Cigarette Lighter Socket Wiring: Which Pin Is Positive and Which Is Negative?
LaikCisie112 61779 1
  • #1 4309047
    LaikCisie112
    Rate: 22
    Hello!
    Someone can tell me where there is plus and minus in the car plug.
    The point is that in the malaczu I do not have a cigarette lighter socket and I bought an FM transmitter and now I do not know where to connect the plus and minus for the plug !?
    I would like to connect it directly to the battery.
    Thanks in advance!
    mariuz
    Help: 141
    Rate: 109
    + is a pin
    - it's a collar.
    I check it every time to be sure meter
    (This is not an attempt to honor you - you don't have a cigarette lighter, so you won't check ;) )
    If there was an outlet, then you might be offended :P
    Good luck with the assembly. Try to somehow insert the connector nicely and possibly the transmitter panel (if there is a reason)
