Build or Buy Metal Detector: Comparing Allegro's PLN 150 Options, Schemes & Hobby Treasure Hunting
patryk-84a 20686 29
Should I build or buy a metal detector for up to PLN 150 that can find small beach treasures while distinguishing non-ferrous targets from bottle caps and other scrap?
With a PLN 150 budget, a reliable detector with effective discrimination is unlikely; a usable discriminating model costs about PLN 550 new or PLN 300–400 used, while very cheap pulse-induction units generally lack discrimination [#5491703] For beach and rubbish-filled areas, a dynamic detector is preferable because it searches small non-ferrous objects more effectively and offers better discrimination, whereas PI detectors can become frustrating around extensive metal litter [#5509484] The All1 VLF/TR design is a realistic DIY option with extensive documentation, but building and balancing its probe is difficult and requires careful tuning, ideally with a two-channel oscilloscope [#5492454] [#5492895] For an easier low-cost build, the modernized Lucaslab/Sandbanks pulse detector uses widely available parts, is stable and sensitive for a PI design, and can use LF356, OP07, TL081, or uA741 in place of LF357, although sensitivity and range may decrease with the latter choices [#5492560] [#5492895] A PE/Sandbanks-style PI detector can work immediately when assembled correctly, but it will not provide the desired metal discrimination [#5492682] The search coil is critical: accurate winding on a template, shielding, and precise adjustment are essential for successful operation [#5492529] [#14733486]
  • #1 5491332
    patryk-84a
    Help: 40
    Rate: 212
    Hello, as in the topic. What do you think about these detectors from allegro up to PLN 150? Will I build something better in terms of such money? What kind of scheme, detector do you recommend? It is not meant to be a professional tool for making money only hobby equipment for searching for "treasures" eg at the seaside, in the sand. He would have to distinguish between noble metals and, for example, bottle caps from :) and that cars from the nearby parking lot would not :) .
  • #2 5491441
    Świętoszek
    Help: 5
    Rate: 25
    If you are interested in this, I have a schematic of quite a good detector. And by the way I have a detector for PLN 30, but this is a total lime tree.
  • #3 5491582
    patryk-84a
    Help: 40
    Rate: 212
    No 30zl is an exaggeration of :) , so much the etched plate can cost, but it is not assessed in total devices at a price because sometimes it is so that cheap solutions are better than the more expensive ones. I remember that in PE, there used to be a schematic of the microprocessor detector. And I used to start assembling a detector on discrete elements, but I do not know how much it was worth. I am looking for something proven and with decent parameters. If yours is good enough, then start a schematic, but I'm also open to other suggestions.
  • #4 5491634
    telemah
    Help: 81
    Rate: 62
    elektrit wrote:
    If you mean these MD or Jabla then I do not recommend it.
    Jabel if it's solid - it's not bad! there is no distinction between metals but
    on military equipment is very good! if you are not looking for very cluttered terrain. There are several companies that simple pulse detectors on the basis of all-available old as the world of construction sell in the price of 700 :!: and they are not
    no better than the mentioned apple. Normal detector with discrimination - i.e. no toy can be bought at a price of about PLN 550, can be used for PLN 300-400. I can not afford cheaper unless you do it yourself. However, construct a decent detector with effective discrimination unless it is expensive It's a bit complicated - without any experience in building some more complex electronic circuits, the construction of such a detector is a difficult thing. In addition, you should have equipment such as a frequency meter and oscilloscope - preferably two-channel and as I mentioned a lot of enthusiasm and a lot of experience in constructing various devices. I advise beginners not to get on the construction of such a detector. And a good impulse detector can be done for a few dozen zlotys - but unfortunately there is no discrimination in it.
    This microprocessor detector - it's lime! overflow of content over the form - the microcontroller does not overwork there - it replaces the two 555 type outlets, the funniest thing is that simultaneously with the microcontroller there are old wz. operational remembering the king of the so-called external compensation, the constructor did not even want to replace these "dinosaurs" with some modern cubes. If someone wants to do so. impulse - let me read my posts in a few of them I gave the lead for pulse detector with good performance, 100% tested and assembled from popular components.
