Pinpointer vlf (mini metal detector)
Supermodurator 58948 18
  • A miniature VLF pinpointer metal detector locates small buried metal objects and can also find pipes or rebar before drilling.
  • It uses two coils, a transmitter and a receiver, arranged for minimal coupling; nearby metal disturbs their balance and changes amplitude and phase.
  • The detector runs at 10 kHz, draws about 7 mA from a 9V battery, and fits on an 8.5 cm x 1.7 cm board.
  • Reported ranges are over 5 cm for 1 grosze, 6 cm for 5 gr, and over 20 cm for larger objects, but the probe is difficult to make.
  • Pinpointer vlf (mini metal detector)
    It is an auxiliary miniature metal detector that is used for precision
    the location of small metal objects in the ground. With it, too
    we will determine the location of metal pipes in the wall or reinforcement bars in the ceiling,
    which is important when drilling holes there.
    Low-cost detectors and pinpointers as well as similar devices available for sale,
    whose descriptions and diagrams can be easily found on the Internet, work on a principle
    detuning of the LC circuit due to bringing the metal closer to L (coils - probes).
    The short range and strong susceptibility to the influence of the ground (earth) is their main disadvantage.
    The presented device works on a different principle. It has two coils of which
    one is the transmitter and the other is the receiver. Their mutual arrangement is such that
    that the influence of the transmitting coil on the receiving coil is minimal. Metal object,
    near them will upset this balance, causing them to grow
    amplitude and phase shift of the transmitter signal induced in the coil
    receiver (very simplified).
    This rule allows for much greater ranges as well
    minimizing the impact of soil mineralization on the detector operation.
    Unfortunately, it comes at a cost with the difficulty of making - especially the probe!
    The schematic diagram of the device (attached) is very simple.
    Basic features
    - operating mode - static
    - 10kHz frequency
    - ranges - 1 grosze over 5cm, 5gr- 6cm, for large objects over 20cm
    - does not react to stones containing iron compounds
    - low power consumption (9V - approx. 7mA)
    - a tiny plate (8.5cm x 1.7cm)
    - sound signaling and LED diode (you can add vibrator)
    - the shape of the probe allows you to bury in the ground
    - low cost - made of readily available elements
    Some details in the photos.
    Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector)
    • sch_vll.rar (114.02 KB) You must be logged in to download this attachment.
    Supermodurator
    Supermodurator wrote 118 posts with rating 254, helped 2 times. Been with us since 2005 year.
  • #2 8447418
    zgierzman
    Help: 108
    Rate: 1573
    I like the project, I would do such a miracle myself. What frequency does it work at?
    I was very disappointed with the attachment. You only gave a schematic there that looks like a stripped down ALL1 detector, and there is no description of the probe structure. So for something that does not really bring anything new, you take a point commission in the section where it is not welcome ... But since I have already downloaded this diagram, I would be grateful for the description of the probe, for example on PRIV.
    Since you gave the amplifiers in the smd version, why are the rest of the elements threaded through? I understand that some capacitors must be like that, but the stabilizer, transistors, resistors are not ... And the board could be even smaller ;-)
    Regards
    Zgierzman
    EDIT:
    aha, I found it
    http://www.exploracja.cyberdusk.pl/phpbb2/vie...?t=12519&sid=b4bffed0fe709d4e26f186fc3de9d8f4 " target="_blank" rel="nofollow noopener ugc" class="postlink inline" title="" > http://www.exploracja.cyberdusk.pl/phpbb2/vie...?t=12519&sid=b4bffed0fe709d4e26f186fc3de9d8f4
  • #3 8447434
    Frog_Qmak
    Help: 7
    Rate: 298
    could you give a picture of the probe? Or explain its construction?
    nice design, + for originality, because it's kind of simple, and hardly anyone does it :)
  • #4 8447681
    Duch__
    Help: 33
    Rate: 1598
    The device is made aesthetically. Could a colleague demonstrate a movie with action? Please put the data about the probe, because in the link provided by
    zgierzman wrote:
    I see that you presented the construction of the probe there, but personally I am not going to create another account to download one file.
    Regards. Spirit__
  • #5 8447765
    lekto
    Help: 294
    Rate: 299
    I registered, 2 pages attached.
    • test.zip (54.37 KB) You must be logged in to download this attachment.
  • #6 8448057
    Supermodurator
    Rate: 254
    The probe is the most difficult to do. Necessary for its construction (regulation)
    there is a frequency counter and an oscilloscope.
    During construction, most of the rules we use apply
    by performing a "normal" VLF probe.
