VW Golf V: Cruise Control Activation, Button ON, Constant Speed & Light Indicator Issues - PZR
viruz997 72132 17
How do I activate cruise control in a VW Golf, and why would the indicator light come on with the engine off but not work while driving?
Cruise control does not activate just by switching it to ON; you must drive at a steady speed above about 40–50 km/h, move the slider to ON, and then press SET to store the current speed [#5445142][#5445195][#5584191] The indicator should light when the switch is turned to ON [#5476504] If the light only appears with the engine off or goes out once the engine is running, the system may have a fault such as incorrect coding after a retrofit, a bad brake/clutch switch signal, or wiring/contact issues in the stalk, so it needs diagnostic checking [#5476302][#5582038] RES returns to the previously set speed, and holding SET or RES while cruise control is active increases or decreases the set speed [#5476351][#5584191]
  • #1 5445117
    viruz997
    Rate: 28
    Hello. How does the cruise control in VW golf turn on after moving the button to ON, the car does not maintain a constant speed. The light comes on when the engine is off, but when I turn it on nothing happens and the light does not come on. What can it be? PZR
  • #2 5445142
    adam7009
    Help: 656
    Rate: 1635
    first, accelerate the car to the desired speed, then set the slider to the ON position and press the SET button. The control unit will remember the car's current speed and the cruise control function will be activated.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #3 5445195
    yaaro
    Help: 195
    Rate: 1083
    I will add to the set that the speed is above 40 km / h, otherwise the cruise control may not turn on.
    Colleague viruz997 asks only specific questions about the Golf V, suggests to study the manual of the car thoroughly in the evening. In the absence of instructions, look for Allegro, maybe someone has one for sale.
  • #4 5445230
    viruz997
    Rate: 28
    I have in German and the cheapest one on Allegro is PLN 130, so I don't think I'll buy it, if anyone has a PDF version, please. :)
  • #5 5448808
    olo_gsm
    Rate: 20
    As they say in our village: if it was for a cow, you have to have a chain...
    GOLF V in the garage, and you don't mind PLN 130 for a manual??? Shame :)
    The cruise control may also not work, for example, the engine controller receives an incorrect signal from the stop or clutch switch, but in your case everything probably works, you just don't know the basics of operating your car.
    Autoelektronika Aleksander Stachowiak
    Jałowcowa 12, Włocławek, 87800 | Company Website: Www.vagelektronika.pl
  • #6 5476054
    viruz997
    Rate: 28
    I press -set I press OK RESET I press RES and the car does not maintain speed
  • #7 5476302
    bartek_j
    Help: 255
    Rate: 817
    Well, it's probably the cruise control "coded" from the controller, the contactology at the clutch / brake pedal (but it would probably throw an error ..) or the contactology / cable of the lever. It needs to be hooked up and tested.
    Can you find a pirated version of this book? Hint: emule.
  • #8 5476339
    viruz997
    Rate: 28
    I just can't find it anywhere ;(
  • #9 5476351
    jarecki04
    Help: 76
    Rate: 283
    Hold the button for a while and short presses will raise or lower the speed of the car
  • #10 5476464
    viruz997
    Rate: 28
    Shouldn't the dash light come on when the switch is turned to ON?
  • #11 5476504
    jarecki04
    Help: 76
    Rate: 283
    She should
  • #12 5476531
    viruz997
    Rate: 28
    lights up when parked and not while driving
  • #13 5477768
    WITEK1952
    Help: 75
    Rate: 388
    Hello. My brother just bought it and gave it a ride. I did it while driving, so I don't know what I was pressing. If I remember correctly, when I pressed the top of the button, the car accelerated until I let go. When I let go, it kept the speed. on our winding and congested roads. Regards.
  • #14 5582038
    Remik71
    Help: 43
    Rate: 303
    If the indicator lights up when the switch is turned ON at a standstill, and goes off with the engine running, and additionally the ECU registers an error - incomprehensible switch signal, it all means that the cruise control was not factory-made, it was added, unlocked GAME in the ECU, but one small thing was not done which is generally not required in most golf/jettas,
    you just happened to have to do it. Details on pw.
    Regards
  • #15 5584191
    Pa7aK
    Help: 6
    Rate: 33
    The cruise control is definitely working, but you can't use it.
    After 1 find the right way to learn cruise control
    After 2, accelerate the car at least 50 km/h
    Switch the slider to ON
    Press SET - Auto will maintain speed.
    When you press the brake, the cruise control will stop maintaining speed. You press RES, the car will return to the pre-set speed.
    While the cruise control is maintaining the speed, hold SET - the car will slowly increase its speed after releasing the cruise control will keep it. Analogous to RES, only the speed will decrease.
    That's all. widths.
  • #16 5584415
    Remik71
    Help: 43
    Rate: 303
    This cruise control will not work, because after firing, the light on the meter goes out.
  • #17 5664497
    viruz997
    Rate: 28
    I noticed that after turning on the cruise control, the light is on up to 30km/ha above this speed it will disappear from the counter, but when the speed still drops to 30 it will turn on again Can connecting to a computer show this error? Please reply. Thanks in advance :)
  • #18 6261078
    Pawlus17
    Hello, I have a Seat Toledo II 1999 1.9 TDI 90kM, I want to buy a combination switch with Cruise Control. can someone tell me how to set and what in the computer using vag?? Regards.
The discussion revolves around issues with the cruise control system in the VW Golf V. Users report difficulties in activating the cruise control, with the light indicator not functioning correctly when the engine is on. Key steps to activate the cruise control include accelerating to at least 40 km/h, setting the slider to ON, and pressing the SET button. If the light does not illuminate while driving, it may indicate a malfunction, possibly due to incorrect signals from the stop or clutch switch. Some users suggest that the cruise control may not be factory-installed, leading to potential coding issues. Additionally, there are inquiries about obtaining a manual for proper operation and troubleshooting.
