revolves around the repair of a Telefunken 43 television, specifically addressing the damaged Vestel 17IPS71 190814R4 power supply, which is missing all output voltages. The user inquires about the feasibility of substituting a FAN 6300AMY PWM controller for a FAN 6300HMY in the power supply. Responses highlight the differences in operating frequencies between the two controllers (100kHz for FAN6300AMY and 190kHz for FAN6300HMY) and emphasize the importance of matching components to avoid potential damage. Several users provide insights into the variations within the Vestel 17IPS71 series and the necessity of replacing defective parts rather than making substitutions that could lead to further issues.
