Rectifier Diode Parallel to DC Voltage Relay Coil: Understanding Its Purpose & Benefits
R_O_Y 69278 10
Why is a diode connected in parallel with a DC relay coil, and what does it do?
A diode across a DC relay coil is used to suppress the high reverse voltage generated when the relay is switched off, protecting the control electronics such as a transistor from breakdown [#5368163][#5368500] The inductive voltage spike still occurs, but the diode provides a path for the coil current and limits the coil voltage to about the diode’s forward drop instead of letting it rise to a dangerous level [#5368500][#5368775] One side effect is that the relay releases more slowly because the stored coil energy decays through the coil-diode loop [#5368775] If a faster release is needed, the thread suggests using several diodes in series or a Zener diode plus a rectifier diode to allow a higher but still safe clamp voltage [#5368775]
  • #1 5368142
    R_O_Y
    Rate: 47
    Hello!
    Maybe a trivial question, but I would love to get an answer to it:
    Why is a rectifier diode placed in parallel with the DC voltage relay coil? What does its use give?
    I am only asking for a specific answer to the discussion, I do not have time, I will mention that I have already browsed the forum and I have not found the answer - maybe I was looking for it wrong.
    Thank you in advance and best regards.
  • #2 5368163
    slawussj
    Help: 244
    Rate: 255
    so that the voltage induced at the moment of switching off the relay does not damage the control elements.
  • #3 5368392
    R_O_Y
    Rate: 47
    Not that I was not kumaty ... Can it be clearer?
  • #4 5368423
    Fatko
    Help: 22
    Rate: 36
    Hello friend.
    At the moment of switching off the coil from work, quite high voltage is induced (the diode prevents the induction).
    Capacitors are also used- (for the same purpose)
  • #5 5368487
    R_O_Y
    Rate: 47
    I once met a description that installing a diode in parallel with the relay coil speeds up its operation (I do not remember whether it is turned on or off). Is it possible?
  • #6 5368500
    dariuszj
    Help: 33
    Rate: 68
    The diode does not prevent induction. The phenomenon of induction as such will always occur at the moment of sudden interruption of the power supply to the coil. A diode is an element that levels the voltage resulting from induction. It is one of the solutions protecting the relay control elements, e.g. transistors, the breakdown voltage of which may be many times lower than the impulse induced in the relay coil. The diode for this pulse is, say, a short circuit and energy is lost in it, which could damage the transistor.
  • #7 5368663
    R_O_Y
    Rate: 47
    Summarizing: A diode connected in parallel to the coil of a DC voltage relay will not accelerate its operation (or turn it off), but only protects the control system against voltages inducing in the coil winding when it is turned off?
  • #8 5368775
    Paweł Es.
    Help: 1236
    Rate: 693
    There is an overvoltage on the relay coil due to its inductance and the rate of current decay in the circuit:
    $$e=-L*\frac{di}{dt}$$
    di / dt - means current increase / decrease over time, measured in A / s
    When the relay is turned off, the disappearing magnetic field induces a voltage in the relay coil. It is directed against the voltage drop across the energized relay, i.e. it adds to the supply voltage of the relay. At the end of the controlled relay (the second one is connected directly to the power supply), there will be a voltage pin with an amplitude:
    Up = Ucc + UL
    Up - overvoltage (peak) voltage
    Ucc - supply voltage
    UL - induced voltage in the coil
    Example. Omron G2R relay for 12V.
    http://downloads.components.omron.eu/OCB/Prod...lays/Up%20to%2030A/G2R/K013/K013-E2-12A-X.pdf
    Coil R = 275?
    Coil L = 2.29H (with anchor attracted, 1.15H is released)
    When powered by 12V, the current in the coil circuit is:
    $$Il=\frac{12V}{275\Omega}=43.6mA$$
    Now let's say that within 0.5ms this current drops to zero, i.e. the overvoltage at the end of the coil will be:
    $$Up=Ucc+L\frac{di}{dt}=12V+2.29H*\frac{43.6mA}{0.5ms}=211.7V$$
    If the switch-off time is even shorter, the overvoltage will be even greater (this phenomenon, unfavorable in relay circuits, is used in voltage-increasing converters, where the output capacitor is charged via a diode with such a controlled overvoltage, but the switching takes place with a much greater frequency).
