SEAT Ibiza 6l 1.4 BBY - Cruise Control Failure, EPC Light, Clutch & Brake Sensor Check
somas3k 7278 3
  • #1 16609680
    somas3k
    I warmly welcome,
    Over a year ago I added a cruise control to my Ibi, which faithfully served me for over half a year. Towards the end of his life, he would blow my epc light out of me and stop working until at some point it completely stopped working without throwing any bugs or epc light. The clutch and brake sensor are working, the computer sees the cruise control power on, pressing set and res, but the cruise control does not turn on. I don't remember what a mistake it was at the end of his life, unfortunately. The battery has already been disconnected several times. I tried to activate it again today but with no improvement. I don't remember with what code I activated it a year ago, today I used 11463. Any advice what else can I check? Link to the movie where I recorded the switching of bits responsible for the cruise control, brake and clutch.
  • #2 16610611
    sk700
    Help: 173
    Rate: 420
    Check the cable continuity from the handle to the ECU.
  • #3 16610817
    somas3k
    You're talking about that single conduit that plugs into the ankle in the bulkhead wall, right?
  • #4 16611406
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    There is no change at all in the 00x0 position for the lever.
    Buttons and sensors, by the way, and what about showing the speed in the engine controller?
    Without it, the cruise control will not work.