    Greetings
  • #6 5491986
    patryk-84a
    Help: 40
    Rate: 212
    I do not want to look for scrap metal. My point is to distinguish precious or precious metals from ordinary scrap. Tenderness could also be not too bad. I have experience in building layouts, but I have never made the detector, come once. To sum up, I am looking for a scheme with discrimination, tested and preferably as if the person who built it could not write something about it, because truthfully I did not have any detector in my hand.
    Added after 1 [hours]:
    Now I think so that we do not think about the same microprocessor detector. The one about which I wrote was from the EP, not EP, PE do not produce anymore. That detector was on prock but had discriminations on the led and additionally some buttons, there were no ops. Maybe I exaggerate a bit with this discrimination. Maybe some really good detector without discrimination? Or maybe the PE? Only where to get the feed?
  • #7 5492370
  • #8 5492454
    telemah
    Help: 81
    Rate: 62
    hehe Such discrimination on led diodes with real discrimination has nothing to do, you have to distinguish discrimination from the distinction between :D and quite poor discrimination. If you want to make a detector yourself with effective discrimination - then build yourself All1 - it's on the electrode I recommend it to you for the simple reason it has a whole lot of documentation and descriptions, which greatly simplifies the matter.
    Ps.I do not know how these new armands but those with whom I had the opportunity to podreptać a bit (discoverer, prospector) were very average, especially the latter - prospector is worth mentioning that cost about 1000 PLN and performance had such as cheap western beaches (such for 500-600 PLN ) such as Garret ACE150 or Bounty Hunter Tracker4 / Quick Silver
  • #9 5492480
    patryk-84a
    Help: 40
    Rate: 212
    Is this All1 quite good? My friend telemah, you used to recommend an impulse detector, what can you say about it? And I'm looking for Alla1.
    And besides, I have a two-channel oscilloscope, and I think that frequency is also calculated from it.
  • #10 5492529
    pukury
    Help: 244
    Rate: 193
    A few years ago, I made several copies of the "magnum" detector, an old construction - but quite effective.
    The problems were with the coil - only templates and accuracy gave effect.
    So watch out for the coils.
    Greetings .
  • #12 5492560
    telemah
    Help: 81
    Rate: 62
    This impulse detector which I recommended has very good performance, good ranges in the ground, a lot of sensitivity to small objects - which is rare in impulse detectors, it is easy to tune and stable - what more :?: and in addition it is simple in construction when it is :?: from new proven elements it moves from the so-called kopa - its documentation is on the LUCASLAB website. I also have other PCBs reduced to it with thicker paths, even such a thickened one has the same advantages - the paths are thicker and less digestive - and the detector on the new PCB works the same as on the old one.
    As for All1, this is a much more difficult construction, the most work is with tuning and balancing the probe, but its construction is not too problematic or difficult - because as I said in the network there are literally tons of descriptions and photo guides, you should also be able to .
  • #13 5492660
    patryk-84a
    Help: 40
    Rate: 212
    I think I will do it, I will start with impulse and see what it is with. Probably in the course of searching something will start missing (I do not know it yet), so once I know what I will build a more professional construction. If you have it, you can throw other tile patterns into it or whatever you have.
    robokop
    Help: 1763
    Rate: 6372
    It's quite good, but it's a dynamic detector, which is quite problematic for a beginner, moreover, it is very difficult and tedious to perform and align the probe independently. There are two masters here who have a lot of knowledge on this subject - Elektronik and Colektor (I guess that's the way it is written, it's All, that is the constructor). I recommend the pulse detector described in the forum with "PE", Sandbanks clone, works immediately with the correct assembly, the problem lies in acquiring one transistor - KP103Ż. Or a more advanced design distinguishing Fisher555 or its modification "Salamandra". Although on the other hand, ready-made "Smętki" are not expensive.
  • #15 5492752
    patryk-84a
    Help: 40
    Rate: 212
    I think I used to start building this pulse PE, but I stopped because of the lack of a transistor. In the electronics store, they could not advise me anything, and I did not have access to the net. Somewhere to me this whole built-in circuit disappeared (only the transistor was missing), even the probe was already done. I will take this impulse from LUCASLAB for probably the most popular elements.
