How to Dissolve Glue Droplet on JBL Narka Speaker Coil Stuck to Magnet?
ojciec10 106625 13
What can I use to dissolve glue that has stuck a speaker coil to the magnet?
Try acetone or an acetone-based cleaner, but use it very carefully because it can also dissolve the coil insulation and may affect the coil itself [#5420074] An acetone-based nail polish remover or a PVC pipe cleaner was suggested as an easier-to-find source of the solvent [#5419980][#5420154][#5420978] One reply says acetone can dissolve even a dry droplet, while another warns that if the glue has already fully cured, only mechanical removal may work [#5420449][#5433728] If the glue is cyanoacrylate, a CA adhesive debonder from a modeling store is another option and was reported to work very well [#9954837]
  • #1 5419900
    ojciec10
    Rate: 113
    A familiar glue speaker narka jbl used as a binder glue droplet. He glued it so unfortunately that he glued the coil to the magnet. My question is what to dissolve about the glue.
  • #2 5419980
    Pocieszny
    Help: 229
    Rate: 264
    Maybe acetone?
  • #3 5420074
  • #4 5420095
    ojciec10
    Rate: 113
    I don't have access to the chemical shop. Where to find acetone in everyday life?
  • #5 5420144
    MARCIN.SLASK
    Home appliances specialist
    Help: 1038
    Rate: 2662
    I know there is such a mixture of ethanol and acetone. Used in construction. The price is about PLN 120 for 5 liters. I can give the name in the evening.
    But I doubt it is possible. The components of the "droplets" are very similar to those in the mounting foams. A solvent based on cyano compounds. It uses moisture from the air and moisture from the surface for bonding.
    As long as wet glue (foam) is acetone or PVC pipe glue cleaner. When it dries up, it's only mechanical.
  • #6 5420154
    JoJoe
    See maybe some nail polish remover some are acetone based or go to the paint shop there they should have these things.
  • #7 5420449
  • #8 5420557
    robokop
    Help: 1763
    Rate: 6376
    zbyrek2 wrote:
    You can get acetone at the DIY store.
    Damn it - pure acetone is on the list of so-called precursors, purchase only for the company, for the purposes of the conducted activity. It remains to look for a good nail polish remover - undiluted acetone, without any cosmetic additives.
  • #9 5420727
    ojciec10
    Rate: 113
    Okay, I'll try to look for something. Thank you for your help.
  • #10 5420978
    MARCIN.SLASK
    Help: 1038
    Rate: 2662
    Buy a PVC cleaner. (installation of PVC pipes, before gluing, you clean with a cleaner) - acetone is its main component. At OBI, about PLN 13.
  • #11 5421085
    bruns
    Level 30  
    Help: 101
    Rate: 303
    robokop I do not know what your rules and customs are, but a few days ago I was buying acetone in a local art store. renovation. It stands on a shelf in half-liter bottles together with other solvents, gasoline and denatured alcohol. Whoever wants to buy, here you go! And let me add, I'm from B-slope.
  • #12 5432683
    ojciec10
    Rate: 113
    Today I bought acetone, but the speaker does not want to fall apart :(
  • #13 5433728
    bruns
    Level 30  
    Help: 101
    Rate: 303
    MARCIN is right and I thought so too, but I preferred to wait for the statements of others because maybe someone managed to unstick the "droplet". But even in such a logic as a droplet "binds" as a result of reaction with moisture and not evaporation of the solvent, no solvent does will dissolve.
  • #14 9954837
    mayekk
    Help: 50
    Rate: 63
    Buy a CA adhesive debonder - available at modeling stores.
    I bought it from the HobbyKing store - it works brilliantly (15ml of glue spilled on the countertop) - everything came off without damaging the surface ....
The discussion revolves around the challenge of removing a glue droplet that has bonded a coil to a magnet in a JBL Narka speaker. Various solutions are proposed, primarily focusing on the use of acetone, which can dissolve the glue but may also damage the coil's insulation. Alternatives such as nail polish remover and PVC cleaner, which contain acetone, are suggested for those unable to access pure acetone. Users also mention the potential ineffectiveness of solvents once the glue has dried, as it may bond through moisture rather than solvent evaporation. A recommendation for a CA adhesive debonder from modeling stores is also provided as a viable solution.
