Effective Diesel Fuel Stain Removal: Clean Clothes with Denatured Alcohol or Solvent Options
wowka 206571 7
  • #1 5627320
    wowka
    Help: 49
    Rate: 247
    Recently, I have drenched myself a bit with diesel oil, i.e. a sweatshirt and pants. The clothes went straight to a bowl of water and powder, and then went to the washing machine. Today it is dry, but the stains are left, they are greasy and stink with diesel fuel, so water and powder could not dissolve it. Now I'm wondering how to get rid of it, I think to wash it with denatured alcohol, or some solvent, but I'm afraid that it will discolor the fabric. Anyone have a proven way to get rid of these stains?
  • #2 5627349
    arekadiusz
    Help: 29
    Rate: 84
    Wash dirty places in health and safety paste and work again, you can also try spraying with a stain remover for greasy stains for colored fabrics, they do not discolor (apparently), my wife says that she does.
    the stain remover is at your risk!
  • #3 5627415
  • #4 5629349
    arekadiusz
    Help: 29
    Rate: 84
    Stain removers (the good ones) soften the substances, stain them and bring them out of the inside of the fibers to the surface and then they can be easily rinsed with water with detergent (it comes with washing), you need to know what to choose.
    that is why people have worked for years on such stain removers so that they work and save time, the good ones really work also depends on the type of stain on some stain remover will help on others something else
  • #5 5630778
    MacGyver.
    Help: 23
    Rate: 29
    Once I accidentally sat on a wooden bench, but I did not notice that it released a lot of resin ... Well, I soaked the pants in water and then polished them with paint solvent, washed with a larger dose of powder and no trace or smell after what was.
    If the sweatshirt has prints, a problem will arise - a solvent can take care of them :(
    As for stain removers, I advise you to look for Voight Brudpur - hard to find, costs a little but no whip that will not let go.
  • #6 5630798
    wojtek60
    Help: 54
    Rate: 107
    Clothes (working) soiled with grease, etc ... feather .. but first, put all this into a large plastic bag and half a liter of extraction gas there. After an hour to the washing machine ... and it comes out clean without stains .. there is a smell of gasoline .. but also passes .
  • #7 5632055
    wowka
    Help: 49
    Rate: 247
    In that case, first I will check the extraction gasoline method. If he does not let go, I will still worry
  • #8 13363210
    dzikiqba
    Rate: 10
    Old topic, but recently I poured pus myself on nice pants.
    Washing three times, including washing at 90 degrees, did not bring any effect, i.e. there were no stains but the smell remained.
    I read from the English forum that oil must be treated with oil.
    For washing instead of the powder, I added 1/2 bottle of olive (they wrote about baby oil, I used my wife for hair - she will kill me).
    After the washing machine drained the water for the first time, I set the program all over again and gave the usual powder and liquid.
    Effect: no smell at all :) !!
Effective methods for removing diesel fuel stains from clothing include using denatured alcohol, extraction gasoline, and specialized stain removers. Users recommend applying extraction gasoline directly to the stained area, allowing it to penetrate, and then washing the fabric. Stain removers designed for greasy stains can also be effective, provided they are suitable for colored fabrics. Some users suggest using oil-based products, such as olive oil or baby oil, during the wash cycle to neutralize odors. Caution is advised when using solvents, as they may damage printed fabrics.
