Effects of Mixing 6L Diesel with 60L Petrol on a Gasoline Engine
scorpio102 24192 26
Can adding about 6 liters of diesel to 60 liters of gasoline damage a gasoline engine?
A one-time mixture containing about 10% diesel will usually not cause catastrophic damage, but it can cause hard starting, weak running, smoke, and spark-plug fouling. [#15406046] [#15406525] Diesel contamination can also reduce the mixture’s effective octane rating and cause knocking, especially in newer, highly stressed engines. [#15409167] [#15408488] Older, simpler engines may tolerate it better, but the safest action is to drain the contaminated fuel and refill with fresh gasoline rather than continue driving for an extended period. [#15406059] [#15409619]
  • #1 15405940
    scorpio102
    I have a different question. If, for example, with the amount of 60 l, there were 6 l of diesel, could it harm the gasoline engine? Should nothing happen because it is only 10% of the oil content in gasoline?
  • #2 15405978
    Xantix
    Help: 686
    Rate: 1657
    It probably depends on the car. The older the structure, the better it will probably endure. I remember once my father and I had such a situation in a Skoda Favorit - my father started to pour oil out of his haste (he drove a diesel every day), he realized when he filled the tank in 1/4 of its capacity. So we poured the rest of the tank right under the cap with gasoline. Well, the car drove, although it had a large mule, but it did not negatively affect the later work of the car. After refueling with clean gasoline, it drove normally.
  • #3 15406011
    kaputo
    Help: 37
    Rate: 128
    How did he pour the diesel (large diameter gun) into the gasoline (small diameter bore)?
    If the ON content is too high, the engine will not start or will stall quickly.
  • #4 15406035
    andrzej20001
    Help: 1578
    Rate: 6669
    Let it pour :) "" ladies, but I was pouring something for a long time, it bounced and bounced "" quote from a client pulled "on a string". Candles will throw syfem, it's not worth driving like that.
  • #5 15406046
  • #6 15406059
    Xantix
    Help: 686
    Rate: 1657
    If it poured, it means that it was possible. I don't know much about refueling ON/Pb fuels, because I drive on gas every day (I fill up with petrol once under the cap and it usually lasts me 3-4 months, so I don't look at regular distributors too often, I never have an abscess I didn't refuel). Anyway, if people flood the tanks with other fuels, it means that somehow it can be done.
  • #7 15406160
    Ermax
    Rate: 17
    It won't hurt anything, at least it won't burn or it will be weak...
    As for the strange statements "the engine seizes, explodes, damages, etc..." these are some extreme accidents of engines that were already on the verge of disintegration ....
    So there is nothing to read and believe in motors, autoworlds and online mechanics...
    If such a situation occurs, it is enough to drain the fuel and pour fresh, and the mixture up to 10% DOES NOT bother ...
  • #8 15406390
    DJ ANNUS
    Help: 108
    Rate: 354
    Petrol cars have flaps in the tank and you really have to be dumb to pour drop by drop.
    After all, it's logical that if you think it's either a full tank or something wrong.
  • #9 15406424
    jas67
    Help: 39
    Rate: 116
    As soon as it fires normally, you can drive safely. You can't just leave it like that for a long time because the gasoline will separate from the drive and then there may be a problem.
    @D.J. ANNUS Sometimes it bounces like the "gun" is damaged. I haven't had that once.
  • #10 15406525
    bula17
    Help: 52
    Rate: 295
    It will flip calmly
    The side effect is a bit of smoke and a difficult start on a cold engine
    Besides, it shouldn't be a problem unless you have some FSI, I wouldn't risk it.
