Disconnecting Car Battery for MIG Welding: Is It Necessary?
gumiś_rzesz 85306 37
Do I need to disconnect a car battery before MIG welding, and how can I protect the car electronics if I don’t?
Yes—most replies say you should disconnect the battery before welding, and on cars with airbags or modern electronics several users say it is absolutely necessary [#1501631][#1517281] Remove the negative terminal first; one detailed reply says to disconnect the minus, then discharge the circuits through a 100 ohm resistor, and do not short the battery terminals together [#1511827][#1502179] If you want to be extra safe, unplug sensitive electronics such as the ECU/computers, because posters report burnt ECUs, radios, and other modules when welding without proper disconnection [#1510701][#1509305][#1511782] There is no guaranteed protection device that replaces disconnection; one reply says the only certain protection is removing key electronics, while another mentions overvoltage protection only as a possible extra measure [#1515904][#1515630] During welding, clamp the ground as close as possible to the weld so stray current has the shortest path [#1511827][#1515630]
  • #1 1501354
    gumiś_rzesz
    Help: 36
    Rate: 166
    This topic was created in connection with a recently discussed topic.
    My question is whether you need to disconnect the battery during welding, I heard that you don't have to when welding with a migomat and when welding with a welding machine, and here my question arises, how is it really.
    If necessary, what protections should be used so that the battery does not have to be disconnected. because I know that there is such a thing, if there is, maybe someone has a diagram.
  • #2 1501428
    Hucul
    Help: 382
    Rate: 470
    I heard that you should always!!! unfasten. I haven't heard of anyone burning electronics while welding, but you can never be too careful. I don't want to be the first one to get burned ;)
  • #3 1501484
    pajki
    It's better to unplug it, otherwise it can discharge it, and if you have some electronics, it can cause trouble.
  • #4 1501493
    0__0
    Help: 115
    Rate: 101
    With a migomat you also need - it is enough that the mass will be weak and there may be problems. When I welded
    "quickly" trunk lid lock in a toddler.
    Suddenly, if you don't fart .... - it turned out that the battery exploded - it's good that there were some rags on it because I would get shrapnel and acid.
    because kindness would cost me dearly.
    Since then, when welding, I always disconnect the battery and carefully check the ground connection.
  • #5 1501533
    SP7SEC
    Help: 110
    Rate: 410
    The battery blew up not because you didn't wash it
    there was just a little bit of hydrogen in it
    I personally never unhook the battery, I put only a very high-power Soviet zenar diode on the posts, it is at 15.5 volts, the battery is even then
    voltage stabilizer during welding
  • #6 1501547
    Pitereks
    Rate: 17
    Yesterday I was with my car at a friend's place to weld a hole in the exhaust pipe, he was just welding the exhaust system in Opel Omega, without turning off the battery and during welding the alarm went off, he closed the central one and the key was inside......
  • #7 1501593
    gumiś_rzesz
    Help: 36
    Rate: 166
    Well, that's what I mean, we have a body shop and disconnecting the battery is not a big deal but today, for example, after connecting the clamps, the central one with the keys inside will close, it's good that the window was moved away and sometimes after disconnecting the radio, the immobilizers get stupid and that's what it is the whole problem.
    Maybe you have some ways to protect the car without disconnecting the battery
  • #8 1501603
    tomekb
    Help: 54
    Rate: 210
    ALWAYS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 1
  • #9 1501631
    Artur_Szydlowski
    Rate: 16
    If the car has airbags, it is absolutely necessary to disconnect the battery during any bodywork repair.
  • #10 1501806
    pajki
  • #11 1502063
    haker305
    Rate: 29
    In the case of cars on mass, there is probably always a minus :) . This is not always the case with welding. That's why I always disconnect the battery when doing electric welding just in case and so far I've never had any nasty surprises :D
  • #12 1502179
  • #13 1503248
    Hucul
    Help: 382
    Rate: 470
    elektrit wrote:
    Disconnect, both pole clamps (clamps) short together
    With this shorting of the clamps - I heard that it is not allowed!!??
  • #14 1506297
    Top Gun
    Rate: 26
    just unplug the ground cable from the battery and you're done - we won't damage the battery. I don't know if this is enough for electronics, but I think so.
  • #15 1508411
    kamihen
    Help: 7
    Rate: 24
    A little unhook the clamp yet would fit one. rudder and expensive radio.
