Analog Meters: Formula for Reading Values from Devices (Guide & Examples)
Pabloso19 55444 4
  • #1 5624778
    Pabloso19
    Rate: 9
    Could someone give me a formula for reading the value from an analog meter? Regards
  • #2 5624842
    Lutek49
    Level 36  
    Help: 440
    Rate: 407
    x - value read from the scale
    d - the maximum value of the scale
    z - measuring range
    w - value
    w = zx / d
  • #3 5624854
    Pabloso19
    Rate: 9
    Thanks for helping me with that :)
  • #4 5624857
    fuutro
    Help: 1450
    Rate: 837
    Ie? You do not know how to read the indication of such a meter? It is quite simple. The whole fun probably comes down to the c meter constants. It is calculated simply, namely for the ammeter and voltmeter you read the set range (e.g. 1 or 3A or 100 or 300V) and the number of divisions on the scale, e.g. 100. In the first case, the ammeter constant c = 1/100 or 3/100 which gives 1 / 100A for each indicated division on the scale or 3 / 100A / div, similarly voltmeter -> 1V / div or 3V / div. If the voltmeter with cv = 3 shows on the scale 20V, the voltage is actually 60V. With a wattmeter it is only so much more interesting that the current and voltage settings are taken into account at the same time. For example, if the wattmeter is set to 100V and 10A and there are 100 divisions on the scale, then the wattmeter constant cw is (U * I) / number of divisions, i.e. (100 * 10) / 100 which gives cw = 10, so if the wattmeter shows 15 plots, in fact, the power is 150W.
  • #5 5627017
    wiśniowy18
    Help: 238
    Rate: 103
    I recommend the "Electrical and electronic measurement" literature, there you will learn everything. To what my colleagues wrote above, you must add the value of the relative and absolute error blah blah blah ........ everything is described in this book, which is necessary in the library of every electrician and electronics.
    Greetings
