Understanding AC Voltage: Alternating Current in Power Grid Network
czyt 4638 6
  • #1 16465098
    czyt
    Help: 5
    Rate: 21
    https://www.elektroda.pl/rtvforum/topic379502.html in this closed topic, the nomenclature "variable" is used for the voltage of the power grid - this is incorrect.
    There is alternating voltage in the network. Variable is different from variable in that it crosses zero, and the mean value of the current is also 0.
    There is voltage in the network ALTERNATIVE
  • #2 16465121
    rb401
    Help: 750
    Rate: 984
    Ok. But every alternating voltage is also alternating voltage, because the term alternating voltage is a more general category and alternating voltage is its special case.
    So there is no error.
    View in Wikipedia.
  • #3 16465134
    nuszek
    Level 30  
    Help: 123
    Rate: 389
    And when they measure the voltage in the network, I have 230 V, the second time I have 237 V, then 233 V, do I have alternating or variable voltage?
    The term alternating voltage in our reality is deeply entrenched, and alternating voltage is just a special case of alternating voltage.
  • #4 16465142
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    You see, telephony uses an alternating voltage that produces a carbon microphone.
    In the anti-local system of an old telephone from the times of the Polish People's Republic, a transformer is used, and here, a curiosity, in order for the speech signal to pass through the transformer, it changes from alternating voltage passing through the transformer to alternating voltage, although it is not a sine wave.
    Anyway, the telephone line is powered by direct voltage, the speech signal is transmitted by alternating voltage, and the current that triggers the bell in the telephone is alternating.
    Greetings.
  • #5 16466858
    CYRUS2
    Help: 1241
    Rate: 3535
    Buddy, stop being "overzealous".
    Electricians use "slang".
    You see a problem with that.
    Do you know what earth potential means?
  • #6 16467718
    czyt
    Help: 5
    Rate: 21
    I see the "enemies" themselves almost: DD.
    To the substantive entry: yes, alternating, is a narrower definition of alternating current - technical forum. In order not to shred your tongue, it is worth knowing Forum users to use a strict term. The more so because it often occurs and is used incorrectly.
    Generalizing what new, more precise words are for, we can stay on the level of uhm, ekche and mmmcha as technical terms. Only who will understand and guess. Young people, the future generation of electricians and electronics learn HERE.
  • #7 16467745
The discussion centers around the terminology used to describe voltage in power grid networks, specifically the distinction between "alternating voltage" and "variable voltage." Participants argue that alternating voltage is a specific type of alternating current, and the term "variable" is misleading as it implies a different concept. The conversation also touches on practical examples, such as the use of alternating voltage in telephony and the importance of precise terminology for the education of future electricians. Some participants express frustration with the misuse of terms in the field, emphasizing the need for clarity in technical discussions.
