Copper Recovery from Cables: Profitability, Auction Link, YKY 5x16 Cable, 1mb=1kg, Copper Weight
toom16 113820 33
Is it profitable to buy YKY 5x16 cable, strip it, and sell the recovered copper scrap, and how much copper would be in one meter?
No, the thread’s answer is that stripping this cable is not profitable: at about PLN 21.90 per meter, you would end up with only about 0.7 kg of copper after stripping, so the copper would need to be worth around PLN 30 per kg just to make it worthwhile [#5717465] Another reply says that even with easier methods than manually peeling the cable, there still won’t be profit and you may even have to pay extra for the operation [#5717549] If you want copper for scrap, the better sources mentioned are old transformers, motors, and especially starter electromagnets, which are easier to dismantle and contain relatively more copper [#5717566][#5717633]
  • #1 5717419
    toom16
    Rate: 21
    is it profitable to recover copper from the cable as in this auction
    http://allegro.pl/item471500309_kabel_yky_5x16_produk_yky_5x16_hurtoiwnia.html
    According to the seller, 1mb = 1kg
    and here's the second question, how much would the copper itself weigh?
    Moderated By Faces:
    Regulations point 10.11
  • #2 5717424
    lowbird
    Help: 36
    Rate: 45
    I understand that you would like to buy a cable, peel it and sell it for scrap?
  • #3 5717430
    toom16
    Rate: 21
    So
  • #4 5717449
  • #5 5717459
    toom16
    Rate: 21
    well, the price is for 1mb I wrote above
  • #6 5717465
  • #7 5717475
    lowbird
    Help: 36
    Rate: 45
    If you find a buyer for copper who will give you more than PLN 30 per kilo, of course it pays off if you have nothing to do at home but pluck cables.
  • #8 5717477
    toom16
    Rate: 21
    Oh well, it's a pity, but about 0.7 kg I had?
  • #9 5717535
  • #10 5717549
  • #11 5717552
    toom16
    Rate: 21
    where else can you get copper for sale?
  • #12 5717566
  • #13 5717582
  • #14 5717591
    toom16
    Rate: 21
    Like a transformer?
  • #15 5717633
  • #16 5717641
  • #17 5717663
    toom16
    Rate: 21
    then you say that there is a lot of copper in the electromagnets, then it will poke
  • #18 5718666
    wamp
    Help: 20
    Rate: 43
    Just don't cut traction because I'm going on a trip tomorrow and I don't want to be late :D
  • #19 5721606
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    The traction is aluminum ;)
  • #20 5721832
    DJ MHz
    Help: 40
    Rate: 254
    Motor windings (from refrigerator compressors, etc.). You just have to play with the grinder a bit, and then pull out the pieces with pliers :) .
  • #21 5721924
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    transpacyfic93 wrote:
    I doubt that the profit from these cables will compensate you for the effort you put into stripping this wire of insulation... Really. I've been putting my strength on just such a cable lately. Average enjoyment...
    You can get used to picking at cables, find a technique and, above all, a place for this work ... Oh, and you need thick gloves and a knife.
  • #22 5722188
    Futrzaczek
    Help: 538
    Rate: 522
    But why?
    I put the cable scraps in the oven, mix it with some balls of paper and ignite it. The boiler (120l) is heated up and even faster. The fire is also good. I tried to pluck cables once, but it's not on my nerves...
    F-TECH Michał Kurzela
    Zacisze 20B, Serock, 05-140 | Company Website: https://elektronika.top/
  • #23 5722201
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    1. they pay less for burnt copper
    2. stench and smoke, you can do it in some reeds or in the countryside, but at home with medium-dense buildings there is no point
    3. this plucking is not so bad, you will make 20 meters of cable, swear and get used to it, you can fly whole spools ;)
  • #24 5723386
    Futrzaczek
    Help: 538
    Rate: 522
    First time I hear of something like this. They only segregate into small (cables, cuttings, etc.) and coarse (tubes, saucepans, etc.)
    It depends on your relations with your neighbors :)
    Perfume once in a while won't hurt anyone. Unless someone is processing it in industrial quantities...
    The problem begins when you have two bags of different scraps and trimmings of different lengths. There are better occasions to curse yourself ;)
  • #25 5723404
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    Then it's actually better to burn...
  • #26 5736098
    Łukasz-O
    Admin of electroenergetics
    Help: 654
    Rate: 4292
    Are you sure mate? :D
  • #27 5736138
    DJ Max
    Level 30  
    Help: 22
    Rate: 136
    So far I have been, but I have never had direct contact with her ;)
    If it's copper, I'm honestly not surprised that it can disappear without a trace ;)
  • #28 5736228
    Łukasz-O
    Help: 654
    Rate: 4292
    Not only the network can disappear without a trace, but also the one who wants to steal it ;)
  • #29 12809030
    pawello54
    hello - I hope this is in the right topic. How much copper can be contained in one meter of cable marked PFSP 1KV 3x120/70mm2. I have the opportunity to buy the above for PLN 30 per meter and would it be worth it to just strip it down to copper.