    The drawing will dispel any doubts. We wind all the coils
    in the same direction, marking the beginnings (or ends) - in the figure
    dots. During the winding of L1 and L3, we impregnate every 200 turns
    cyanopane. We connect according to the drawing, attach a capacitor to Tx
    100n. We attach the probe to the system, connect the power supply and measure
    frequency. If its value is near 10kHz then we try
    pre-compensate - by moving L2 over L3 we reduce the mileage
    (observing the oscilloscope screen) on Pin1 LM324 to as little as possible
    level. At this stage, the mileage can be kept to a minimum
    distorted (significantly differ in shape from the sinusoid).
    Now we select the Rx capacitor. For this, we temporarily connect
    winding the receiving coil in place of the transmitting coil. We are trying
    get resonance at a frequency slightly higher (approx. 200Hz) than Tx.
    After that, we correct the compensation and immobilize L2
    and cyanopanem tubing.
    After inserting the winding into the housing, pour resin.
    The face of the probe (the end we are looking for) in my case is L1 (Tx),
    although it seems indifferent.
    Then select the elements marked with an asterisk in the diagram
    in the phase shifter so that the detector reacts to all metals,
    a did not detect ferrite and stones containing iron compounds, and the course
    at its exit it was rectangular.
    At this stage, it may be necessary to correct the Rx capacitor,
    therefore it is a good idea to wait until this point with the probe housing.
    The coils do not contain any core, the fiber rod shown in the photos
    glass supports the mechanical construction.
    Point L1 in the assembly drawing is the common ground connection point
    all coils.
    Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector) Pinpointer vlf (mini metal detector)
    Take a close look, what does it have to do with all1? Probably just the same
    solved phase detector - it is the same in many other detectors!
    Everything else is completely different ..
  • #7 8449748
    zgierzman
    Help: 108
    Rate: 1573
    I dug up the ALL1 diagram, took a look and the fact - it seemed to me. I return my honor and sprinkle ashes on my head. My only excuse is that I probably made Alla three years ago, or earlier, and since then I have not returned to the pattern.
    Regards
    Zgierzman
  • #8 8452923
    2lero
    Help: 5
    Rate: 8
    As far as I understood the scheme correctly, the system examines the amplitude and phase with Rx. As for the amplitude, the matter is obvious to me, but why is the phase also tested?
  • #9 8452973
    Supermodurator
    Rate: 254
    Because thanks to this, the detector can distinguish colored metal from iron, you can also
    eliminate the influence of the soil.
    Anyway, you'd better read somewhere about system solutions and types of detectors.
  • #10 8475331
    BOOF
    Someone asked for versions in SMD. Here is the finished project. I post with the consent of the creator of this device.
  • #11 8475535
    FoxTech
    Help: 21
    Rate: 67
    How can I etch the plate on the basis of such a picture?
    After all, this is an overview drawing and not a PCB design.
  • #12 8475639
    BOOF
    I'm sorry, but I did not write that it is etchable. This is made in SprintLayout 5.0. This is the free version of this program and has some limitations. This includes on the fact that I can print a black and white version on a printer and make a pattern for e.g. thermal transfer, but I can only export in the form I did. I have given this for convenience only to potential contractors. Again, I'm so sorry.
  • #13 8475765
    FoxTech
    Help: 21
    Rate: 67
    If you can print to paper, you can also print to PDF, it's very simple: use a free program called Bullzip PDF Printer. The description of the program explains all the confusions:
    Bullzip PDF Printer is a free application that allows you to save documents as PDF files in any program with the option of printing the page.
    Download from:
    http://www.dobreprogramy.pl/Bullzip-PDF-Printer,Program,Windows,12736.html
  • #14 8509547
    mopo11
    I would like to ask for a list of all detector elements with exact parameters.
  • #15 8510953
    Supermodurator
    Rate: 254
    Unfortunately, such a list has never been established - the layout has few elements, easy
    write them down from the schematic diagram.
    Miniature elements, 5mm raster.
    Both integrated circuits are SMD versions (SO14 housing).
    Electrolytic capacitors for a voltage of 6.3V.
    C5, C6 - ceramic.
    kisses
  • #16 8516659
    mopo11
    I am asking for a list of these elements. so far I have been building only kits and I would like to make a pinpointer from scratch. I wrote down the basic elements from the drawing, but I cannot read some of them.
  • #17 8517652
    Supermodurator
    Rate: 254
    There are some who have already performed this detector and such problems
    did not report ..
    Write specifically which markings raise your doubts?
    I adhere to it once again, as long as the device diagram is trivial
    simple, it's not like that anymore and it requires some experience!
    kisses
  • #18 8572544
    MnIrek
    is it possible to insert a full PCB design in PDF
The discussion revolves around a miniature metal detector, specifically a pinpointer that utilizes a unique principle involving two coils—one as a transmitter and the other as a receiver—to locate small metal objects with precision. Users express interest in the device's construction, particularly the probe design and its components. Several participants request additional details, such as frequency specifications, a complete list of elements, and PCB designs. The conversation highlights the challenges in building the probe, including the need for specific tools like a frequency counter and oscilloscope. The importance of phase testing for distinguishing between different types of metals is also noted. Overall, the community seeks to share knowledge and resources to aid in the construction of this device.
