Connecting 7.2kW Induction Hob & 3kW Oven: 3-Phase Socket vs 230V with Kettle & Fridge in Circuit
jonathan 117390 23
Can I connect a 7.2 kW induction hob and a 3 kW oven to a kitchen’s 230 V socket circuit, or should the hob use the three-phase supply and the oven get a separate phase/connection?
Do not run the 3 kW oven, kettle, and fridge from one ordinary 230 V kitchen socket circuit; a 3 kW oven already exceeds a typical socket’s load and the circuit is usually limited to 16 A, so the oven should have its own connection/cable [#5727368] The hob should be wired to two phases, and the oven should be connected to the third phase [#5728997][#5840149] One reply explains the hob’s L1 and L2 go to any two phase conductors, while N goes to neutral and PE to protective earth; the oven uses N and PE the same way, with its third conductor on the remaining unused phase [#5730876] Another note adds that many such hobs are designed for 2 × 230 V operation, not a true three-phase load, and that the third phase is reserved for the oven [#5840149][#5843779] If you are preparing the installation, have an authorized electrician wire it and verify the exact connection diagram on the appliance [#5730535][#5730876]
  • #1 5727278
    jonathan
    Rate: 18
    Hello, I have a question about connecting an induction hob with a power of max. 7.2kW and an oven with a power of 3kW.
    I have a 3-phase socket in the wall and now my question is whether the hob and the oven must be connected to a 3-phase socket together, read only the plate, and the oven to 230V.
    The problem is that I have the plate (where phase 3) on the other side of the wall as the oven, but I can pull the cable to the other side, but is it necessary?
    If I plug the oven into a regular 230V socket in the kitchen and the oven, electric kettle and fridge will work in one circuit, will all the standard installation in the kitchen last?
    Greetings,
    Jonathan
  • #2 5727368
    basgol
    Help: 60
    Rate: 190
    A typical single-phase socket (plug too) is able to withstand a load of up to 10 A. An oven with a power of 3 kW consumes a little more (when fully started). Installation in perfect condition (1.5mm?) withstands more, but the circuit can be protected with max. 16 A, so in total, the circuit should not be loaded more than 4 - roma kW - then without a plug-socket connection only through the installation strip (cube). I advise you to pull it by force.
  • #3 5728983
    jonathan
    Rate: 18
    only now to which phase to connect this oven ??
    Connection diagram of the hob
  • #4 5728997
    Andrzej G
    Home appliances specialist
    Help: 110
    Rate: 290
    When the hob is connected to phase 1 and 2, connect the oven to phase 3.
  • #5 5730383
    jonathan
    Rate: 18
    And 3rd phase is brown which is compact with blue? because something's wrong with me.
    Maybe someone will write to me what wires should I connect with the contact, green-yellow-blue-brown? it makes no sense because blue and brown are compact?
  • #6 5730535
    mirofalcon
    Help: 72
    Rate: 360
    If you have new equipment, I advise you to order a fitter with home permissions, because you must have the fitter's seal in the warranty anyway
  • #7 5730776
    jonathan
    Rate: 18
    It will be a company to install the equipment, but I want to prepare the sockets, and now, before painting, how to do something, a socket for the oven and pull the wire from the 3-phase
  • #8 5730876
    basgol
    Help: 60
    Rate: 190
    Listen to the mirofalcon, if not, I will explain to you. The board works on two phases, the third is not needed. Everything is in the diagram - N is connected to the operating zero in the installation (it should be a blue wire, but you need to check it), PE protective conductor (yellow - green) is connected to the same in the installation. If there are no two separate zeros in the installation (old installations were four-wire), then both N and PE are bridged with one zero. The other L1 and L2 are connected to any two phase conductors From the oven N and PE the same, and the third wire (not blue N or yellow - green PE) to the third unused phase.
  • #9 5839559
    marcinradom
    Rate: 60
    I will stick to the topic and ask about one thing from my esteemed colleagues. I am familiar with buying an induction hob Link with a power of 5.6 kW. my question is about connecting this device. I have a power socket nearby (3 phases, zero and protection), but the power cord is YDY 5x2.5mm. is it safe to connect this board to such a cable?
  • #10 5839647
    basgol
    Help: 60
    Rate: 190
    For a power of 5.6 kW it is enough with a large margin.
  • #11 5839765
    marcinradom
    Rate: 60
    thanks mate warmly. I have one more question; what maximum power can i connect the hob to this socket so that it is safe?
  • #12 5839816
    basgol
    Help: 60
    Rate: 190
    It depends whether you are connecting two or three phase. If you use three phases, you can load up to 10 kW, with two-phase up to about 7 kW, these are safe loads.
  • #13 5840149
    libretto4
    Help: 53
    Rate: 141
    There are no three-phase boards, and as there are some few models, the third phase powers the electronics. In addition, the heating zones work on 230V.
