JBL Flip 3 Flooded: Speaker Issues & Solutions After Water Damage, Button & Charging Fixes
Flaszene 5094 9
How can I fix a JBL Flip 3 after water damage when it only turns on while I hold the power button and behaves normally only while charging?
After water damage, clean both boards with 96% pure spirit or isopropanol, dry the speaker thoroughly, and check the ribbon cable that connects the keyboard/button board to the rest of the electronics [#16886175][#16887887][#16888315][#16888428] The symptom of working only while the button is held points to a possible fault in the button/ribbon assembly [#16887887] Do not use vodka or salicylic alcohol; only pure spirit 96% or isopropanol was recommended [#16888428] If cleaning does not change anything, the damage may already be irreversible and the unit should go to service [#16886175][#16887959]
  • #1 16885901
    Flaszene
    Hello, I have a problem with the flip 3 speaker, I accidentally flooded it. At first everything was ok with him but until. Suddenly it stopped working. At some point during operation, the speaker has not turned on normally since then. I managed to turn it on only after holding the button for a long time after turning it on, it works until I release the button. It also works quite normally when I plug it in for charging. And here's the question, what's in it? (I add that I turned it on and got to the battery where there was water that I removed). Thank you in advance for any attempts to help :D
  • #2 16886175
    Freddy
    Help: 1394
    Rate: 2821
    Flooded equipment must not be used, but it should be washed with IPA or clean spirit and thoroughly dried. Another course of action usually leads to irreversible damage.
  • #3 16887870
    Flaszene
    I mean, immediately after that it was dissected and dried. And now nw whether to try something with him at home or give it to the service
  • #4 16887887
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    To check the ribbon connecting the keyboard to the rest of the electronics.
  • #5 16887959
    Freddy
    Help: 1394
    Rate: 2821
    If you have pure spirit, then you can try to wash the tile at home, if not, have it serviced.
  • #6 16888311
    Flaszene
    Hmm which plate because of what I see are two
  • #7 16888315
    Freddy
    Help: 1394
    Rate: 2821
    Both of course.
  • #8 16888395
    Flaszene
    Freddy wrote:
    Both of course.
    Okay, if I do, I'll answer what and how
  • #9 16888428
    Freddy
    Help: 1394
    Rate: 2821
    Only no vodka or salicylic, but pure spirit 96% or isopropanol
  • #10 16888479
    Flaszene
    Okay I'll say so, there is nothing to believe, nothing has changed I will give it to what service and let them get tired
The discussion revolves around issues faced by a JBL Flip 3 speaker after it was accidentally flooded. The user reports that the speaker initially functioned but later failed to operate normally, only turning on when the power button is held down. Suggestions from other users include cleaning the internal components with isopropanol or pure spirit to remove moisture and checking the ribbon cable connections. The user contemplates whether to attempt repairs at home or seek professional service, ultimately deciding to take it to a service center for further assistance.