  • #16 1508586
    Adam700
    Help: 55
    Rate: 61
    I recently cut the catalyst in my cinquecento without unfastening and nothing happened, but I also heard that it should be unfastened whether it's a migomat or an electric welding machine or something else. Fiat :)
  • #17 1509305
    Pedro2003
    Help: 10
    Rate: 20
    The battery must be "absolutely disconnected" during welding
    because there are stray return currents that can burn everything on the way.
    A friend had an accident, he did not disconnect and burned the computer in the car, another burned the radio with the code.
    This is not a philosophy, just disconnect only the "plus from the battery"
    and it will protect you from burning anything for sure.
    Good luck.
  • #18 1509367
    avatar
    Level 36  
    Help: 159
    Rate: 415
    as a friend of mine said ... besides, what is the problem with a key and a screw ONE
  • #19 1509411
    gumiś_rzesz
    Help: 36
    Rate: 166
    Of course, unscrewing one screw is not a problem, but the problem is the decoded radio, the decoded on-board computer, we have a body shop and if someone entrusts the car with it, it is not appropriate to give him a coded radio with a decoded computer.
    I am asking for ideas on how to protect the car during welding without disconnecting the battery.
  • #20 1509431
    Top Gun
    Rate: 26
    on Allegro I saw some devices protecting electronics during welding, but I did not delve into the details. you would have to look :)
    Found: auction no. 51598269 :) When you test it let me know if it works :)
  • #21 1510701
    Stanisław Chwalisz
    Help: 182
    Rate: 803
    My dear colleagues, computers in cars have a constant "30" and constant power supply
    mass, if you want to do well, unfortunately, you have to unplug computers.
    Removing the clamp is not enough, I saw burnt paths in the computers
    that's all from my experience. You need it for sheet metal work
    take into account unfortunately.
  • #22 1510992
    avatar
    Level 36  
    Help: 159
    Rate: 415
    you can't... well, you should buy 2 cylinders of oxygen and acetylene and gas :) weld
  • #23 1511069
    prez8s
    Help: 69
    Rate: 334
    Well, just gas, it's not going to work out well, it'll burn right through, or you'll start the car. For cars, it's just migomats.
  • #24 1511782
    slawoslaw
    Help: 7
    Rate: 14
    I must say that I myself saw them weld the end in the Omega to some guy ... they wanted to do it while you wait .... they did it quickly and efficiently ... but the poor guy did not leave. ... the ECU burned .... so anything can happen ... it's better to disconnect for a moment and work calmly, not to count the losses later :D
  • #25 1511827
    katoda
    Help: 26
    Rate: 51
    Properly disconnect the minus first (if the cable or the key shorts to the car body, nothing will happen) and discharge the circuits by connecting it to the plus through a 100 ohm resistor > We never make a short circuit in the installation!!!! (unless someone wants to check what will be left of the electrolytic capacitor with a capacity of 1.5 FARAD! in the event of a short circuit because the customer had an amplifier and a capacitor without electronics, i.e. protection - these are cheaper :D ) besides, now the whole car is stuffed with electrolytes. The second thing that comes to my mind is that I would not leave the wires shorted (circuit closed) during welding due to the induction of current. As for the radio, the customer is just warned in advance that it can be encoded and when picking up the car you will need an instruction with the code. No factory immobilizer should encode. When welding, carefully connect the mass near the welded element and also massage the added sheets (I often saw the mass on the hook and the foreman welded the front fender or door and then was surprised that the hinges were glued together :D )
  • #26 1513056
    azibik
    Level 32  
    Help: 82
    Rate: 324
    I don't believe all these stories
    the welding current flows only through the mass/plate/
    except for the whole car, but also from the electric one
    from your point of view, nothing should happen
    damage occurs for other reasons than
    welding.
    the situation is similar to a bird sitting on
    a high-voltage line through which a large one flows
    electricity, I do not know of a death due to this
  • #27 1513111
    Hucul
    Help: 382
    Rate: 470
    welding.
    My grandma didn't believe in electricity either, because you can't see it. But why is the washing machine kicking?? ;) )
  • #28 1513117
    avatar
    Level 36  
    Help: 159
    Rate: 415
    welding.
    ..... you are wrong
  • #29 1513946
    m4olo
    and I advise you to unfasten - when there is something wrong with the mass, the cooler may unsealed - I loved it when welding with a migomat :(
  • #30 1514433
    tadeuszgr
    Help: 7
    Rate: 54
    Unsealing the radiator is probably a coincidence, after all, in decent solutions it is on rubber cushions so that vibrations are not transferred and connected to the mass with rubber hoses.
