Modify Excel File Creation Date on Windows XP: Update Date Circled in Red Square
K 83818 13
How can I change the creation date shown in an Excel file’s Summary/Advanced properties on Windows XP?
You usually cannot change that Summary-tab date with normal file-date tools, because it is stored in the Excel file’s metadata, not just as the filesystem timestamps shown in the General tab [#5927229][#5927235] The practical workaround suggested in the thread is to create a new file and copy the data from the old workbook into it [#5927235] If you need the new file to inherit the desired creation date, set the system date to the target date immediately before creating it [#5927755] Tools like FileDate Changer can change the General-tab Created/Modified/Accessed dates, but not the Excel metadata date the OP was after [#5927158][#5927128]
  • Seeking way to change Excel creation date in Windows XP
    #1 5927006
    K
    Rate: 11
    Today I probably have a trivial problem for some - as in the topic.
    The point is that in win XP I need to change the creation date of the excel file, the attached picture shows the problem.
    I know how to change the date from the first picture, but I can't change the date circled in the red square in the picture next to it. I have searched on various forums and unfortunately did not find an answer. It is all about this date, if I fail to change it, it will give me a lot of unnecessary work.
    I am asking you for help.
    Thanks in advance
    k
  • #2 5927018
    Afcht
    Level 30  
    Help: 32
    Rate: 82
    With EXIFeditor.
  • #3 5927036
    K
    Rate: 11
    Thank you very much :) I'm already looking for a program and go to work. But from what I see, it is an EXIF photo editing program, can it cope with * xls files?
    Unfortunately, it's just a jpeg program and I need to change the EXCELA file creation date => * xls
  • #4 5927057
    Afcht
    Level 30  
    Help: 32
    Rate: 82
    Try it, there are quite a few programs to change these tags.
  • Distinguishing Summary-tab date from file timestamps
    #7 5927128
    K
    Rate: 11
    Well, I already have a few programs, but they all change only the dates from the first picture and none of them changes the field marked by me in red, which appears after we do the following:
    1 click on the Excel file with the right mouse button and give properties,
    2 we will enter the "Summary" tab
    3 click on the "Advanced >>" button
    4 and in the 2nd line from the bottom we have something like this (my case to be exact): "Created on 10/26 2005 22:24"
    On the other hand, in the "general" tab, there are three dates: creation, modification and last use. These are the dates that I can change with these different programs. I can't change the file creation date, which is just in the summary tab.
    Try to pay attention to it, create an excel file and change the dates from the "general" tab using the programs you recommended to me, then you will see that the dates in the summary tab cannot be changed using these programs.
    Which does not change the fact that I badly need to change the file creation date from the "summary" tab and I hope it is possible because so far I have been looking for a dozen hours and I have not found an answer ...
    I am waiting for your further suggestions.
  • #8 5927158
    Adam770
    Help: 41
    Rate: 13
    The one I linked to above changes all three dates: Created, Last Modified, and Last Accessed :)
  • Changing Excel Summary creation date from 2005 to 2008
    #9 5927171
    K
    Rate: 11
    I know these 3 I can change but read carefully what I wrote and look at the picture and note that the creation date in "general" is 2008, and the creation date in "summary" is 2005. And I want to change it from 2005 to 2008. A I can only change the dates from the "general" tab, and I can't change the second date from the second picture marked with a red frame and I have to do it otherwise I will be screwed up ...
  • #10 5927214
    wada
    Help: 168
    Rate: 732
    and you cannot create a new file, be it in Excel or OpenOffis, and import data from the old file.
    Elefant
    Wagonowa 34, Wrocław, 52-231 | Company Website: literyzmetalu.pl
  • NTFS alternate streams store SummaryInformation metadata
    #11 5927229
    Adam770
    Help: 41
    Rate: 13
    Support for multiple data streams was introduced in Windows NT for Mac compatibility. For a long time, they had no other use in the system. Starting from Windows 2000, the Summary tab is present in the file properties window, where we can save the author, title, etc. This information is saved in the SummaryInformation stream.
    Thus, multiple data streams is a feature of the NTFS file system. Therefore, it is enough to copy this file to a disk with the FAT file system (e.g. a floppy disk) to lose this information.
    Unfortunately, I can not check it at the moment, because the computer from which I am writing has disks in the FAT file system :(
    There is no information on the creation date of the file in my properties / summary / advanced tab. There are only these three dates in the properties / general tab.
  • #12 5927235
    elektryk
    Help: 439
    Rate: 241
    It seems to me that this creation date is not saved in the file system but in the excel file content. There is information about editing time, who edited when and so on. The best thing to do is to make a new file and paste the contents of the old one into it.
  • #13 5927755
    skierniak
    Help: 14
    Just before creating this new one, change the system date to the one you need.
  • #14 5929168
    K
    Rate: 11
    So I did ... I made a new file and transferred the data :) . By the way, thanks for all the help. I consider the topic closed. By the way -> Happy New Year's Eve to all of you :D
The discussion revolves around the challenge of modifying the creation date of an Excel file on Windows XP, specifically the date displayed in the "Summary" tab, which differs from the "General" tab. The user seeks a solution to change this date, as existing programs only allow modification of the dates in the "General" tab. Various suggestions are provided, including using programs like NirSoft's FileDateChg and Ninotech Date Edit, but the user finds these ineffective for the specific date in question. Ultimately, a workaround is proposed: creating a new Excel file and transferring the data from the old file, while adjusting the system date to the desired creation date before doing so. The user successfully implements this solution and concludes the discussion.