  • #30 12812287
    c4r0
    Level 36  
    Help: 155
    Rate: 565
    Good topic but too old... You should start a new one. In the cable designation you have the cross-section (this is the cross-section of the conductor). Any junior high school student should be able to count in a minute exactly how much copper will be in a meter of this cable.
The discussion revolves around the profitability of recovering copper from YKY 5x16 cables, as referenced in an auction link. Participants analyze the cost of the cable, which is priced at PLN 21.90 per meter, and estimate that stripping the insulation yields approximately 0.7 kg of copper per meter. For profitability, the selling price of copper would need to exceed PLN 30 per kg. Various methods of copper recovery are discussed, including stripping cables and dismantling old transformers or motors, with some participants expressing skepticism about the effort versus profit ratio. The conversation also touches on alternative sources of copper and the challenges associated with the recovery process.
TL;DR: Stripping a YKY 5×16 cable yields about 0.7 kg of clean copper per metre (≈70 % metal) [Elektroda, Anonymous, post #5717465]; "it would have to cost around PLN 30 / kg to make it worthwhile" [Elektroda, Anonymous, post #5717465]
• YKY 5×16 mass: 1 kg / m, copper ≈0.7 kg (insulation ≈30 %) [Elektroda, Anonymous, post #5717465] • PFSP 3×120/70 mm² contains ≈4 kg copper per metre [Elektroda, c4r0, post #12813894] • Bare bright copper scrap price in Poland: PLN 22–29 /kg ("Polish Scrap Price List 2023"). • Burnt copper is typically discounted by ~10 % [Elektroda, DJ Max, post #5722201] • Copper density: 8.96 g/cm³ (MatWeb).
How much copper is inside one metre of YKY 5×16 cable?
The cable has five conductors, each 16 mm². Total cross-section = 80 mm². Volume per metre = 80 cm³. Multiplying by copper density 8.96 g/cm³ gives ≈716 g, rounded to 0.7 kg [Elektroda, Anonymous, #5717465; MatWeb].
Is buying YKY 5×16 at PLN 21.90 / m profitable for scrap?
No. Copper value: 0.7 kg × PLN 25 ≈ PLN 17.5. Purchase cost: PLN 21.9. You lose about PLN 4.4 per metre before labour [Elektroda, Anonymous, post #5717465]
What percentage of a power-cable’s weight is insulation?
Typical power cables show 25–35 % insulation by mass. YKY 5×16 sits near the high end with about 30 % plastic sheath [Elektroda, Anonymous, post #5717465]
How much copper is in PFSP 1 kV 3×120/70 mm²?
Designation means 3 × 120 mm² phase plus 1 × 70 mm² neutral → 430 mm² total. Volume per metre = 430 cm³. Mass = 430 cm³ × 8.96 g/cm³ ≈ 3.85 kg copper per metre [Elektroda, c4r0, #12813894; MatWeb].
Where can I harvest copper more easily than from cables?
Starter electromagnets and refrigerator-compressor motors contain larger, loosely wound coils that pull out fast [Elektroda, Anonymous, #5717633; DJ MHz, #5721832]. A single starter yields up to 0.4 kg copper—four times a metre of YKY 5×16.
Do all scrap yards pay less for burnt copper?
Most do; some smaller yards only separate ‘fine’ and ‘coarse’ scrap [Elektroda, Futrzaczek, post #5723386] Call ahead—policies vary and surprise downgrades erase profit.
How can I strip thick cable safely at home?
  1. Score the outer sheath length-wise with a hooked knife.
  2. Twist to open, pull conductors free with pliers.
  3. Feed each copper core through a handheld stripper to remove individual insulation. Wear cut-resistant gloves and eye protection [Elektroda, DJ Max, post #5721924]
What tools speed up cable stripping?
Budget scrappers use a bench-mount rotary stripper (~PLN 300), or a drill-powered wire-stripper jig. Larger outfits deploy automatic blade machines from brands like Bluerock or StripMeister that process up to 30 m/min.
Are there environmental or legal risks in burning cable insulation?
Yes. Open-air burning emits dioxins and can incur fines under Polish waste regulations (Ustawa o odpadach 2012). Neighbours may file nuisance complaints, halting your operation and negating gains.
What if the cable turns out to be aluminium?
Traction lines are often aluminium, not copper [Elektroda, DJ Max, post #5721606] Aluminium scrap fetches only PLN 4–7 /kg, slashing revenue by ~75 %. Use a magnet and colour check before buying.
How do I estimate copper weight in any multi-core cable?
Multiply total conductor cross-section (mm²) by 0.00896 to get kg per metre. Example: 50 mm² total × 0.00896 = 0.448 kg. Keep a pocket chart for quick market checks.