    Since the above-mentioned and calculated overvoltage can damage (break through) the control transistor, for example, diodes connected in parallel to the relay coil are used, which limit the overvoltage on the coil to its forward voltage.
    Over-voltage suppression has the side effect of lengthening the deceleration time of the relay. This is due to the fact that although we do not supply current to the relay, due to self-induction, the current now flows in the relay coil-diode circuit.
    The decaying current in the coil-diode circuit is described by an approximate formula:
    $$Ild=\frac{Ucc-Ud}{R}*e^{-\frac{t}{\tau}$$
    Ucc - supply voltage (12V)
    Ud - voltage drop across the diode (0.8V)
    R - relay coil resistance
    L - relay coil inductance
    t - time in seconds
    ? - circuit time constant RL = L / R
    e - 2.718 ... the base of the natural logarithm
    The above-mentioned relay releases when the current in the coil drops to 0.15 of the nominal value (in the data sheet it is given as release voltage)
    Solving the equation:
    $$0.15*I0=I1*e^{-\frac{t}{\tau}}$$
    Where
    I0 = Ucc / R
    I1 = (Ucc-Ud) / R
    we get that the current in the coil circuit will reach the release current level after time (for the above-mentioned data):
    $$t=1.83*\frac{L}{R}=1.83*\frac{2.29H}{275\Omega}=15.2ms$$
    Without a diode, the deceleration time is (for the G2R relay for DC voltage):
    so-called = 5ms
    with diode:
    Tcałk_zw = so-called + td = 5ms + 15.2ms = 20.2ms
    Of course, this is a theoretical value that does not take into account the scattering of parameters of individual relays
    In some applications, this increase in deceleration time can hurt us.
    It can be prevented by using several diodes in series instead of a single diode or a Zener diode in series with a rectifying diode. As a result, the overvoltage on the coil will be limited to safe values and at the same time will shorten the time of current flow in the overvoltage discharge circuit.
    Uz + Ud + Ucc
  • #9 5369025
    R_O_Y
    Rate: 47
    So installing the diode parallel to the coil is little that it will not speed up the operation of the relay, but will extend its switch-off time.
    Academic lecture - congratulations on your knowledge and thanks for your help.
    Greetings.
  • #10 16746252
    oscdev
    OK, but in what direction should this diode be mounted?
    Which way in relation to the polarity of the power supply (control) of the relay?
    Moderated By trymer01:
    Regulations, point 3.1.19. Do not send messages on archival topics if this is another question, in particular other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
    3.1.16. Do not post questions that are easily answered on the Internet or in the electrode forum.
    And just think (what will happen when we turn it on in the forward direction?), Just check how this diode is turned on by others (there are a lot of diagrams on the forum). But no, I do not want to think, I do not want to read - I will ask!
  • #11 16746264
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    Fatko wrote:
    (the diode prevents induction).
    Yeah, I wonder what Mr. Lorenz would say about that :D . @oscdev What do you think ? You can also put it in series with the coil. There are such solutions, used rather for large electromagnets - why in series, not in parallel - maybe someone will answer. And varistors and transils are also in use.
A rectifier diode is placed in parallel with a DC voltage relay coil primarily to protect control elements from high voltage spikes induced when the relay is switched off. The sudden interruption of current in the coil generates an induced voltage that can exceed the supply voltage, potentially damaging sensitive components like transistors. The diode provides a path for the induced current, effectively clamping the voltage and preventing damage. While it does not speed up the relay's operation, it can influence the switch-off time by managing the energy released from the coil. Proper orientation of the diode relative to the power supply polarity is crucial for its effective operation.
