Polar Dafne PDH 585 Washer: Smoke Emerging from Drum Post-Spinning Cycle
dagor006 36193 20
Why did smoke come out of the drum after the washing machine finished spinning, and what should I check or replace?
The smoke was most likely caused by a damaged heater rubbing against the drum because the drum bearings and seal were worn, not by the belt. Check the heater for proper resistance (about 26 Ω) and for leakage to ground, and inspect the drum bearings by removing the belt and turning the drum by hand; any noise or roughness points to bearing failure [#5954669][#5957794] If the heater shows scuff marks or the drum has play, replace the bearings and the simmering/seal, because the heater can rub through and short when the machine runs without water [#5952577][#5957589] In the reported case, water was leaking along the shaft, confirming the seal/bearing problem rather than the heater itself [#5957589] After replacing the bearings and simmerings, the problem was solved; a bearing puller was needed to remove the crosshead [#5979379]
  • #1 5952810
    dagor006
    Rate: 15
    After finishing the spinning program, smoke started coming out of the drum. I thought it was the belt, I took off the back and top but there I could not smell any burning. Smoke came out only from inside the drum. The washing machine did not throw the fuses. Please help. What could have happened
    Greetings.
    staszekf
    Help: 204
    Rate: 498
    To check clean the pressure system as well as the heater, since it may have already burned out. Greetings.
  • #3 5952839
    dagor006
    Rate: 15
    Pressure system ie hydrostat? I looked at it organoleptically, but I can't feel anything. And how to check the heater?
    marqs-60
    Help: 28
    Rate: 136
    Hello.KOL.staszekf did not write about the hydrostat as such.To clean from it down ie the hose and to the tank itself-primarily the plastic element (,,pipe") (exactly),the heater (without a meter) is the easiest way to set the program with heating and wait.
  • #5 5954322
    nares
    Home appliances specialist
    Help: 1515
    Rate: 3387
    And you don't happen to have an additional relay installed on the heater supply?
  • #6 5954626
    dagor006
    Rate: 15
    Standard washing machine, never repaired.
  • #7 5954669
    nares
    Help: 1515
    Rate: 3387
    Check the heater, it is supposed to be about 26Ω. Perhaps it is burned out and short-circuiting to the housing begins to heat on a shortened circuit. Hydrostat has nothing to do here, if it smokes on spinning. If you have a differential switch in the installation, then do not take my suggestions into account.
  • #8 5954673
    axxx
    Help: 376
    Rate: 1720
    Maybe there is a leak from the tank to the engine or pump.
    Worth checking.
  • #9 5955109
    dagor006
    Rate: 15
    I checked the wire and pipe from the hydrostat - clean. I removed the heater because I had the impression that it somehow heats less well. The stained but working one has the right resestance. I am further in a quandary.
  • #10 5955321
    staszekf
    Help: 204
    Rate: 498
    Check for leakage (short circuit) to ground.Greetings.
  • #11 5956528
    Paw_el
    Help: 592
    Rate: 1551
    dagor006 wrote:
    After the spinning program was over, smoke started coming out of the drum. I thought it was the belt, I took off the back and the top but there was no smell of burning. Smoke came out only from inside the drum. The washing machine did not throw the fuses. Please help. What could have happened
    Greetings
    As spinning took place? is not the hydrostat blocked?
    Naprawa Pralek Automatycznych Zmywarek
    Poznańska 46, Kalisz, 62-800 | Tel.: 62 XXXXXXX (Show)
  • #12 5957382
    schnauzerman
    Help: 277
    Rate: 565
    It could have happened what nares
    nares wrote:
    Check the heater. Perhaps it is burned out and shorting to the housing starts heating on a shorted circuit.
    Replace the heater.
  • #13 5957589
    dagor006
    Rate: 15
    The heater does not have a puncture but it is stained so I will replace it anyway. I will save on electricity. The only thing I found is that the heater is rubbed on one side as if rubbing against the drum. As for the question about spinning is spinning took place the washing machine normally turned off, after opening it began to come out smoke from the drum. I still have a question next to the hydrostat pipe something else is located in the drum to which two cables come. Could this component have been damaged?
  • #14 5957663
    schnauzerman
    Help: 277
    Rate: 565
    If there are scuff marks on the heater, it is possible that there are drum clearances due to bearing damage, does the washing machine spin loudly?
  • #15 5957692
    dagor006
    Rate: 15
    It's hard to say whether it goes loudly. A person gets used to the sound of a washing machine.
    schnauzerman
    Help: 277
    Rate: 565
    Remove the belt and vigorously turn the drum, it should be quiet, if you hear any noises - bearings to be replaced.
  • #17 5959693
    kruszyna 2
    Help: 15
    Rate: 96
    Hello, I bet on the bearings.
  • #18 5962393
    dagor006
    Rate: 15
    I replaced the heater. I did a test pouring water to determine if it was leaking. And it turned out that water is leaking, but not from the heater but along the shaft. So I think that the simmer has worn out, the bearings probably also to be replaced. Smoke in the drum was probably caused by the bearings. Now my question is whether it is possible to replace the bearings yourself at home or do you need some specialized tools like pullers, special wrenches, etc.?
  • #20 5962577
    schnauzerman
    Help: 277
    Rate: 565
    dagor006 wrote:
    what I found is that the heater is rubbed on one side as if it is rubbing against the drum....
    dagor006 wrote:
    I replaced the heater.... The smoke in the drum was probably caused by the bearings....
    Smoke in the drum was caused by the damaged heater rubbed through the drum running on damaged bearings turned on without water(shortened circuit) on the spin program. Replace the bearings as soon as possible before the situation is not repeated.
  • #21 5979379
    dagor006
    Rate: 15
    After changing the bearings and simmerings, the problem was solved. Removal of the crosshead required the purchase of a bearing puller (expense of 26 zloty). Pounding the shaft bolt with a hammer if the shaft is corroded is unfortunately a waste of time. I thank everyone for their help and close the topic.
The discussion revolves around a Polar Dafne PDH 585 washing machine that emitted smoke from the drum after completing a spinning cycle. The user initially suspected the belt but found no burning smell upon inspection. Various responses suggested checking the pressure system, heater, and potential leaks. The heater was found to be stained but functional, and the user later discovered that the smoke was likely caused by damaged bearings and a worn-out seal. After replacing the heater and bearings, the issue was resolved. The user confirmed that specialized tools, such as a bearing puller, were necessary for the repair.