  • #16 5492895
    telemah
    Help: 81
    Rate: 62
    patryk-84a wrote:
    I think I used to start building this pulse PE, but I stopped because of the transistor's lack. In the electronics store, they could not advise me anything, and I did not have access to the net. Somewhere to me this whole built-in circuit disappeared (only the transistor was missing), even the probe was already done. I will take this impulse from LUCASLAB for probably the most popular elements.
    If you want, I can send you some pieces of this KP103Ż I have somewhere a few of the scrapped Soviet equipment :D but as I said, I strongly recommend the pulse from "Lucaslab" it is according to me the best impulse detector that will easily put any amateur - and you can buy parts in every store. If you want this modified PCB I will send you an e-mail - it is in a large resolution in JPG, of course I will give you the dimensions of the tile just put it in some text editor and set the dimensions of the printout, you can use the originals. tiles but it is larger and has thinner path through which the plate digests longer because the etchant must digest more copper. The LF357 operational gain is used in this detector - but it can be replaced by another high-gain op. - I put, for example, LF356 and it's ok, in another I put OP07 and it was great too! both op-amps are cheap and generally available.
    You can even throw in the popular TL081 or uA741, but the detector's range and sensitivity to small items will drop slightly.
    I have already built 3 such detectors and everybody is flying to this day.
    If you had any problems during construction, it's a bold move
    Kol.Robokop
    What I am proposing is the one there (n-th) transformation of sandbanks
    simply modern elements were used there, removed these atypical FETs, only one N-feta was left (popular BF245)
    The inverter has been slightly modified and a few other minor modifications - a good effect has been achieved - the original sandbanks do not reach its heels! I know because I built it too. Besides, if I think that someone had to look for LM709 Ma501 systems these days, etc .. then I sincerely sympathize - these monuments are probably the easiest to find in
    some antique shop :D
    As for the salamanders or fisher - I think they are more complicated than All1 - because there are fewer documentation and descriptions, fewer people built them. Added to this are operational amplifiers from the CA family that are not so easy to get! And All1 is in a simplified version on a single-sided straight board, the only problem (it is not such a big problem) is to build the probe itself because it has to be tuned in resonance to the frequency response then it should be balanced by monitoring the voltage (and shape of voltage) unbalance with an oscilloscope. Therefore, I think that due to the innumerable number of elaborate and the number of constructors - amateurs counted in thick hundreds, All1 is the simplest VLF / TR detector to be assembled.
    Ps.Salamandra and F55 are basically the same! these are static detectors
    nowadays they are used to search for large military objects, and to a limited extent to the location of underground installations, and when it comes to detectors focused on minor finds and universal
    dynamic detectors are absolutely dominant - mainly due to their numerous advantages - m.in. faster terrain searching, easier operation and running of the detector, slightly more effective discrimination and much greater sensitivity to small objects from non-ferrous metals
  • #17 5493011
    zdzicho44
    Help: 30
    Rate: 117
    KP103Ż was used in Ruby 707 to 1974 in block Y1. in Impulsowki it was used as a substitute, because there were no other transistors with the p-channel in our country.
    For those interested, I can give the KP103Ż parameters, maybe they will find some equivalent.
  • #18 5493040
    telemah
    Help: 81
    Rate: 62
    Instead of KP103ż you can give:
    2N3820
    J176
    they will come because I used to check it myself.
    However, there is no point in having fun in orig. sandbanks if he is his
    a heavily improved version on contemporary popular components. :!:
    Świętoszek
    Help: 5
    Rate: 25
    I give this diagram along with the description.
    • BUDOWA.DOC (39.5 KB) You must be logged in to download this attachment.
    • SONDA.GIF (6.37 KB) You must be logged in to download this attachment.
    • SCHEMAT MONTAŻOWY.gif (35.99 KB) You must be logged in to download this attachment.
    • SCHEMAT IDEOWY.gif (39.81 KB) You must be logged in to download this attachment.
    • PŁYTKA DRUKOWANA.gif (121.37 KB) You must be logged in to download this attachment.
