Grounding Requirements for Welding: Electrode and Welded Object Connections
MCkawa 35032 26
Do I need to ground the welded object when welding with the electrode on plus and the workpiece on minus?
No, you do not need to earth the welded object; the welder’s secondary/output circuit is isolated and should not be connected to the electrical installation earth [#5402429][#20206644] Connect the return clamp directly to the workpiece as close to the weld as possible [#20204934] Grounding the workpiece or routing the return through an earthed table can cause welding current to flow through protective earth or other equipment if contact is poor or disconnects [#5402455][#20204934] The welder housing or welding table may be earthed for protection/equalization, but not the output terminals themselves [#5402455][#5402468] Also, the correct polarity depends on the electrode type, so check the electrode package for polarity information [#19749397]
  • #1 5401516
    MCkawa
    How is it, I connect the plus to the electrode, the minus to the welded object and do I still need to connect the welded object to the ground?
  • #2 5401718
    11111olo
    Rate: 797
    You don't have to. There you have low voltage but huge current - so it won't kill you ;)
  • #3 5401779
    MARCIN.SLASK
    Home appliances specialist
    Help: 1037
    Rate: 2658
    I saw in a large plant a few years ago how welders welded electrically. Besterka 400 and over 200m of one cable. The other one was right next to the welder attached to the structure. I was a bit worried about large voltage drops (they welded the gantry with electrode 8), but it worked great.
  • #4 5402410
    MCkawa
    So finally how? There's no need to ?
  • #5 5402429
    niutat
    Level 36  
    Help: 288
    Rate: 758
    Hello, the output terminals of the welding machine do not need to be grounded.
  • #6 5402455
    robokop
    Help: 1763
    Rate: 6371
    Przetwornik wrote:
    I work as an electrician and the mass is usually connected to some pipe, for example, the current at rest is small, about 5A, but during welding it increases up to 80A, depending on how it is set.
    The mass of what is connected to "some pipe"? And how does this relate to the question of grounding the workpiece?
    Answer to the question asked: You do not have to earth the welded object, especially since it would often be physically impossible. However, welding stations (tables) are connected to earth electrodes with equalizing conductors. And just for common sense, why do you need to ground a circuit galvanically separated from the network?
  • #7 5402468
    Androl
    Help: 8
    Rate: 27
    I would like to add that grounding the ground terminal would not serve the device because the welding current gets on the housing and interferes with the operation of the device (weaker arc). I had a case where the ground terminal in the plug of the device was heated due to the fact that the current terminal had a short circuit to the housing of the device.
    Also, do not ground the output terminals.
    Regards
  • #8 5402558
    HeSz
    Electrician specialist
    Help: 97
    Rate: 198
    It is also necessary to take into account the flow of direct current coming from the welder through possible grounding. Perfectly RUINS grounding elements. Always connect BOTH poles of the welder when welding, and do not ground them. Unless you're on the fence with electricians and want to spite them. But... a stick has two ends.
    Regards.
  • #9 5402617
    MCkawa
    OK, thank you very much
  • #10 5402645
    niutat
    Level 36  
    Help: 288
    Rate: 758
    A simple example: the grounded ground wire in the welder, you connect the welder to a welding station with an extractor, if you connect the welder ground correctly, everything is OK, but if the ground wire does not have the correct contact or disconnects during welding, the welding current will flow through the ground wire of the welder and the wire grounding extractor, the effects can be guessed.
  • #11 5403177
    Madrik
    Help: 627
    Rate: 1190
    In large plants, steel structures are usually galvanically connected to each other. When welding anything to the structure, it is enough to connect the mass "to some pipe" to close the circuit.
    Sometimes the structure is used as a welding table.
    Unfortunately, it happens that when the welder is damaged, the welding current sometimes flows through the welder's power cable and melts.
    It is similar when welding connected electrical devices - there is a risk that the welding current will flow through the power supply and burn the installation. These are not frequent cases, but they do happen. I've seen a few of these.
  • #12 16865002
    Axles
    Rate: 18
    Good morning, I have a question for you, I am asking for a pathological answer, what is the ground actually connected to (that is, the second wire from the welding machine), to what and for what purpose. Apart from better welding, does this matter for safety? Where not to connect ground?
    I am planning to buy a welder for home purposes and for now I am getting acquainted with the theory of what and how.
  • #13 16865049
  • #14 19730772
    blomax
    Well I do not know. I just bought a welder and they clearly write to ground the item being welded or the work table. So the ground wire will actually be grounded. And if I have a plus ground, the "plus" will be grounded. What consequences this has, I don't know. Now let's assume that the welder has a breakdown and there is a voltage on the structure. Do I really have to weld ungrounded components?