TL;DR: A DIY VLF pin-pointer finds a 1-grosz coin at 5 cm and draws only 7 mA from a 9 V cell, and—“phase shift lets us separate colored metals from iron” [Elektroda, Supermodurator, #8447120; #8452973].
Why it matters: Hobbyists get pro-level soil immunity without expensive commercial probes, using parts you can solder at home.
• 10 kHz fixed operating frequency [Elektroda, Supermodurator, post #8447120] • Detects a 1 grosz coin at >5 cm; large objects >20 cm [Elektroda, Supermodurator, post #8447120] • Power draw ≈7 mA from a 9 V battery (≈70 h on 500 mAh cell) [Elektroda, Supermodurator, #8447120; Duracell 9 V datasheet] • Dual-coil Tx/Rx cancels ground effect; no response to iron-rich stones [Elektroda, Supermodurator, post #8447120] • PCB footprint 8.5 × 1.7 cm; main ICs LM324 & CD4011 in SO-14 [Elektroda, Supermodurator, post #8447120]
How is this pin-pointer different from simple LC detune metal detectors?
Classic hobby detectors shift an LC resonant frequency, giving short range and strong ground interference. This design uses separate transmit (Tx) and receive (Rx) coils nulled for minimal coupling; metal upsets the amplitude and phase balance, extending range and cutting soil noise [Elektroda, Supermodurator, post #8447120]
What exact parts do I need?
Core parts: 1× LM324-SMD, 1× CD4011-SMD, BC847 or similar NPN, 5 mm resistors, ceramic C5 = 10 nF, C6 = 100 nF, electrolytics 6.3 V, Rx capacitor tuned ≈100–220 nF, Tx capacitor 100 nF, 9 V battery clip, buzzer/LED, three air-core coils wound per probe drawing [Elektroda, Supermodurator, post #8510953]
How do I wind and tune the three-coil probe?
  1. Wind L1, L2, L3 in the same direction; mark starts with dots [Elektroda, Supermodurator, post #8448057]
  2. Impregnate every 200 turns with cyanoacrylate.
  3. Slide L2 over L3 while watching Pin 1 of LM324; minimise residual signal, then lock with glue.
  4. Swap Rx and Tx leads, adjust Rx capacitor for resonance 200 Hz above 10 kHz.
  5. Final-fit, pot with epoxy, then re-check compensation [Elektroda, Supermodurator, post #8448057]
Can it discriminate between ferrous and non-ferrous targets?
Yes. The phase detector lets the circuit ignore ferrite stones yet alert on coloured metals; “phase shift lets us separate metals” [Elektroda, Supermodurator, post #8452973]
Is a full SMD version available?
Forum user BOOF posted an SMD board layout in Sprint-Layout format with the author’s consent [Elektroda, BOOF, post #8475331]
How can I print the PCB if I only have the Sprint-Layout viewer?
Install Bullzip PDF Printer, choose Print in Sprint-Layout, select Bullzip, and export a mirrored black-layer PDF ready for toner transfer [Elektroda, FoxTech, post #8475765]
Why does the circuit sample both amplitude and phase?
Amplitude shows proximity; phase shift reveals metal type and cancels soil mineralisation. Without phase data you’d get many false positives in magnetic ground [Elektroda, 2lero, #8452923; Supermodurator, #8452973].
What battery life should I expect in the field?
At 7 mA, a 500 mAh alkaline 9 V cell lasts ≈70 hours (500 mAh ÷ 7 mA) [Elektroda, Supermodurator, #8447120; Duracell 9 V datasheet].
Common build mistakes and how to avoid them?
• Reversing coil leads—null never happens. • Skipping oscilloscope—result is false beeps. • Using ferrite cores—range collapses. • Forgetting to retune after potting—drift causes silent failure [Elektroda, Supermodurator, post #8448057]
How do I adjust the phase-shifter so stones stay silent?
Change the starred resistor-capacitor pairs until the output at LM324 pin 8 is a clean rectangle and ferrite stones give no swing; minor Rx capacitor tweaks may follow [Elektroda, Supermodurator, post #8448057]
What material should I use for the probe housing and support rod?
Use a glass-fiber (FRP) rod for mechanical strength and zero magnetic loss, then pot coils in epoxy resin to seal them [Elektroda, Supermodurator, post #8448057]
Edge case: will highly mineralised soil still fool the detector?
Mineralised soil shows weak amplitude change but near-zero phase shift, so the balanced coils reject it. However, if phase null drifts more than 10° the unit may chirp falsely [Elektroda, Supermodurator, post #8447120]
