How to use Print Screen for only the first monitor on a dual-monitor PC?
aro84 55464 2
  • #1 3967988
    aro84
    The matter is quite complicated, because the screenshot is to be taken using the standard method, ie by the "Print Screen" button and pasted into any editor. However, with this method, when two monitors are connected, we have an image from both
    Maybe you just need to edit or add the appropriate entry in the registry?
  • #3 3968934
    aro84
    But the point here is that I need this for work.
    Everyone has to know how to use it, so the new method is out of the question, everyone would have to be re-trained ...
    Unless there is a program that "watches" that a screenshot taken with a print screen is only from the first screen?
    Ok, I've already dealt with it. I decided that all I need is a screenshot of a given application.
    So when it is active, press Alt + Print Screen and we are at home :)
    To close.
