[Solved] Cigarette Lighter Socket Amperage for Power Supply & CB-Radio Connection at Home
Berni-lg 51989 3
  • #1 6421320
    Berni-lg
    Rate: 17
    Hello. I would like to know what the amperage is in the cigarette lighter socket (because the voltage is supposedly 12V), I need to buy a power supply and want to connect the CB-Radio at home, but I do not know what amperage to give it, and I do not have how to measure the amperage in the car. Could someone tell me?
  • #2 6421360
    Duduś74
    Moderator of HydePark
    Help: 71
    Rate: 225
    See how many amps the fuse has in the car (from the lighter), and as for the CB, it should write on it what power it has, or what the fuse is with it.
  • #3 6421567
    Berni-lg
    Rate: 17
    And someone knows how many amps it is, because there are probably the same in every car. And the fuse probably recognizes only the peak value and not the average or typical there.
    Qwet
    Help: 137
    Rate: 180
    You don't understand the basics. First, no electricity flows without a load. Secondly, the receiver draws its own current, depending on its resistance or its needs, if it is an electronic device. Any current, even 100A, can be drawn from the car socket, but then the fuse will blow. Again, the voltage source does not force a specific current in any way. It is the receiver that decides how many amps it will take from a given voltage. You should be interested in how much current your CB radio takes, so that you know what current efficiency the power supply must have. For example, if you were to connect a CB that takes 3A to a 12V power supply with an allowable load of 500mA, the power supply would probably burn out. But if you had plugged this CB into a 20A 12V power supply then everything would work as it should ;)
