Mistakenly Mixed 10w40 and 15w40 Engine Oils: Change Oil or Continue Driving?
aron20000 114578 16
Can I keep driving after accidentally mixing 10W-40 engine oil with 15W-40, or do I need to change the entire oil immediately?
Yes—if you only added a small amount of 10W-40 to 15W-40, you can keep driving and change the oil at the next scheduled service rather than draining it immediately [#5999418][#6022637][#6034589] One reply says that about 0.5 L in a 4–5 L sump is no problem, and another says even about 1 L in a 3 L engine can still be driven until replacement [#5999418][#5999424] The forum also notes that modern engine oils are fully miscible, so the mix itself is not a concern [#6034589]
  • #1 5999395
    aron20000
    Help: 6
    Rate: 294
    Hello, I added 10w40 oil to the 15w40 oil by mistake, do you need to change the entire oil or can you continue driving ??
    marcin_wr
    Help: 42
    Rate: 104
    I assume that you have added no more than 0.5 liters for 4-5 liters. Nothing will happen. You don't have to change.
    adamjur1
    Help: 772
    Rate: 1003
    How much did you add it?
    As soon as a little (e.g. 1l on 3l in the engine) you can drive to change.
    Greetings J.
  • #4 5999717
    aron20000
    Help: 6
    Rate: 294
    I added less than a liter for about 3 liters in the engine, so I can drive another 3000 km for replacement.
  • #5 5999729
    adamjur1
    Help: 772
    Rate: 1003
    You haven't written what kind of cart it is, but a Ferrari is probably not ....
    Greetings J.
  • #6 6001789
    aron20000
    Help: 6
    Rate: 294
    It may not be a Ferrari, but it is close to it :) golf III benz. :)
  • #7 6002189
    adamjur1
    Help: 772
    Rate: 1003
    Buddy - I wrote so that you would start such posts in the future with information about the brand, type and mileage.
    And by the way - once in a less than 2-year-old vehicle (although it was a Daewoo but an Espero 2.0 16V version), brilliant service technicians at the warranty service (obligatory) changed my oil from fuul synthetics to ...... .... mineral. And they said I could ride it until the next change !!!!. I firmly requested a flush, flush the engine, and top up the right one. They were very reluctant to do it, they probably did not wash the engine, and they certainly did not change the filter again. As a result, the previously dry and clean engine with a mileage of about 100,000 km began to let off the oil. It was the only car in my almost 30 years of driving practice (I had 12-13 cars - I can not count exactly) when I changed a newer car to an older one - less than 3 years of Espero for a 4-year-old B4 Passat. And, gosh, I had to pay extra ... :D :cry:
    Greetings J.
    ps
    Recently, my son, in the enthusiasm of replenishing various fluids, poured distilled water into the oil (in the already mentioned 13-year-old dog)
    Fortunately, he realized that something was wrong (the coolant indicator was still blinking) and without starting the engine, he called my dad. I was draining the oil and rinsing the engine in the underground parking lot under his name ....
    mczapski
    Level 40  
    Help: 468
    Rate: 1661
    Are you seriously asking, are you kidding? After all, there is nothing to talk about. You basically flooded some better oil. In addition, I understand that this 1 liter is operational consumption. And if the car uses that much oil, it won't be picky.
    mario.123
    With this amount of refills, nothing will happen, you will easily commute for replacement.
  • #10 6034145
    kocur2891
    Certainly nothing will happen. But how can oils be confused.
  • #11 6034589
    globus
    Help: 56
    Rate: 103
    Surely nothing will happen, since the thicker oil disappears into you, this one has a chance to disappear even faster in the engine. Although it may be different, oils that are supposed to be "less" (better) do not lose their density as quickly as the "thicker" ones, but it is a matter of specification of a specific grade and manufacturer. In addition, modern oils are fully miscible with each other and you have nothing to bother with.
  • #12 6034907
    brandy-p
    Help: 128
    Rate: 542
    I used to have a polonaise and I poured it with whatever I had at hand (including the gear one :-) ) and the car was running, but once I had a client who did not know what his engine was flooded with. He added one and lost his pressure for a few kilometers. After removing the pan, it turned out that the oil had turned into a thick, sticky substance that clogged the oil pump dragon.
  • #13 6036739
    Sharuga
    Help: 6
    Rate: 28
    Buddy, why don't you exchange it for 10w-40 at all ??? This engine should work on such. Ah, I already know why - because many people repeat urban legends about the disastrous effect of this oil on the old engine. Total nonsense. I have half a bubble in my car and I am pouring 5w-40 and nothing happens. And when I bought it, the mastic was 15w-40. I have been driving this way for several years and tens of thousands of km. Yes, it is possible to flush out the muck or unseal the engine - but forgive me; if the engine stays on syphilis, it only needs the repair, not good oil - if it is healthy - add 10W-40 at the next replacement and do not tire the engine with mineral oil. Nothing will happen and you will extend his life.
    PS BTW all engine oils are currently miscible with each other.
  • Mixed engine oils are compatible; switch to 10W-40
    #14 8065457
    DoktorB
    Rate: 85
    Nothing to add or take. 100% support.
  • #15 8065975
    ociz
    Help: 1379
    Rate: 3488
    Synthetics are not poured into engines that like to nibble on oil because then they smoke and stink, and the mineral burns up nicely and there is almost no trace of it :) .
  • Forum rules favor closing, not deleting, oil threads
    #16 8066039
  • #17 8066049
    Pawel wawa
    Help: 1262
    Rate: 4433
    Owik are right, I should close the topic, which I am doing here. Your post has been reported. I sent it to the trash.
The discussion revolves around the accidental mixing of 10w40 and 15w40 engine oils. Users generally agree that if less than a liter of 10w40 was added to an engine containing approximately 3-5 liters of 15w40, it is safe to continue driving without an immediate oil change. Many participants emphasize that modern engine oils are fully miscible, and minor mixing will not cause significant issues. However, some caution against using oils of lower quality or different specifications in older engines. The conversation also touches on personal experiences with oil changes and the importance of adhering to manufacturer recommendations for oil types and viscosities.
