How to Remove Black Stains from Washing Machine Door Seal (Apron)?
W.Wojtek 46960 8
  • #1 10011248
    W.Wojtek
    Phones specialist
    Help: 245
    Rate: 430
    Banal.
    The apron in the washing machine turned black, stained. None of the available means did anything.
    It does not bother but looks terrible.
    Is there any secret way besides replacing it with a new one ??
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3387
    There isn't.
  • #4 10013494
    W.Wojtek
    Phones specialist
    Help: 245
    Rate: 430
    I tried with chlorine preparations but without soaking .. We will see ..
    Jowisz
    Rate: 9
    I dip it in diluted with water 1: 1.
    First of all, because there is more fluid in the machine and it is easier to dip the apron into it. Secondly, because I usually soak overnight, and a few soaked in too strong a solution have already shrunk to me ;)
    Maybe a flaw of rubber, but the apron is practically unusable (although clean).
  • #6 10013967
    Jowisz
    Rate: 9
    With a lot of processing (in thousands) of equipment brought from Germany, I won't argue how it works, but it's probably not about water.
    Maybe some of the aprons had been lying for too long, but they were definitely "felted" after taking them out and could not be stretched.
    I think your way is faster, but I don't have the head to guard my apron like eggs (lest it come out hard) ;) hence the suggestion.
  • #8 10061083
    Polarnik1
    Help: 16
    Rate: 51
    These stains can come from fungi - mold, I read somewhere on dishwashers that these stains on rubber elements come from them. Industry specifics recommend replacing them with new ones.
  • #9 11301668
    W.Wojtek
    Phones specialist
    Help: 245
    Rate: 430
    Well, I found a way ...
    I found such a "Savo" trickle of a characteristic flash.
    No Genie from this chlorine-based flask after 3 sprays and wiping with a cloth led to almost novelty. In some places there are slightly grayish stains, but it is much better. Some water went to rinse but the smell was gone.
    Well, without undressing!
The discussion revolves around cleaning a stained apron that turned black after being washed in a washing machine. Users suggest various methods for cleaning, including soaking the apron in a chlorine-based detergent like ACE for several hours, which reportedly restores its appearance. Some users mention trying diluted chlorine solutions and express concerns about potential shrinkage of the apron material. One user found success using a product called "Savo," which significantly improved the apron’s condition with minimal effort. There are also mentions of mold-related stains and the recommendation to replace the apron if cleaning fails.
