Seeking Printer Recommendations: High-Quality, Durable Print on 300g/m2 Paper, A4/A3 Size
Centaurus 10542 10
Can I get a printer that prints well on paper up to 300 g/m², with high-quality, durable output that resists light moisture, and also prints very opaque black on transparent film?
An old HP LaserJet 2100 with a JetDirect card and a straight-through paper path was reported to print on foil and on thicker media, but the thread also says standard laser printers usually do not make transparencies black enough for UV work [#16368511][#16368906] For truly high-opacity transparencies, the replies recommend printing on film at a print shop instead of relying on a home laser printer [#16368906] One participant was offered an Epson SureColor SC-Pxxxx pigment printer as a possible alternative, but noted the price starts around 4500 PLN [#16393383] Another workaround mentioned was printing the same transparency three times and aligning the prints, though this was presented as an informal tip rather than a proven solution [#16368616]
  • #1 16368091
    Centaurus
    Hello! I am looking for a printer (laser or ink will be better?) That I can print on paper up to 300g / m2 thick. Most important: print quality and durability - resistance to light moisture. It is enough for A4 (although it may be A3, but it will definitely be more expensive). Can you recommend me something? Until now, the tested laser printers did not print in some places or the print was detached from the paper after some time, and the inkjet ones - smudged under the influence of e.g. sweaty hands. These are disqualifying faults for my needs. And one more question: maybe you know a printer that will allow you to print in black and white on a transparent film or calce- condition: black opacity comparable to a Postscript printer?
  • #2 16368511
    scotch
    Help: 78
    Rate: 148
    I have an old woman HP LaserJet 2100 plus JetDirect. Old heavy equipment. Normally an S or C-shaped paper path (from the bypass tray). After unfolding both trays, the paper path is straight. I printed on foil and opaque enabling tiles to be made by exposure
  • #3 16368558
    Centaurus
    Hmmm, I've tried different lasers a bit - but black isn't black here - just gray. Unfortunately - it transmits light. I pass a flash of UV fluorescent through the foil with the pattern (transparent pattern on a black background). Unfortunately - so far every laser printer has been transmitting light - not only exposing the pattern, but also the background. So practically: the whole. I also tried to cover the bases with acetone with such a film - in fact, the blackness is more black, but it is not black enough. I haven't tried this printer yet - is black really comparable (light transmission) to black of photographic film?
  • #4 16368616
    sanfran
    Help: 963
    Rate: 3004
    A friend had a similar problem with transparencies and printed in triplicate on a regular laser, and then combined the prints together and exposed them all.
  • #5 16368648
    yogi009
    Help: 848
    Rate: 2655
    And it is interesting what paths could have exposed it ... The film also has its thickness, the light on the border of two centers naturally breaks down. Now imagine several such layers.
  • #6 16368787
    sanfran
    Help: 963
    Rate: 3004
    I do not know, we talked with a friend about the degree of print density and he told me that. I don't know anything about it and I didn't do it. I wrote because it may be useful to someone; and whether the author of the topic will check it or not - not my business.
  • #7 16368906
    yogi009
    Help: 848
    Rate: 2655
    The moment you want to run thin paths (say 8-12 mils), such phenomena unfortunately destroy the effect of our work. In general, lasers do not blacken the paper or film to such an extent that UV light does not over-print this print. Therefore, if we want to achieve maximum quality effects, we recommend printing on foil from a printing plant. You can somehow combine with printing on foil and swelling toner in acetone vapors, but it will not be in full contrast all the time.
  • #8 16393383
    Centaurus
    Yes you are right. The problem is that it costs me a lot. Besides - I often have a production order, I make a print file - and the printing company tells me that if I want to, I have to pay for the whole film. I was offered a pigment printer from the SureColor SC-Pxxxx series (Epson). Well, but this price is not impressive (from 4500 PLN).
  • #9 16393429
    yogi009
    Help: 848
    Rate: 2655
    Analyze the possibility of ordering prototype plates in the tile shop, maybe they will come out cheaper.
  • #10 16394332
    Centaurus
    Well, but it's not about tiles :-) . These are engraved items and more. Something like metalwork.
  • #11 16394657
    yogi009
    Help: 848
    Rate: 2655
    Well, this tile shop may not swallow :-)
The discussion revolves around finding a printer capable of producing high-quality prints on 300g/m2 paper, with a focus on durability and resistance to light moisture. Users share experiences with various laser and inkjet printers, noting issues such as inadequate black density and smudging. One user mentions the HP LaserJet 2100 as an older model that can print on foil but questions its black opacity compared to photographic film. Another suggests using a pigment printer from the Epson SureColor SC-Pxxxx series, although the cost is a concern. The conversation also touches on alternative printing methods, such as combining multiple prints for better density and exploring options for prototype plates in tile shops.