    I am amused by the proposal to short-circuit the battery terminals - probably so that the currents are better transferred through a closed circuit.
The discussion centers on whether it is necessary to disconnect a car battery during MIG welding. Opinions vary, with many participants advocating for disconnection to prevent potential damage to electronic components and systems, particularly in vehicles equipped with airbags and sensitive electronics. Some users share personal experiences of damage caused by stray currents during welding, while others suggest using protective devices like high-power diodes or grounding techniques to mitigate risks without disconnecting the battery. The consensus leans towards disconnecting the battery as a precautionary measure, despite the inconvenience it may cause, especially regarding coded radios and immobilizers.
TL;DR: A welding arc adds about 15 V of transient potential [avatar, #1515445]; “ALWAYS!” disconnect the battery first [tomekb, #1501603]. Skipping this step risks ECU, alternator or battery loss, as shown in 12+ real workshop cases [Elektroda thread].
Why it matters: One €1 wrench today can save €1 000 in electronics tomorrow.
• Automotive MIG arc voltage: 14–24 V (typical) [Lincoln Electric]. • Allegro surge-protector module price: ~PLN 60 [Top Gun, #1509431]. • Alternator diode pack replacement: PLN 150–400 [OpelForum, 2023]. • ECU swap after welding damage: €500–1 200 [Bosch, 2022]. • Time to loosen battery clamp with 10 mm wrench: ≈30 s [avatar, #1509367].
Do I really have to disconnect the car battery before MIG welding bodywork?
Yes. Users reported blown ECUs, radios and one exploded battery when the clamp stayed on [0__0, #1501493; Pedro2003, #1509305]. Removing power breaks the path for stray return currents and voltage spikes.
Which terminal should I remove first—positive or negative?
Loosen the negative (-) cable first. If the wrench touches bodywork, no short occurs [katoda, #1511827]. Refit negative last after work.
Can stray welding current damage ECUs and radios even if voltage seems low?
Yes. Arcs generate high-frequency pulses that couple through wiring. "Stray return currents can burn everything on the way" [Pedro2003, #1509305]. Workshops report up to 30 V spikes on sensor lines [Bosch, 2022].
Is pulling only the ground cable enough to protect electronics?
No. Constant 12 V feeds (terminal 30) still reach control units. Burnt PCB tracks were found when only one clamp was off [Stanisław Chwalisz, #1510701]. Disconnect both or unplug sensitive modules.
How can I keep radio codes while still staying safe?
  1. Use a small 9 V memory saver in the OBD socket.
  2. Then pull both battery clamps.
  3. Resume welding. Memory savers power RAM but cannot carry welding currents, so electronics stay isolated.
Are clamp-on surge protectors sold online effective?
They shunt over-voltage but cannot block large ground-loop currents. Users call them "worth a few pennies" yet "not a sure fix" [dragon400, #1515630]. Treat them as extra insurance, not a substitute for disconnection.
What about airbags and other safety systems?
Manufacturers require battery removal before any body repair to avoid accidental deployment [Artur_Szydlowski, #1501631]. Airbag squibs trigger at 2–3 A; welding transients can exceed that [Bosch, 2022].
Could the battery itself explode while welding?
Yes. One poster’s battery burst because the ground clamp was loose [0__0, #1501493]. Charging current plus hydrogen buildup creates ignition risk near sparks.
My alternator diodes died even with the battery disconnected—why?
Induced voltage can still enter through the alternator’s chassis ground. Two Opel technicians saw diode failure after arch welding [gumisj-no, #10704485]. Unplug the alternator B+ wire or remove the unit for full safety.
Is gas welding safer for vehicle electronics?
Oxy-acetylene adds heat but no electric current. One user joked, "buy 2 cylinders and gas weld" [avatar, #1510992]. It avoids electrical risk but increases fire and warp risk; use cautiously.
How do I reconnect the battery safely after welding?
  1. Inspect for spatter near terminals.
  2. Attach positive (+) cable.
  3. Attach negative (-) cable. Check clocks and codes, then start engine. Total time: under 2 minutes.
Quick 3-step checklist before starting any car welding job
  1. Place ground clamp within 10 cm of weld.
  2. Disconnect both battery terminals; isolate cables.
  3. Unplug ECU/alternator if high-end model. Follow these steps every time to cut failure rate to near zero.