  • #11 15406645
    AAnnddrrzzeejj
    Help: 16
    Rate: 71
    WELCOME. One of my friends wrote, the older he is, the less he will feel. Maybe what I write is off topic. In 1975 I found a job in a company where I had access to acetone. I "farmed" 4 barrels, i.e. about 800 liters. At that time, I had the Volga, probably gas 21, the old one. A hard winter came. but the engine withstood it. There was no trace left on the engine. Merchants struggled over it. Regards. ANDRZEJ
  • #12 15408308
    wowka
    Help: 49
    Rate: 247
    I used to drive on a mixture of gasoline and diesel, poured from a diesel tank into which someone poured gasoline, but I don't know what proportions because I got it for free, but it smelled more like gasoline than oil. There was a problem with starting a cold engine and knocking combustion. If you hear strange noises from the engine when you press the gas, it is knocking combustion. But the worst problem is that the spark plugs get clogged after a while. And what's interesting, all the candles suddenly zasyfiły at the same time that suddenly it was impossible to start the car.
  • #13 15408324
    janek1815
    Help: 372
    Rate: 1062
    You can burn that much with no problems. I wouldn't be writing here if I wasn't interested in the situation found yesterday at the gas station. Passat B6 tdi stands next to it, two batteries, hoses, bulbs and 3 men. I ask what are they doing? The owner filled up with 47 liters of Pb. He freaked out as the car ignited and then died. Do you think it still fires? From the tank extracts as much as possible from the filter just poured out at me. I had no time to wait for further developments. It was cleaning the fuel system right at the distributor.
  • #14 15408438
    andrzej20001
    Help: 1578
    Rate: 6669
    It will start, but the pumps may then fail over time.
  • #15 15408488
    ociz
    Help: 1379
    Rate: 3486
    This... An old, primitive engine will last, but a newer, strained one (a lot of horses from a small capacity) can quickly finish knocking combustion.
  • #16 15409132
  • #17 15409167
    Xantix
    Help: 686
    Rate: 1657
    The point is probably that gasoline with the addition of ON has a lower octane number than uncontaminated gasoline. A lower octane number means more susceptibility to knocking. Currently, engines are designed to run on gasoline with a minimum LO of 95, although the newer ones probably prefer 98 LO. So using a low LO fuel will cause engine knocking problems.
    I still remember that old cars were probably adapted to LO 86 fuel, maybe that's why old cars cope better in such cases.
  • #18 15409215
  • #19 15409261
    Xantix
    Help: 686
    Rate: 1657
    In the Astra F from the early 90s, I have such a "myczek" at the engine controller, which is probably called "octane corrector". And you can probably use it to program one of the three octane numbers of the fuel on which you drive.
  • #20 15409469
  • #21 15409502
    Xantix
    Help: 686
    Rate: 1657
    It's not that diesel burns knocking in the cylinder from the spark plug, but that gasoline contaminated with oil will ignite from the spark plug prematurely. HE does not burn, but its presence reduces the LO of gasoline and that is the problem.
  • #22 15409604
    OSAAA1
    Help: 15
    Rate: 88
    It doesn't burn and goes into the oil. Two friends rode on such a compound.
  • #23 15409619
    marek1977
    Help: 204
    Rate: 710
    It will hurt in the long run. It will immediately hiccup and snort, and in a longer period of driving on such fuel you will have more goods on the oil dipstick in the engine. This fuel is suitable for a lawn mower.
    It's 99% fuel drained from a diesel where someone filled up with gasoline. THERE IS NO POSSIBILITY TO PUT A GUN FROM DIESEL INTO PETROL.
  • #24 15409715
    janek1815
    Help: 372
    Rate: 1062
    Currently, there is no such possibility in cars, but let's take into account, for example, the cinquecento from the beginning of production, the year 93 includes both ON and Pb. I used to have one and it fit.
  • #25 15412082
    trance123
    Help: 27
    Rate: 134
    Ap-ropo of mixing oil and gasoline.
