Electric Oven: Understanding Connected Load, 3.5 kW Power, Heating Elements, Fans & Lighting
kochzg 61073 5
  • #1 5482733
    kochzg
    Rate: 8
    As is the case with one of the parameters of the oven, the so-called Power Connection.
    If the manufacturer specifies 3.5 kW of connected power, it means that it is the sum of the power of all heating elements, fans and lighting that are in the oven. Is it sometimes not the maximum power from one of the heating elements (e.g. only a double grill)?
    Cheers
    kochzg
  • #2 5482764
    mrhari
    Help: 835
    Rate: 3239
    The greatest power is achieved by the strongest element or combinations of elements. So the highest power consumed by the oven is 3.5 kW
  • #3 5482821
    kochzg
    Rate: 8
    So let's assume theoretically that if there are elements in the oven, for example:
    - lower heater - 1000W
    - upper heater - 800W
    - infrared grill - 1700W
    - double grill - 3500W
    then the sum of the power is 7000W.
    However, I do not use all the heating elements at the same time, but only individually. So from the previous post it follows that the connection power is 3500W, which is a double grill.
    I mean right ????
    Regards
    kochzg
  • #4 5482851
    mrhari
    Help: 835
    Rate: 3239
    Do you have the option to turn on all the elements at the same time? I do not think so. Can the grill and some other elements be turned on? If not, you have good reasoning.
  • #5 5482868
    kochzg
    Rate: 8
    I cannot turn on all the elements, but before buying an oven, I wanted to make sure that my electrical system will last.
    Thanks for the help.
    Regards
    kochzg
  • #6 5484166
    jorgkrab
    Help: 39
    Rate: 71
    This is what it looks like in terms of the power provided by ZE.
    POWER CONNECTION
    The highest active power consumed by the customer specified in the relevant contract between the supplier and the customer
    For your oven, it is a minimum of 3.5 kW, but that's not all, there are other receivers probably in this facility. :D
    Regards.
    You correctly understand the maximum that this device takes in the most energy-consuming combination.
    In a single-phase installation, the current is about 15.2A. A minimum cable of 3x 2.5mm? is recommended. Of course, copper.