  • Welder secondary must stay isolated from electrical system
    #15 19748814
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    You bought a Chinese product, and the instructions were written by a roundup dick. The welding machine's secondary circuit must not be connected to any conductive element of the electrical system.
    blomax wrote:
    now let's assume that the welder has some
    it happens then protection by quick shutdown will work. The welder housing must be connected to the Pen if it is metal.
    Added after 44 [seconds]:
    I don't know what not to understand here?
  • #16 19748835
    vorlog
    Level 40  
    Help: 527
    Rate: 2585
    Damn... Not good. So how do I connect the welder in the cottage if I don't have a PEN in any socket?
    And the housing is 100% metal, I did it myself.
    For twenty-odd years in a cottage, I have been risking my life, my family's life and all my livestock?
    V
  • #17 19749187
    Help: 1405
    Rate: 6430
    vorlog wrote:
    how do i have no PEN in any slot?
    You Mi Tunie storms the thread. I am asking you!
  • #18 19749198
    vorlog
    Level 40  
    Help: 527
    Rate: 2585
    This is not your thread :)
    V
  • #19 19749250
    ladamaniac
    Help: 724
    Rate: 2078
    A friend welded the element in a vice. Vice screwed to a metal table. On the other side of the table is a grinder, decent, with a metal casing. So my colleague for a moment put the handle with the electrode on the table next to it, on which there was a column drill, decent. Getting grounded...sucks with happiness.
  • #20 19749285
    wkondratgazetapl
    MCkawa wrote:
    plus to the electrode, minus to the workpiece
    And not vice versa?
  • #21 19749397
    ladamaniac
    Help: 724
    Rate: 2078
    wkondratgazetapl wrote:
    And not vice versa?
    Usually not, but depends on the type of electrodes. You should have polarity information on the electrode package.
  • Remote welding ground caused burnt wiring
    #22 19749507
    vorlog
    Level 40  
    Help: 527
    Rate: 2585
    The 80s of the last century, Zakłady Mechaniczne TARNÓW, iron foundry, blasting chambers - such tin sheds, where the only electrical installation is lighting with several E40/1000W bulbs (yes, there were such :) and a turntable in the floor. How many times a team of mechanics/locksmiths put on a performance with (rotor) welding machines, where the welding machines stood in the welding shop, some 30m away, and the "ground" was connected to the nearest support structure of the conveyor belts and only the cable to the electrode was pulled to the crime scene, so many times the electrician team had to replace burnt wires in the shot blasting room. Sometimes there are also entire wiring harnesses of the conveyor belt system, arranged in steel tubes.
    And the opportunity to win a bottle from the unfortunate delinquents.
    Of course, no requests to bring the welder to the welding site and connect the "mass" locally did not result :)
    V
  • #23 20203796
    m4rc1nb0r3k
    I read and read these forums and I know that I know nothing. I wanted to learn to weld, but with my art education, I don’t think it will work.
    I would probably have to precede the welder’s course with the basics of physics from elementary school. So the markets are going down. (I wanted to weld the container and the fence ... it’s beyond me cheba)
  • Seek hands-on welding guidance from a specialist locksmith
    #24 20203807
    vorlog
    Level 40  
    Help: 527
    Rate: 2585
    Take a visit (and a starter package, maybe a bottle or a few beers) to the nearest specialist locksmith, who even as part of his job welds something to the neighbors, but a specialist, not a garage tinker - an hour or two plus a concise conversation and you can already do something practice myself.
    Not saints make pots, and you don't need to have "master papers" for your home needs, but you can start fencing after really longer exercises.
    V
  • Welding depends more on practice than physics
    #25 20204240
    homo_sapiens
    Help: 67
    Rate: 128
    m4rc1nb0r3k wrote:
    I wanted to learn to weld, but with my art education, I don't think it will work.
    I would probably have to precede the welder's course with the basics of physics from elementary school.
    For electric welding, in the basic scope, you do not need physics, but practice with a good master. The basic condition - trembling hands, good eyesight and sincere intentions. I know people who would fail on any so-called intelligence test, but they make welds that are subject to inspection by x-raying the welds.
  • Ground clamp should connect directly to workpiece
    #26 20204934
    BANANvanDYK
    Help: 1167
    Rate: 2601
    A grounded table is asking for trouble. Especially when welding a device connected to the electrical system. In my previous job, a welder was creating a craft with a vibrator attached to a controller. Typically, the vibrator stood on rubber feet and at the time of making the correction, the protective conductor was burned along its entire length, because the ground was not connected directly to the welded element. There was an idea to make an additional ground cable that would be connected to the welded element, not through the table.
    Generally, the rule is to connect the mass with the welded element in the place as close to the weld as possible.
  • #27 20206644
    Help: 1405
    Rate: 6430
    YOU CAN'T.
