Gluing Cracked Laptop Cases: Best Adhesives & Techniques for Matrix Hinge Housing Repair
keseszel 58623 16
How can I repair a cracked laptop case near the matrix hinge so it holds permanently?
Don't rely on glue alone; disassemble the case, fix the hinge cause, and reinforce the crack from the inside with a plastic patch or metal mesh/staples before gluing. The crack often returns if the hinges are seized, so remove them first, reduce the holding force, and make sure the hinges are clean and properly adjusted [#4778691][#5620104] For the bond itself, posters recommended good cyanoacrylate for plastics, preferably in gel form so it can fill gaps, or a 2-component epoxy such as Poxipol, Distal, or JB Weld for a stronger repair [#4776423][#4788149][#4776433][#4779862] If the case is hard PVC, PVC glue was suggested; if it is polypropylene, it is usually difficult to glue and may need welding instead [#4779862] The best practice is to roughen and clean the surfaces, then clamp the repair and add an internal reinforcement rather than depending on glue alone [#4776423][#4779862]
  • #1 4776396
    keseszel
    Help: 54
    Rate: 558
    I have a cracked housing near the matrix hinge. It doesn't bother me at the moment, but it still irritates me. What good glue could it be glued together? Droplet - I'm somehow allergic to it ;-) Maybe there is another technique that can be recommended? Demolition of the housing, putting something in and then gluing it? How do colleagues deal with such a problem?
  • #2 4776423
    tronic1
    IT specialist
    Help: 2640
    Rate: 1108
    Gluing alone will not do much. It will break again in a moment. Disassemble the casing and put a patch of similar plastic on the bottom so that the glue reacts with both surfaces. Some glue based on cyanopan.
  • #3 4776433
    milakowie
    Help: 17
    Rate: 36
    With laptop cases and plastic, it happens differently, I recommend glue on Allegro or ebay "JB Weld" two components and it binds like hell and does not melt plastic elements. I have no conviction for droplets and this type of inventions. I use this glue and it is ok that the hinges are still used today.
  • #4 4777069
    AdrianZ
    Help: 13
    2-component adhesives, which are mixed only before gluing, are second to none and are the best way to glue something permanently, some of what I know can harden and maintain the consistency of metal, so it will be difficult to break something like this again. The disadvantage is the price, but it is worth gluing important parts with them.
  • #5 4777610
    jag61
    Radiation protection specialist
    Help: 115
    Rate: 85
    Colleagues - let me throw in my two cents - THERE ARE NO UNIVERSAL ADHESIVES (especially for plastics).
    kesychel - before gluing, it is good to know what kind of material you are dealing with - there are those that will be very difficult to stick (thermoplastics - mainly polyethylene, polypropylene, etc.) - there are those that can be, although it is not easy (you need to "prepare" the surface properly before gluing).
    And in places exposed to tensile / shear forces, you should not stick without a "pad" ...
    I recommend reading this topic..
    greetings to all.
  • #6 4778691
    satgal
    Level 40  
    Help: 482
    Rate: 428
    The die casings break at the hinges for a reason, most often due to seized hinges. You must first remove them, adjust the holding force and you have to think about how to do it in this model.
  • #7 4779027
    keseszel
    Help: 54
    Rate: 558
    Interesting page about plastics. I can't imagine burning a laptop casing to check the hardness of the plastic. And what do colleagues think about Poxipol or Distal?
  • #8 4779862
    jag61
    Help: 115
    Rate: 85
    If the case is made of hard PVC - I would use PVC glue ..
    In the case of materials such as polypropylene - a colleague will probably not be able to stick together (it is rather welded).
    As for "smoking ( ;-) ) of the casing - a very small piece (e.g. chip from internal bracing) is enough to get the required information :-) (and of course a good nose and experience ..).
    Perhaps it would be possible, for example, to heat up a dense metal mesh (as an additional reinforcement) and then make and paste the "overlay" from the inside.
    Ps
    Distal and Poxipol are epoxy resins - they could be suitable provided that they adhere to the material (but I would strengthen them with, for example, glass fiber or metal mesh).
    Ps2
    In the past, I used to "weld" polypropylene using a soldering iron with a shaped tip - then the question of "processing" the weld remains.
  • #9 4785095
    WITEK1952
    Help: 75
    Rate: 388
    Hello. I have been using Bondini for years. It is a bit thickened and it dries longer than a droplet. I do not know better at this price. Regards.