  • #26 20313302
    Jojoborys
    Today, by mistake, I poured 8 liters of diesel from the canister into petrol, then I added 35 liters of Benz, so far I have driven 30 km and nothing is happening. Will it burn out such a mixture or is it better to drain it. Car Ford Fusion 1.4 Benz 2008 year
  • Diesel contamination mainly threatens injection pump lubrication
    #27 20314112
    michal_rybka
    Help: 283
    Rate: 771
    https://www.elektroda.pl/rtvforum/topic3938304.html exactly the same topic, nothing will happen with such a small percentage of oil in gasoline, besides, nothing will happen to a petrol engine even if it is full of oil, at most it will not ignite, or it will smoke terribly, after draining and pouring gasoline it will continue to be normal
    you have to worry when you pour a lot of gasoline into the diesel, because the injection pump is lubricated with this oil, and without proper lubrication, it blurs, filings and the entire fuel supply system gets stuck
Mixing 6 liters of diesel with 60 liters of petrol in a gasoline engine generally poses minimal risk, particularly in older vehicles. Users report that while the engine may experience difficulties starting and could produce smoke, it typically continues to operate without severe damage. The main concerns include potential clogging of spark plugs and knocking combustion due to the lower octane rating of the contaminated fuel. Draining the mixture and refueling with clean gasoline is recommended if issues arise. Newer engines, especially those with higher performance specifications, may be more susceptible to damage from such mixtures. Overall, a 10% diesel content is often considered manageable, but caution is advised for prolonged use.
TL;DR: A 10 % diesel-in-petrol mix typically drops octane by ~4 RON [Shell, 2021]; “the mixture up to 10% DOES NOT bother” [Elektroda, Ermax, post #15406160] Most engines will run but expect hard starts and plug fouling.
Why it matters: Even small octane loss can trigger destructive knock in modern high-compression petrol engines.
  • Safe dilution threshold: ≤10 % diesel in petrol [Elektroda, Ermax, post #15406160]
  • Octane drop: ≈0.4 RON per 1 % diesel [Shell, 2021]
  • Cold-start crank time may rise by 30 %–50 % [Elektroda, wowka, post #15408308]
  • Tank drain service cost: €100–€200, roadside average [AA, 2023]
  • Turbo GDI knock damage can occur within 5 km under load [Bosch, 2020]
Will 6 L of diesel in 60 L of petrol harm my gasoline engine?
Most port-injected engines survive a 10 % mix; power drops and starts are harder but no lasting harm if refilled soon [Elektroda, Ermax, post #15406160]
Why does diesel lower octane and cause knock?
Diesel molecules resist spark ignition yet dilute petrol’s antiknock additives, cutting octane ~4 RON at 10 % concentration [Shell, 2021]; lower octane increases knock risk in 95-RON-calibrated engines [Elektroda, Xantix, post #15409167]
Is it safer to drain the tank or burn the fuel off?
Drain if diesel exceeds 10 % or if you drive a knock-sensitive turbo GDI. Otherwise, gentle driving and topping with fresh petrol usually works [Elektroda, jas67, post #15406424]
How can I dilute the contaminated fuel quickly?
  1. Add at least 30 L of correct petrol.
  2. Drive 10 km at light throttle to mix.
  3. Refill to full again at half-tank. This halves the diesel share each refill [Elektroda, Anonymous, post #15406046]
Can modern FSI/GDI or turbo engines handle the mix?
They run higher compression; even 5 % diesel can trigger knock under boost and damage pistons [Bosch, 2020]. Avoid load and dilute below 3 % for safety [Elektroda, ociz, post #15408488]
Why doesn’t the diesel nozzle fit most petrol fillers?
Modern petrol fillers are 21 mm; diesel nozzles are 25 mm by ISO 17268. Older cars lacked this safeguard, so cross-fueling was possible [Elektroda, janek1815, post #15409715]
What if I accidentally fill a diesel car with petrol instead?
Petrol strips diesel’s lubricity; a 20 % mix can scar injection pumps within minutes, demanding €1 000+ repairs [AA, 2023]. Drain immediately [Elektroda, michal_rybka, post #20314112]
Is separation a problem if the car sits?
Yes. Petrol and diesel stratify within hours; the next cold start can pull near-pure diesel, stalling the engine [Elektroda, jas67, post #15406424]
Edge case: What happens in freezing weather?
Diesel can gel below −7 °C, blocking petrol filters and starving the engine, even at 5 % concentration Winter Fuel Guide.