    Always the left side of the plate is one phase and the right side is the other. We will use the third phase for the oven.
  • #14 5843544
    marcinradom
    Rate: 60
    I am at the stage of selecting an induction hob and all those I watched from the bottom can be powered with one phase, two or three. I have the ability to connect the board to three phases, so I will. I understand that with this type of power supply and with the cross-section of the power cable 5x2.5mm square, I can connect a 10kW board. I understand that I can load one 2.5mm square wire with the power of about 3kW, right?
    the fact that the fields work on 230V seems to be logical, but this is why power is used with two or three phases so as not to load one wire with such high currents - this is my reasoning. when it comes to 230V, the voltage between the "0" cable and each phase is 230V, and between two phases 230Vx?3 or 400V. I still remember this from school.
    thank you all for advice, information and opinions.
    Best wishes
  • #15 5843590
    libretto4
    Help: 53
    Rate: 141
    I will add that some boards actually have 3 phases connected to the connector, but only two can be physically used and the third connector is only to plug in the cable there so that it does not fall over the housing.
  • #16 5843603
    basgol
    Help: 60
    Rate: 190
    Check carefully whether the selected three-phase connection diagram contains certainly the description of 3 x 400 V? , because often a three-phase connection applies to marine or military networks marked with the description 3 x 230 V? , where the voltage between the phases is 230 V and connecting according to of this schematic the 3 x 400 V network gets a big buum !!
  • #17 5843729
    marcinradom
    Rate: 60
    the board will be connected by an authorized electrician. I just want to find out about the possibility of connecting the device, the permissible power of the device, in order to safely use this equipment before buying it.
    since the boards are powered by only two phases, what maximum power can my board have to safely connect it to the socket, which is powered by a 5x2.5 YDY cable?
  • #18 5843778
    basgol
    Help: 60
    Rate: 190
    In this case (as I wrote above) it can be up to 7 kW (8 kW will also last), moreover, a licensed electrician will certainly know.
  • #19 5843779
    samsu100
    Help: 58
    Rate: 243
    Virtually all commercially available plates can be connected to an installation made with such a cross-section. Of course, we are talking about connecting 2 x 230V.
  • #20 5843804
    marcinradom
    Rate: 60
    it is a pity that it will only be spoken when it is already bought.
    this is the information I meant. Thanks.
  • #21 7224856
    marcinradom
    Rate: 60
    after a few months of using the album, I can say that it fully met my and my wife's expectations. even electricity bills did not increase by more than PLN 50 / month.
    now my question, of course regarding this album. This plate is connected to the electric network with cables with a cross-section of 2.5mm2. The cooking zones are divided in such a way that the left two are powered from one phase, and the right two from the other, the third one is known to the oven. when on one side (on one phase) there are two pots and both fields are turned on, one of them (always with less power) as if waving. waving consists in continuously, evenly switching on and off the induction currents, but as I wrote earlier, only in the field of less power. in practice, the field heats up 1.5 seconds, and the next 1.5 seconds does not heat up all the time. of course, what is in the smaller field will be cooked, but I do not know if this is the correct operating mode of the induction hob. changing pots, increasing their diameters and the like does not help. pots, of course, intended for the induction hob.
  • #22 7315052
    xavud
    It just so happens that I am also buying induction - specifically TEKA IR 641 (I would have to install gas in a new apartment - which would take several months and eat up several thousand hence the profitability of connecting questionable - at least for the next few years). I have a question here - I would like to connect this board myself - I am an automation specialist and I have the power to 15kV and connecting 4 or 5 cables is not a problem.
    And here is my main question - do I have to look for an electrical installer who will stamp this stamp and how much can it cost me to have a valid warranty? It's a bit annoying - because I don't have an electrical installer stamp and I don't have any friend who would have such a stamp.
  • #23 7315262
    minoor
    It just so happens that yesterday I called the portfolio asking what qualifications an electrician must have to raise the guarantees. It turned out that SEP E 1kV qualifications are enough and you do not need to have a stamp, only a photocopy of permissions is enough.
    By the way, I have a question because in the manual of this board it says "When connecting the device, make sure to prepare an installation that allows disconnecting the device from the mains (switching off all poles) with a contact gap of at least 3 mm by means of a contact - a wide opening.
    for this purpose, the LS-contact, fuses and contactors are used.
  • #24 7919409
    karol n.