  • #10 4785302
    jag61
    Help: 115
    Rate: 85
    Witek - you can actually try it (although it is also a type of cyanoacrylate glue) - but, as you wrote, it is in the form of a gel (there are different varieties)
    Added after 2 [hours] 33 [minutes]:
    I would also like to add that Bondinim gel can "fill" the cavities ...
  • #11 4788065
    keseszel
    Help: 54
    Rate: 558
    I know it's off topic. My shoes were glued with this glue :-) . A friend just had leftovers. He held really great. And it was sooooo expensive. How much is it now?
  • #12 4788149
    tzok
    Help: 3175
    Rate: 6537
    Once in Travelmate my flap broke, I melted the staples (alternately from the top and bottom), on the other side I bent them, and finally poured transparent Poxipol. I applied it several layers, and painted the penultimate layer black. The gluing point was masked with tape, so finally a strip of poxipol with even edges remained on the flap - it did not look too bad.
  • #13 4788498
    jag61
    Help: 115
    Rate: 85
    tzok - you did as I wrote - only; instead of fusing the mesh - staples and an adhesive overlay ;-) - the ground to be effective.
    kesychel - something around PLN 15-20 (as I remember correctly) - only there is a problem with finding in the gel ... :-(
  • #14 5619217
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Today I bought a Technicqll adhesive for Hard Plastics "Aggressive" - it partially dissolves (melts) the glued surfaces
    It cost me in the Ciastorama about PLN 4 with pennies, the guy recommended it to me, he said that this glue can melt the joined parts in the joint in the joint, where they will also be joined with the original material.
    The glue is suitable for modern plastics such as all kinds of plastics, abs, acrylic glass, persplex, tr-y, eva-y, etc.
    It is required to press the glued parts firmly and then to clean them.
    Today I will try it, because I have a cracked hinge, it is already "rump one", adjusted and greased - I bought a laptop occasionally used in a neglected condition, now I pamper it:].
    After connecting the elements, I will think about some additional protection from the inside of the housing. I was thinking of profiling some metal plates (plates), matting the surfaces of the connected plastic elements and plates and making a small reinforcement in the damaged area.
    We'll see what comes out of it :)
    Here was a similar topic with the discussed aggressive glue suitable for gluing ABS>
    www.elektroda.pl/rtvforum/topic862954.html
  • #15 5619383
    WITEK1952
    Help: 75
    Rate: 388
    Hello. As I like to have 100% functional equipment, I have a question: Did lubricating the hinges cause a weaker grip on the matrix flap? Regards.
  • #16 5620069
    AoT_Hunter_PL
    Help: 13
    Rate: 47
    Hi, I am answering (smearing completely dry hinges will loosen the resistance to some extent, because that's why the parts will have less friction against each other). they can "squeal" violins, proverbial, like the old hinges on the door when it is dry there.
    Secondly, it will make the work more enjoyable - everything will run pleasantly and smoothly without jams.
    Unscrew and lubricate it well, and if there is a screw for adjusting the pressure, adjust the pressure with it, and even though you lubricate it, there will be adequate resistance for the damper.
    Note that it is not too big (as in the case when the hinges can be dirty without grease, "stuck") old laptops often have cracked hinges.
  • #17 5620104
    Hucul
    Help: 382
    Rate: 470
    In my experience, the plastic near the hinges breaks for three reasons:
    -dry hinges
    -tightened screws at the hinges
    - defective construction
    The first two reasons "maliciously" become apparent only after the casing is broken, the third one can be bypassed by buying equipment without this defect, which is difficult to sense with the new models.
    My method for this fault is getting the hinges tidy and good cyanoacrylate glue (Loctite for example).
✨ The discussion centers on repairing cracked laptop cases, particularly near the matrix hinge. Users recommend various adhesives and techniques for effective repairs. Key suggestions include using two-component adhesives like JB Weld, which provide strong bonding without damaging plastic, and cyanoacrylate glues such as Loctite. It is emphasized that proper surface preparation and reinforcement with patches or metal mesh can enhance durability. Some participants mention specific products like Bondini and Poxipol, noting their effectiveness for different plastic types. Additionally, the importance of addressing underlying issues such as seized hinges and screw tension is highlighted to prevent future damage.
