Welding with Covered Electrode in DC Mode: Plus vs Minus for Penetration, Melting & Butt-Melting
34554 10
How should I set DC polarity and welding current for butt welding with a covered electrode so I get penetration without burning holes?
DC+ on the electrode gives greater penetration and heats the workpiece more, while DC- puts more heat into the electrode, but you should still connect the polarity recommended for that electrode type [#18337774][#18336653] For acidic electrodes use minus, for basic electrodes use plus, and rutile electrodes can often work either way, though many welders prefer minus [#18337043] If you are burning through, the likely cause is too much current or an arc that is too long, not polarity alone [#19796518][#19796558] For a 2.5 mm setup, posters suggest going below 60 A, even around 55 A, and narrowing the gap [#19796558][#19797520]
  • #1 18336589
  • #2 18336653
    wowka
    Help: 49
    Rate: 247
    On the packaging of the electrodes it is written whether the electrode should be + or - and stick to it.
  • #3 18337043
    landy13
    Help: 195
    Rate: 260
    zyx12345 wrote:
    When welding with a covered electrode with a DC welder and with a plus to the electrode (minus to the welded material), there is greater penetration and the material melts more strongly, or vice versa?
    To the acidic electrode - minus, to the alkaline - plus.
    On a rutile indifferent, you can be alternating. But practitioners more often give a minus.
  • #4 18337774
    Michelson
    Help: 82
    Rate: 305
    I'm an amateur so I could be wrong.
    More heat is generated at the positive pole, so when the material burns through, the more you need to weld with DC+ polarity, i.e. + on the electrode.
    The guy in the video welded with basic electrodes E7018 or E7016, rather DC +, but it is not known what diameter. What thickness of the material is also unknown, but rather thick sheet metal.
    You did not write what electrodes you used, what thickness of the sheet, how bevelled, and the size of the gap depends on the thickness of the sheet.
    Maybe try lowering the intensity and/or narrowing the gap first.
  • #5 18338270
    saskia
    Help: 174
    Rate: 1086
    I am not sure how it is with different electrodes, but I have noticed experimentally that if the electrode markings indicate a specific polarity, then this is how it should be connected to the welder. If it is the other way around, the result may be that the workpiece material is "thrown onto the electrode, instead of from the electrode onto the workpiece. This is especially noticeable when the electrodes for welding cast iron are not properly connected. There is a dimple in the workpiece, and a welded bump on the electrode.
    Just like Col. Landy 13, he wrote that acidic electrodes are minus, and alkaline ones are plus, because this determines the ionization of the electrode in relation to the material, and the flow direction of the ionized material depends on the direction of the current flow.
    Of course, the arc-melted material will flow from the electrode by the force of gravity, but the weld is then full of holes and looks like a cast of molten metal in the welded gap, connects here and there, but there is no continuity.
  • #6 18338719
  • #7 19744507
    drucikfaza
    I also searched for a long time about it on the Internet and opinions are divided, but according to my observations, it melts the material more as it is - on the electrode, it happens because the actual current flow is from - to ,
    If I am wrong, please explain why
  • #8 19796518
    ziemek56
    Help: 24
    Rate: 186
    And the holes are usually like material too thin for the electrode.
  • #9 19796558
    palmus
    Help: 233
    Rate: 752
    Or when instead of swimming in the lake, a large arc is drawn. 2.5mm sheet can be easily welded. Try to go slightly below 60A.
  • #10 19797520
    ziemek56
    Help: 24
    Rate: 186
    YES. EVEN 55,
  • #11 19797574
    landy13
    Help: 195
    Rate: 260
    Do you really think he hasn't welded that sheet in over two years?
The discussion revolves around the effects of electrode polarity when welding with covered electrodes in DC mode, specifically regarding penetration and melting characteristics. Users emphasize the importance of adhering to the polarity indicated on electrode packaging, noting that acidic electrodes should be connected to the negative terminal, while alkaline electrodes should be connected to the positive. Observations suggest that more heat is generated at the positive pole, leading to greater melting of the workpiece material when using DC+. However, some users report confusion regarding the melting rates of the electrode versus the workpiece, particularly when using E6012 and E6013 electrodes. Issues such as burning holes in the material are attributed to factors like insufficient material thickness, incorrect current settings, and improper gap sizes. Recommendations include adjusting the welding current to around 55-60 amps and ensuring proper technique to avoid excessive arc length.