  • #20 5493593
    patryk-84a
    Help: 40
    Rate: 212
    What do you think about the detector colleague Świętoszek?
    LIST OF ELEMENTS
    The use of LM317 instead of REG1117A is acceptable, but it should be taken into account that the detector will work worse. When the battery runs out a little, the detector may not be stable and frequent sensitivity adjustments will be necessary.
    The use of 1N4148 diode in place of 1N4937 is also not recommended (although it is perfectly acceptable). In the initial phase it will not be noticeable, however, with longer detector operation it has little effect on its stability.
    Resistors:
    R1 110
    R2 750
    R3 47K
    R4 47K
    R5 15K
    R6 4K7
    R7 3K3
    R8 68K
    R9 4K7
    R10 68K
    R11 150
    R12 680
    R13 omitted
    R14 omitted
    R15 1k5
    R16 omitted
    R17 470
    R18 680
    R19 10K
    R20 330
    R21 820
    R22 47K
    R23 220
    R24 1K
    R25 1M5
    R26 51K
    R27 51K
    R28 2K2
    R29 2K2
    R30 18K
    R31 8K2
    R32 470K
    R33 68K
    Potentiometers:
    VR1 25K assembly
    VR2 50K Sensitivity
    VR3 1K Volume
    VR4 5K Reset the microammeter pointer
    VR5 4.7k Sensitivity
    capacitors:
    C1 1 uF tantalum 35V
    C2 10 uF tantalum 10V
    C3 10 uF tantalum 10V
    C4 10uF tantalum 25V
    C5 100 uF electrolyte 25V
    C6 1 uF tantalum 10V
    C7 1 uF tantalum 10V
    C8 10 uF tantalum 10V
    C9 1 uF tantalum 10V
    C10 1 uF tantalum 10V
    C11 100 nF 63V
    C12 10nF 100V
    C13 10nF 100V
    C14 10nF 100V
    C15 1nF 100V
    C16 10nF 100V
    C17 10nF 100V
    C18 10 uF tantalum 10V
    C19 220 pF
    C20 10nF 100V
    C21 10nF 100V
    C22 220 pF
    C23 omitted
    C24 omitted
    C25 100 nF 63V
    C26 100 nF 63V
    C27 22 uF electrolyte 63V
    C28 100 nF 63V
    C29 10nF 100V
    C30 220nF 100V
    C31 10 uF tantalum 10V
    C32 omitted
    C33 10uF tantalum 10V
    C34 470uF Electrolyte 10V
    LEDs:
    D1 1N4937 (High Speed diode)
    D2 1N4937 (High Speed diode)
    D3 1N4148 or 1N914
    D4 1N4148 or 1N914
    D5 1N4148 or 1N914
    D6 1N4148 or 1N914
    D7 1N4148 or 1N914
    D8 1N4148 or 1N914
    systems:
    IC1 REG-1117A in the housing "SOT-223") or LM317
    IC2 LT1054-CN8 - 8 pin or ICL7660
    IC3 78L05 T0-92
    IC4 79L05 T0-92
    IC5 555 8 pin (you can use the C-mos version)
    IC6 555 8 pin (you can use the C-mos version)
    IC7 555 8 pin (you can use the C-mos version)
    IC8 555 8 pin (you can use the C-mos version)
    IC9 TL081 or TL071 8 pin
    IC10 TL081 or TL071 8 pin
    IC11 555 8 pin (you can use the C-mos version)
    transistors:
    Q1 IRF840
    Q2 omitted
    Q3 2SK30A or 2N3819 or BF245
    Q4 2N4125 PNP transistor or other good PNP (e.g. BC416 Philips)
    Other:
    M1 microammeter with scale up to 200 microamper - pointer meter (or 100 uA or 50 uA, but then R31 should be changed)
    SPKR loudspeaker or headphones
    LI Poll
    BI battery (accumulator) 12V 1.2 AH. The battery must be above 10.5 V !!! You can use, for example, combined R20 batteries, but a rechargeable battery is recommended
  • #21 5493747
    telemah
    Help: 81
    Rate: 62
    What was suggested by Col. Świętokrzyski is if my eyes are not confused by any changes of Mark Stewart's impulse, in this case probably PULSE2 probably matched by a certain cloud, this structure (with very little cosmetic changes) is described in the DIY section in the subject of "Detector for 50 zlotys" You can let go of curiosity I made it not so long - ranges are very average, and the tuning itself was solved in a quite "painless" way. I have already written where a complete description of the good PI type detector is available. add that impulse detectors are manufactured in Poland to this day
    folded by almost identical documentation - they differ only with printed :D boards :D and that the construction is successful, which is why it was successfully made by several Polish craftsmen.
