How should a beginner start learning welding, what kind of course or machine should they choose, and what should they look for?
Start with a practical welding course or an experienced welder, because welding is learned mainly by hands-on practice, then back it up with books and video tutorials [#12012631][#13188048] A simple inverter welder is enough for a beginner, and several users said a cheap home-amateur machine is fine if it runs on 230/400 V, melts electrodes reliably, and its thermal protection does not trip every 2 minutes [#8321234][#8327727] For thin sheet metal around 1.5–2 mm, a MIG/MAG (migomat) is the better choice than a basic electrode/transformer welder, which can easily burn holes even at low current [#12407877][#6523749] One reply also advised not to buy something random and to ask the seller for help matching the welder to your needs [#6004095]
Hello, I would like to learn how to weld, I looked for information on this topic on the net and found a lot and I don't know what I really need. Maybe the phrase "I want to learn to weld" is too general, but it is true. I also looked at the courses but these are specialized.
What I need is to stir up sometimes, I don't need papers etc. Where do you really start looking, what courses to look for, and what to look for.
Please do not just write to me to buy a welder and learn by trial and error.
It's best to go to a friend who knows how to weld and ask him to show you how to do it. It's not really a big man. You have to learn it practically. You have to compensate for the cost of electricity and electrodes wasting a friend. I'm talking about electric welding. it is a bit worse because it is more dangerous and without courses and qualifications I would be afraid. If you don't have a friend, in some workshop you will come across someone who will help you.
Please do not write, just to buy a welder and learn by trial and error.
But it's the truth. You can't learn to weld without access to a welding machine. You can acquire all the knowledge in the field of welding, and you will get the real welding skill only when you start to use it practically. By the way, do you know a driver who has learned to drive a car without ever sitting behind the wheel?
In that case, which welder to buy, I know from practice that, however, theoretical knowledge is also useful, and unfortunately I do not know anyone who would weld. I just mean electric welding, can you recommend some reading and model of the welding machine, and the next question, should I buy any welding machine or something specific to learn?
Theoretical knowledge is the most recommended, I can not advise much about a specific model, because I weld myself with a welding machine made by myself in times when there was nothing in our beautiful country. One thing is for sure, do not buy just any welder because you will weld anyway, if you will weld at all. In my opinion, it is enough to go to the store and consult the seller, and you will surely choose something according to your requirements. greetings Zbyszek
Hello, I used to weld a wicket with a BESTER welding machine on plots in Szczecin. A welding teacher from one of the schools was passing by. He stated that it is a very good Polish welder.
So far I have bought a simple electrode welder, but not Besterka, such as 250 A, and I have already welded several times and it even went quite well, unfortunately it is not suitable for welding thin objects, despite setting the smallest current - I burned holes, hehe, or for welding thin objects do you need a MIG welder?
Let him buy the eye ointment for the first week. To learn welding, an inverter is enough, when you go to a higher level, then you can buy something specific - the only question is why? since you do not deal with this professionally ...
And why is the allegro for PLN 300-400 bad? Nothing else is needed for an amateur at home. As long as it was powered on 230 / 400V As soon as it melts the electrodes and the thermal protection does not turn it off every 2 minutes, it is approx.
Hello, connecting to the topic I have the same question as my colleague, what reading for learning welding, and I mean, for example, what electrode for which sheet, what ammeter should I set, etc. I bought an electric welder (http: //www.ebay .co.uk / itm / Einhell-Electric-Welder-Welding-Transformer-230V-XA-Great-Present- / 390429483828? pt = UK_BOI_Electrical_Components_Supplies_ET & hash = item5ae7692334 # ht_4004wt_932) on ebay uk, it's also not supposed to be welding competitive !!! thanks in advance.
It's probably best to go to the course and that's it. I learned everything from scratch, because I was quite green in this topic and left the course with knowledge, practical skills and most importantly a certificate and I intend to go to work abroad, because I can work with him in the EU countries. Check the side of Goworek, they have the welding course I was there. for my part, I recommend it.
MIG welding recommended for automotive sheet metal
Hello. I believe that the migomat is the best for thin metal sheets, e.g. automotive. I know from experience that the worst migomat welds will be a thousand times better than with an ordinary transformer welding machine and if someone has some practice, really nice tears come out. So when it comes to sheet metal up to 1.5mm-2mm, it is only a migrate. It also works great with thicker sheet metal, but I am not able to say whether it is better to weld a sheet over 2mm with a migomat or a welder.
I do not want to discourage anyone here, but if someone thinks that they can weld at the rate, then they are very wrong I am welding professionally for some time they will allow you to weld an element in different positions, you will see the positions PA, PB, PC, PD, PE, PF and PG and the foreman will come to us and will judge how badly you grind it and all over again. If someone wants, I can scan the study materials and send them to an e-mail. I have a book on Mag 135 and Tig 141, I recommend "Gas shielded arc welding according to national and international guidelines" by Leon Mistur. Greetings.