    Rate: 9
    This is a matter of gibberish from some unsuccessful translation. The point is that after disconnecting the power supply, the distance between the contacts of this device should be at least 3 mm apart. Something like this is ensured by the so-called flat automatic machines / fuses from German LS (Leitungsschutzschalter) http://de.wikipedia.org/wiki/Leitungsschutzschalter http://pl.wikipedia.org/wiki/Wy%C5%82%C4%85cznik_instalacyjny
The discussion revolves around the connection of a 7.2kW induction hob and a 3kW oven, focusing on whether both appliances should be connected to a 3-phase socket or if the oven can be plugged into a standard 230V socket. Participants highlight the importance of adhering to electrical load limits, noting that a typical single-phase socket can handle up to 10A, while a 3-phase connection allows for higher loads. Recommendations include connecting the hob to two phases and the oven to a third phase. Concerns about wiring colors and safety standards are also addressed, emphasizing the need for professional installation to ensure compliance with warranty requirements. The discussion concludes with insights on the safe power limits for various configurations and the necessity of proper circuit protection.
TL;DR: A 3 kW oven pulls ~13 A on 230 V and “use three phases for loads above 7 kW” [Elektroda, basgol, #5727368; #5839816]. Mix hob and oven across separate phases to stay under a 16 A breaker. Why it matters: Correct phase-balancing prevents tripped breakers, melted plugs, and voided warranties for kitchen appliances.
• 16 A circuit ≈ 3.7 kW safe continuous load on 230 V [Elektroda, basgol, post #5727368] • YDY 5×2.5 mm² copper supports up to 10 kW when split over 3 phases (≤16 A/phase) [Elektroda, basgol, #5839816; IEC 60364-5-52] • Typical induction hob zones draw 1.4–3.7 kW each at 230 V [Bosch Tech Sheet] • Warranty sign-off usually needs SEP E ≤1 kV certification; stamp not required—attach copy of licence [Elektroda, minoor, post #7315262] • Mis-wiring 3 × 230 V devices to 3 × 400 V can destroy electronics instantly [Elektroda, basgol, post #5843603]
Can I run a 7.2 kW induction hob and a 3 kW oven on one 230 V kitchen circuit?
No. Together they reach 10.2 kW ≈ 44 A, far above a 16 A socket’s rating. Split the hob across two phases and put the oven on the third to keep each phase ≤16 A [Elektroda, basgol, #5839816; #5727368].
Which phase should the oven use when the hob uses two phases?
If the hob is on phases L1 and L2, connect the oven’s live to the remaining L3, with its neutral (N) and protective earth (PE) commoned as normal [Elektroda, Andrzej G, post #5728997]
What wire size is safe for a 5.6 kW or 7 kW hob?
A 5 × 2.5 mm² copper flex is adequate up to ≈10 kW when three phases are available—current stays below 16 A per core [Elektroda, basgol, #5839647; IEC 60364-5-52]. For single-phase hobs above 3.6 kW use 4 mm² and a 20 A breaker.
How do I balance loads across three phases?
  1. Check appliance wiring diagram for L1/L2 assignment.
  2. Tie hob left zones to L1, right zones to L2; link neutrals.
  3. Connect oven live to unused L3, then test with clamps for <16 A per phase. “Phase balancing keeps cables cool and bills low” [Elektroda, basgol, post #5730876]
What happens if I wire a 3 × 230 V hob to a 400 V network?
Electronics see 400 V phase-to-phase and fail immediately—often with audible pop and warranty voided [Elektroda, basgol, post #5843603] Always match the plate’s voltage label to supply.
Why does one induction zone cycle on and off every 1.5 s?
Induction controllers time-share power when two zones share one phase; the lower-priority zone pulses to keep total phase current under its programmed 16 A ceiling [Elektroda, marcinradom, post #7224856] This is normal unless cookware fails to heat.
Do I legally need a licensed electrician to connect the hob?
Manufacturers ask for sign-off by a technician with SEP E ≤1 kV (or equivalent) certification; a photocopy of the licence in the warranty booklet suffices—no embossed stamp needed [Elektroda, minoor, post #7315262]
What disconnect device meets the “3 mm contact gap” note in manuals?
Any DIN-rail miniature circuit breaker (MCB) or isolator marked IEC 60947-3 provides ≥3 mm air gap when off. A 3-pole 16 A C-curve MCB is typical [Elektroda, karol n., post #7919409]
How much current can a standard 16 A Schuko plug handle continuously?
Rated 16 A but practical continuous load should stay below 10 A (≈2.3 kW) to limit heat at contact pins, per VDE 0620 figures and forum experience [Elektroda, basgol, post #5727368]
Edge case: Can old 4-wire TN-C installations feed modern hobs safely?
Yes, but you must split the PEN conductor into separate N and PE at the appliance side and bond them—failure to do so removes protective earthing and risks shock [IEC 60364-4-41].
What maximum hob power can I fit on two phases and 2.5 mm² cable?
About 7 kW safely; 8 kW is possible but offers little thermal margin during long cooking sessions [Elektroda, basgol, post #5843778]
Can I prepare the sockets myself before the electrician arrives?
Yes. Run a 5-core 2.5 mm² cable from the three-phase junction box to a 5-pin 16 A outlet near the hob, label phases, and leave conductors un-terminated for final testing [Elektroda, jonathan, post #5730776]