  • #22 5493953
    patryk-84a
    Help: 40
    Rate: 212
    Ok, I will ask for your plate: patryk-84a (at) o2.pl
    I could design a tile myself, but it's a waste of time if someone else already did :) .
  • #23 5494506
    telemah
    Help: 81
    Rate: 62
    The tile has always been for this project but I modified it significantly to save on the laminate and :D and work :D
    I sent you everything you need. Now I'm making progress in the construction of your :D detector
  • #24 5509484
    swaldek
    Help: 13
    Rate: 63
    Civilization garbage can effectively discourage searches using a pulse detector.
    Telemah is right, it's a great detector, but I'm only suited to a forest where there is not too much garbage, and there is a chance to hit something thicker.
    I know a friend who deals amazing things with this equipment, but everything in XXL size, with scallops and other small items has a problem.
    I will advise you that you can use a tiny probe, you can, but still, to find a 5gr you need to move at a sluggish pace and the range for these 5 grams will be very mikrusny.
    Dynamic detector is created for finding small objects made of non-ferrous metals, and it is not such a difficult art to use this detector.
    And the probe, the fact requires patience and a few hours of work with breaks, but after the construction will only be joy alone, unlike PI with which disappointment and dissatisfaction will come.
    If you have measuring equipment, you do not risk anything, even if something will not work for you, there are many who would like to help.
    I greet and encourage you to more demanding challenges
  • #25 5787440
    bimladentoja
    Rate: 25
    there is such a store and in it the equivalent of jabla but for PLN 47.99 gold, with delivery of 61.09, the dude one also has a pretty walk is like apple, maybe even a bit better.
    Added after 5 [minutes]:
    detector and store Build or Buy Metal Detector: Comparing Allegro's PLN 150 Options, Schemes & Hobby Treasure Hunting
    detector Build or Buy Metal Detector: Comparing Allegro's PLN 150 Options, Schemes & Hobby Treasure Hunting
  • #26 14733237
  • #27 14733486
    pukury
    Help: 244
    Rate: 193
    It was really a long time.
    Templates I had made for winding the coils - the worse is of course the one in
    shaped ?.
    After winding it was immediately covered with resin on the template.
    And shielding.
    I first made coils in the desk room - mistake - the desk has a metal skeleton.
    Only in a large room on the wooden table did it - as it were.
    And the oscilloscope is very useful.
    The detector is ok - fun with coils less pleasant.
    Greetings.
  • #28 14735120
  • #29 14735399
    pukury
    Help: 244
    Rate: 193
    I forgot to write about the monitor - it influenced me.
    Theoretically - a small coil should be moved slightly in relation to ?.
    So what (how to say) in a big coil.
    But - it all depends on the symmetry of the large coil.
    You must look for a place - for this oscilloscope is useful.
    Do you have a break on the screen?
    I made the screen winding a lot of foil from the TVSAT concentrator.
    Not everyone was suitable - I came across such a not alu.
    And then with braided line (the second screen on the concentrate) I wrapped and poured the whole once again with resin.
    A rigid and tight coil is created.
    That's quite a long time and I do not even have a pattern anymore.
    I even made a plate - one - not two.
    But somehow I got bored.
    Greetings.
  • #30 14738247
The discussion revolves around the feasibility of building or buying a metal detector for hobby treasure hunting within a budget of PLN 150. Users share experiences with various detectors, emphasizing the challenges of achieving effective metal discrimination, particularly between precious metals and common scrap. Suggestions include building detectors from schematics, with recommendations for specific models like the All1 and impulse detectors from Lucaslab. Users highlight the importance of having the right components, such as the KP103Ż transistor, and the difficulties in tuning coils for optimal performance. The consensus leans towards building a detector for better customization and performance, although ready-made options are also considered.