Learn welding through practice, theory, and video tutorials
Old topic, but worth summing up. 1. Welding can only be learned through practical trials. This is not negotiable. 2. The process must be supported by theoretical information from books (enter the following keywords on auction portals: welding, welding, welding, and a few or a dozen titles will appear). Books can be older, used, in welding available to amateurs, not much has changed ("Kowalski" will not be soaking up anything with a laser), the basics of the processes remain the same. In addition to the typically "welding" one, it is also worth getting interested in the literature on metallurgy, materials science, as well as mechanics and strength of materials. Then it will be possible to do more than just "welding the fence on the plot". 3. The internet with video tutorials has been added to the books, for example (unfortunately / unfortunately the best ones are in English): http://www.youtube.com/user/weldingtipsandtricks " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.youtube.com/user/weldingtipsandtricks , http://www.youtube.com/user/ChuckE2009/videos " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.youtube.com/user/ChuckE2009/videos , and the like.
Combining hands-on practice with welding theory and videos
Old topic, but worth summing up. 1. Welding can only be learned through practical trials. This is not negotiable. 2. The process must be supported by theoretical information from books (enter the following keywords on auction portals: welding, welding, welding, and a few or a dozen titles will appear). Books can be older, used, in welding available to amateurs, not much has changed ("Kowalski" will not be soaking up anything with a laser), the basics of the processes remain the same. In addition to the typically "welding" one, it is also worth getting interested in the literature on metallurgy, materials science as well as mechanics and strength of materials. Then it will be possible to do more than just "welding the fence on the plot". 3. The internet with video tutorials has been added to the books, for example (unfortunately / unfortunately the best ones are in English): http://www.youtube.com/user/weldingtipsandtricks " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.youtube.com/user/weldingtipsandtricks , http://www.youtube.com/user/ChuckE2009/videos " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.youtube.com/user/ChuckE2009/videos , and the like.
Your posts are nice to read. Thanks for the given channels, I did not know the latter
Hello, colleagues, tell me if there is any possibility of electrocution when welding, for example when one element is in a vice and the other is held in our hands?
If you hold too close, you can burn yourself, the electricity will not caress you because it is high current and low voltage. safe voltage.
The discussion centers around beginner welding, emphasizing the importance of practical experience alongside theoretical knowledge. Participants suggest starting with hands-on learning, ideally under the guidance of an experienced welder. Recommendations include purchasing a suitable welding machine, with options like electrode welders, MIG welders, and inverter welders being discussed. Specific brands mentioned include BESTER, and the need for reading materials to understand welding techniques and safety is highlighted. The consensus is that while basic equipment can be affordable, investing in a quality welder is crucial for effective learning, especially for thin materials. Online resources and courses are also recommended for comprehensive learning. AI summary based on the discussion. May contain errors.
What’s the simplest welding method for a complete beginner?
Stick (MMA) remains the cheapest entry point: one machine, electrode holder, and clamps. You can weld mild steel outdoors and tolerate rusty surfaces. Users confirm fast learning when paired with practice [Elektroda, awerew, post #6003920] Downsides: slag cleanup and harder thin-sheet control. If you plan bodywork, start with a small MIG instead [Elektroda, piotrekchopin, post #12407877]
Which welder should I buy to learn at home?
Buy a 160–200 A inverter stick welder that runs on 230 V. It strikes arcs easily, weighs <6 kg, and costs ≈PLN 600–800. Inverters give smoother beads than budget transformers [Elektroda, lukas548, post #8321234] Ensure it has at least a 60 % duty cycle at 100 A for continuous practice [Miller, 2023].
How much will a basic hobby welder set me back?
Forum users found serviceable units for PLN 300–400 on Allegro and PLN 500–600 in stores [Elektroda, mac9366, post #6523839] Add PLN 150 for PPE (auto-dark helmet, gloves) and PLN 50 for starter electrodes. Total: about PLN 500–800 all-in.
How do I stop burning holes in 1 mm–2 mm sheet metal?
Drop current to 60–80 A.
Use Ø2.0–2.5 mm electrodes or switch to 0.8 mm MIG wire.
What amperage and electrode size for 1.5 mm mild steel?
Set 70–80 A with a fresh Ø2.5 mm rutile rod; users report clean, hole-free welds [Elektroda, lukas548, post #8326715] Keep a 20° rod angle and move fast to limit heat input.
Is home welding dangerous—can I get electrocuted?
Stick welders use high current but only 20–100 V, below lethal thresholds. "The electricity will not caress you because it is low voltage" [Elektroda, Tomek 265, post #13568400] Main risks are UV flash and burns; wear auto-dark helmets and leather gloves.
Why pick an inverter welder over a transformer box?
Inverters deliver stable DC, hot-start, and weigh 70 % less than coil transformers. Users saw visibly nicer beads after switching [Elektroda, lukas548, post #8321234] Power savings up to 30 % are common because efficiency exceeds 80 % [Lincoln, 2022].
My cheap welder trips thermal protection every 2 minutes—what now?
Budget machines often have small heat sinks and 10 % duty cycles. Let it cool 5 minutes per 1 minute weld or upgrade to a 60 % duty model. Edge case: continuous trips can burn the fan and void warranty [Elektroda, Anonymous, post #8327727]
How do I set up a safe practice routine?
Clamp ground directly to the workpiece.
Tack-weld scrap 5 cm coupons for 15 minutes daily.
Inspect, grind, and re-run until beads look like stacked coins.
Consistent micro-sessions build muscle memory and keep heat on small parts manageable.
