Polar PFL/C 71232P Washing Machine: Bearing Issues at 1200 RPM? Rumbling Noise & Potential Causes
budziol26 5103 4
  • #1 16675988
    budziol26
    Rate: 21
    I have a question, can it be a placenta? Ok. two months ago, the washing machine started to rumble loudly at 1200 rpm, after a month of not washing it in the washing machine, I ran it at 400 revolutions, the washing machine behaved normally. Now at 1000 revolutions you can hear it a bit again, but not as it used to be at 400, can it be a bearing? The washing machine is 3 years old. There is a movie attached, but the crackles in the film are not as loud as they really are.
    [movie: ba34881a7e] https://filmy.elektroda.pl/34_1504288886.mp4 [/ movie: ba34881a7e]
  • #2 16676030
    arturdip
    Help: 170
    Rate: 323
    Manually check that the drum has no play (by tugging on the inside of the drum flange)
  • #3 16676032
    kot mirmur
    Help: 206
    Rate: 559
    Hello, take off the belt and twist the drum by hand quickly. If you hear a hurgot, the bearings need to be replaced. With the belt removed, you can also check the drum's axial play - you move it from the front up / down. When there is a lot of slack, you will hear a knock. There may also be a broken drum axle cross.
  • #4 16676038
    budziol26
    Rate: 21
    When I took off the belt and spun the drum, I didn't feel any slack or knocking. These knocks now only occur at 1000 RPM.
  • #5 16676072
