Washing machine Polar PFL-819 - Red service indicator, laundry wash spin, start
PIOTREL 16200 7
  • #1 16659367
    PIOTREL
    Help: 41
    Rate: 172
    I have a question about the Polar washing machine.
    I have no experience in washing machines and a friend called and stupidly refused to help.
    The symptom is as follows. After turning the programmer, all lights come on for each program. After pressing start the green LEDs light up, main wash, spin 800, start flashing and the red service permanently, for a few seconds growling and buzzing.
    I will probably have to go there but I would like to be prepared for something, check it out. You can draw a conclusion with your help, eventually
    what to hang on At the beginning I had to check the strainers at the water inlet.
    I am asking for your suggestions.
    Regards.
    jacekwwy
    Level 19  
    Help: 39
    Rate: 108
    I send you service codes, but just in case, download the manuals for this model. So on "good morning" as you write, check the filter at the pump because this is the most common fault (some coin, nail, etc.), the drum is rotating freely or the tap is turned on the water, maybe someone turned off the water by accident :) Washing machine Polar PFL-819 - Red service indicator, laundry wash spin, start Washing machine Polar PFL-819 - Red service indicator, laundry wash spin, start
  • #3 16659680
    PIOTREL
    Help: 41
    Rate: 172
    Thank you, I'll check everything tomorrow.
    Strainers checked. They were clean.
    The codes you sent are to the washing machine with display.
  • #4 16659719
    jacekwwy
    Level 19  
    Help: 39
    Rate: 108
    Yes, only with the display you know what the fault is, because it is displayed and without the display you need to check everything in turn, I will add that if the strainer is clean it does not mean that something is not sitting in the pump, you need to put a finger and turn the wing, some washing machines have you must reset after removing the fault
  • #5 16659752
    PIOTREL
    Help: 41
    Rate: 172
    I'll check in tomorrow
    zhudomel
    Home appliances specialist
    Help: 1280
    Rate: 3368
    There is a problem with the heater (if you have correctly described the symptoms).
  • #7 16660059
    PIOTREL
    Help: 41
    Rate: 172
    I received this information over the phone. First of all I think it should be. After pressing start the buzzer sounds and then the four LEDs light up, including one flashing.
    Added after 7 [hours] 44 [minutes]:
    Do you think this error describes heater problems?
  • #8 16663896
    PIOTREL
    Help: 41
    Rate: 172
    Hello, the problem turned out as colleagues suggested a heater. Thank you for your help and especially to my colleague zhudomel
✨ The discussion revolves around issues with the Polar PFL-819 washing machine, specifically a persistent red service indicator and abnormal behavior during operation. The user describes that after selecting a program, all lights illuminate, and upon pressing start, the green LEDs activate while the red service light remains on, accompanied by buzzing sounds. Suggestions include checking the water inlet strainers, ensuring the pump is clear of obstructions, and verifying the heater's functionality. Ultimately, it was determined that the heater was the source of the problem, confirming the initial suspicions of the respondents.
