[Solved] LG 32LH500D TV - ZD9108 Diode Replacement in 715G7801 Power Supply After Overvoltage
grygier 27648 4
  • #1 16986741
    grygier
    Rate: 11
    TV as in the subject.
    Panel: TPT315B5
    Power supply + driver: 715G7801
    Main: 715G8003
    Tcon: 6871L-4445
    TV after overvoltage in the network - I need information about the diode in the power supply marked: ZD9108, diode shorted. The power supply is based on the SSC3S121 system.
  • #2 16986805
    lisek
    Service technician RTV
    Help: 6355
    Rate: 6886
    The Philips-40PFT6709 on the chassis: TPM14-2A-LA is the power supply on the SSC3s121
    There is no ZD9108 zener diode in approx. SSC3121
  • #3 16987149
    grygier
    Rate: 11
    There is no such element in the diagram, but in my case the diode is connected in parallel to the R9101 with the cathode to the source.
    lisek
    Help: 6355
    Rate: 6886
    Once upon a time, companies used "myk" in the form of:
    - zener diode, connected in parallel to the resistor in the field current sensor
    There was even something on the forum .....
    you have to search the resources :cry:
    e.g.
  • #5 17018468
    grygier
    Rate: 11
    So the TV works. I decided to take a chance - there is a 3.3V diode in the fox diagram with a 0.56 ohm resistor, in the power supply for the 43LH5000 model, the schematic diagram of which is in the base, a 5.1V diode and a resistance of 0.15 ohms. I had a 0.3om resistor so I gave a 4.7V diode; the power supply started. The voltage value on the diode during operation is about 0.028V, so I suppose that it has a protective function and the power supply would also work without it.