TL;DR: Hobbyists report that “construct a decent detector with effective discrimination … is a bit complicated” [Elektroda, telemah, post #5491703]; meanwhile, ready-made pulse units based on decades-old designs still retail for 700 PLN [Elektroda, telemah, post #5491703] DIY or buy? This FAQ compares costs, ranges, and build risks.
Why it matters: First-time treasure hunters can avoid wasting 150 PLN on a toy and instead pick a build or purchase path that fits skill level, tools, and beach-hunting goals.
• Allegro "budget" detectors cost ≈150 PLN but lack metal discrimination [Elektroda, patryk-84a, post #5491332] • Polish PI clones derived from Sandbanks still sell for ≈700 PLN new [Elektroda, telemah, post #5491703] • Used dynamic VLF units trade for 300-400 PLN, e.g., Garrett ACE150 class [Elektroda, telemah, post #5491703] • LucasLab PI build uses only common parts; materials bill ≈60–80 PLN [Elektroda, telemah, post #5492560] • Moving a magnum pick-up coil 0.5 mm can shift balance voltage from 0.15 V to 0.60 V [Elektroda, Anonymous, post #14738247]
Is a 150 PLN Allegro metal detector worth the money?
Not really. Forum users found that cheap MD or Jabel clones under 150 PLN offer no discrimination and limited depth, making them “total lime tree” devices [Elektroda, Świętoszek, #5491441; Anonymous, #5491634]. You will quickly outgrow their performance on litter-filled beaches.
Can I build something better for the same budget?
Yes. The LucasLab PI schematic needs about 60–80 PLN in parts and beats entry-level store units in depth and stability [Elektroda, telemah, post #5492560] You still need an oscilloscope and basic soldering skills, but the return on range per zloty is higher.
Pulse vs. dynamic detectors—what’s the difference for hobby treasure hunting?
Pulse-induction (PI) units excel at depth and ignore saltwater but cannot truly distinguish bottle caps from gold [Elektroda, telemah, post #5491703] Dynamic VLF models such as ALL-1 offer usable discrimination and better response to coin-sized targets, yet need careful coil balancing [Elektroda, swaldek, post #5509484]
How do I replace the rare KP103Ż transistor in older builds?
Swap it with 2N3820 or J176 J-FETs; both were tested in-circuit without range loss [Elektroda, telemah, post #5493040] That substitution removes the chief sourcing roadblock for the classic Sandbanks clone.
Will a pulse detector ignore bottle caps and car chassis?
No. PI lacks true ferrous/non-ferrous differentiation; nearby cars and junk will still trigger a signal [Elektroda, patryk-84a, #5491332; telemah, #5491703]. Only VLF designs with phase-shift discrimination can mute most steel trash.
What search depth can I expect on a coin?
Forum builders reported LucasLab PI finding a 5-g coin at shallow 10 cm unless you slow the sweep speed dramatically [Elektroda, swaldek, post #5509484] Dynamic detectors of similar cost typically hit 12–15 cm on the same target when tuned correctly.
Edge case: why does my detector drift after 30 minutes?
Using LM317 instead of REG1117A in the Pulse2 clone increases voltage sag; sensitivity adjustments become frequent as the 12 V battery drops below 10.5 V [Elektroda, Świętoszek, post #5493593] Upgrade the regulator or use a larger Ah SLA pack.
How do I quickly balance an ALL-1 probe?
  1. Place the loop on a wooden surface, away from monitors and metal furniture.
  2. Connect scope to unbalance test point; adjust small inner coil until trace centers at 0 V.
  3. Add foil shield, secure with epoxy, re-confirm null.
    This three-step sequence usually gets within 0.1 V of perfect balance [Elektroda, pukury, post #14733486]
Any tip to boost small-object sensitivity on a PI build?
Use a smaller diameter search coil (e.g., 15 cm) and lower the pulse repetition rate; builders noted noticeable gain on sub-5 g targets, though large-object depth will drop [Elektroda, swaldek, post #5509484]
