Outlook Express: Selecting Multiple Messages for Deletion in Inbox - Efficient Process
Czeslaw10 22645 4
  • #1 4619965
    Czeslaw10
    Rate: 52
    How to select (highlight) several messages in the inbox to delete them?
    I don't want to delete one at a time, it is very time consuming.
    A lay question, but I can't highlight it.
    Piżol
    Rate: 12
    Hold down the CTRL key and left-click to select individual messages
  • #3 4620092
    Czeslaw10
    Rate: 52
    I already know you have to click on each message.
    Then they light up.
    You can't pull because there is a prohibition sign.
    mariusz.ja
    Help: 7
    Rate: 10
    If you would like to select all messages, the Ctrl + A combination will be helpful.
    SaraniS
    Help: 78
    Rate: 26
    And I'll add one more using Shift :D
    Namely, you click on the first one, then press Shift and on the last one you want to select :) The above can be combined with Ctrl to select several ranges - I will add that this is typical behavior for the ListView control, which controls both the folder windows and the OE window :D
    Happy Christmas :)