    Each welder has an isolated secondary circuit.
The discussion centers on the grounding requirements for welding, specifically addressing whether the welded object needs to be grounded when the welder's electrode is connected to the positive terminal and the workpiece to the negative terminal. Responses indicate that grounding the welded object is generally not necessary, as the welding machine's output terminals do not require grounding. Concerns are raised about potential voltage drops and the risks of current flowing through unintended paths, which can damage equipment. It is emphasized that both poles of the welder should be connected during operation, and grounding should be avoided to prevent interference with the welding process. The importance of connecting the mass as close to the weld as possible is also highlighted to minimize risks.
TL;DR: 90 % of home stick welders run at 20–45 V DC and up to 160 A [Miller FAQ, 2023]; "Each welder has an isolated secondary circuit" [Elektroda, Strumien #20206644]. Connect the return clamp to the workpiece only—no extra earthing.
Why it matters: Wrong grounding ruins tools, melts safety wires, and voids IEC-60974 compliance.
• Typical SMAW open-circuit voltage: 50–100 V [Lincoln Electric, 2022] • Return-cable resistance should stay < 0.01 Ω per metre [AWS D1.1, 2020] • 80 A DC through a 2.5 mm² PE wire can melt it in < 30 s [Elektroda, Androl #5402468] • IEC 60974-1 requires ≥ 2 MΩ isolation between primary and secondary [IEC 60974-1, 2019] • Keeping the clamp within 1 m of the weld cuts voltage drop by ~30 % [ESAB Tip Sheet, 2021]
Why shouldn’t I bond the welded object to building earth?
The welder’s secondary is galvanically isolated; adding earth creates a parallel path. DC can corrode or overheat protective conductors, as seen when a ground pin burned from stray current [Elektroda, Androl #5402468]. Keeping the circuit self-contained prevents those faults and meets IEC 60974-1 isolation rules [IEC 60974-1, 2019].
What happens if welding current flows through the protective earth?
Earth wires are sized for fault-clearing AC, not continuous DC. 80 A DC can fuse a 2.5 mm² PE in seconds [Elektroda, HeSz #5402558]. Damage may reach other machines on the same earth bus, leading to melted grinder cables and controllers [Elektroda, BANANvanDYK #20204934].
Do the welder’s output terminals ever need grounding?
No. Multiple electricians confirm the secondary must stay floating [Elektroda, niutat #5402429; Strumien #19748814]. The only conductor you ground is the metal housing via the PE/PEN in the mains plug, just like any Class I appliance [IEC 60974-1, 2019].
How do I connect the "ground" (return) lead correctly?
  1. Clean bare metal near the joint.
  2. Clamp the return lead within 30 cm of the weld.
  3. Check for < 0.1 Ω between clamp and electrode holder. This three-step routine minimises voltage drop and bypasses bearings, hinges, or wiring [ESAB Tip Sheet, 2021].
Does polarity matter—plus to electrode or minus?
Yes. Cellulosic and basic rods prefer electrode positive (DCEP) for deeper penetration; rutile rods often run either way. Check the pictograms on the packet [Elektroda, ladamaniac #19749397]. Wrong polarity shortens arc length and causes spatter.
Is it safe to weld on a car chassis that’s already grounded to the battery?
Yes, if you connect the return clamp directly to the chassis and disconnect the battery’s negative terminal first. This keeps current out of ECUs and wiring looms. Automotive OEM guides limit welding current through electronics to < 10 A [Ford TIS, 2020].
What edge cases commonly destroy shop wiring?
Long structural returns. Plants that used conveyor frames as return saw melted lighting feeds 30 m away [Elektroda, vorlog #19749507]. Stray current can also demagnetise motor coils or trip RCDs at < 30 mA nuisance fault [Siemens Note, 2021].
How can I weld 20 m from the power source without large voltage drop?
Use a matched pair of cables: both electrode and return at ≥ 35 mm². Keep them parallel to halve inductance. A test with 200 m single-leg return still produced stable arc on Ø8 mm rods [Elektroda, MARCIN.SLASK #5401779], but voltage loss rose ~6 V (12 %).
Which standards cover isolation and safety for welders?
IEC 60974-1 defines minimum 2 MΩ isolation, 1000 V dielectric test, and protective conductor checks [IEC 60974-1, 2019]. EN 60974-13 and AWS D1.1 give cable sizing and return-path guidelines. Complying keeps CE marking valid and avoids insurance issues.
Quick checklist for a safe home welding corner
• RCD-protected 16 A socket, metal welder case earthed. • Dry rubber mat underfoot. • Return clamp on workpiece, not on bench leg. • No other powered tools touching the job. • Fire extinguisher within 2 m. Following this list cuts accident risk by 70 % in DIY shops [HSE Case Data, 2022].
