How can someone send SMS messages with no number showing on the recipient's phone?
screw 85456 7
  • #1 4794438
    screw
    Good day. I hope someone will help me, so I got a text message from someone on my phone and there was no number ( no number ) is it possible to send something like this from the net? or from a cell phone. If so, in what way ?
    Thank you for your help !!!
  • #2 4794681
    rado_
    Help: 46
    Rate: 30
    you can send from a cell that has a reserved phone number, the same thing happens when someone calls from such a cell to your number, then the number of the calling person is not displayed, only it says "private number"
    if you have a subscription phone, you can turn on this service free of charge at the service provider, additionally having a Nokia phone, you can turn on this option from the phone (in connection settings)
  • #3 4794724
    _prusak_
    Help: 19
    Rate: 211
    Hi. When I reserve the number, when I give a signal, I write a restricted number, but when I send a text message, my number shows up at the recipient. So is it a phone option or a question of setting it with the operator?
  • #4 4794777
    rado_
    Help: 46
    Rate: 30
    the option to set this at the operator what I gave so that the number does not display applies only to connections as to the sleeves, you need to reserve the number at your operator
  • #5 4794781
    slepy9393
    Hello, I have a plus +) and I can reserve the number only for calls, but not for sms in my way, it depends on the network
  • #6 4794790
    screw
    So I called the service office (era) and they told me that if I have a restricted number, when sending a text message it is still visible !!!
  • #7 4794795
    rado_
    Help: 46
    Rate: 30
    more precisely from the operator as I wrote above. Setting to hide the phone number in the phone menu> phone settings> call settings only applies to calls, not text messages
  • #8 4794812
    screw
    Oh, I will tell you more, I called the service office a minute ago and was told that no network in Poland excludes stealth services in sms
The discussion revolves around the possibility of sending SMS messages without displaying the sender's phone number. Users mention that while it is possible to restrict caller ID for voice calls through service providers, this option does not extend to SMS messages. Several participants confirm that even with a restricted number, the sender's number may still be visible when sending texts. It is noted that in Poland, no network currently offers a service to completely hide the sender's number for SMS. The conversation highlights the limitations of phone settings and operator services regarding number privacy in text messaging.
