Creating Desktop Web Links to Local Folders and Executables in IE for Win98
MES Mariusz 15220 4
  • #1 5084670
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 224
    Is there any clever way to get IE to click on a link to open not a page but a folder that is on your local drive, or even exe-ca?
    If it could be done, it would be possible to make an indestructible desktop (web site as a desktop) for Windows 98 by removing all icons from it, and on the desktop page to make linked folder graphics, e.g. Programs, Games, and links that directly launch some basic programs.
    Such icons could not be moved or deleted, if you somehow blocked saving to the desktop and changing screen settings in Win98, you could start talking about some kind of eternal order on the desktop.
    mietekn
    Help: 400
    Rate: 161
    You just make a link like: file: /// c: /windows/system32/cmd.exe. If the page is saved on a local disk, it will work.
    Dżyszla
    Help: 1095
    Rate: 226
    As for blocking the desktop, if that was it: in 98 you will not block adding new items to the desktop, in 2k and XP you have to take away the right to save in the desktop kaytalog.
  • #4 5084775
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 224
    Really :-) Both files and folders open smoothly.
    If you want to emulate the Windows desktop even more, you would have to think about a script that will open the link only after pressing it twice.
  • #5 5085033
    Dżyszla
    Help: 1095
    Rate: 226
    If there is no appropriate event, the click counter + time reset from the last click + moving the link from href to function. But sometimes people just use one ;) (this is to be set probably from version 98SE with ActiveDesktop)
