What to do - clean the system if you have flooded with gasoline instead of oil i
blader1234 63570 14
What should I do after accidentally putting 2 liters of gasoline into a diesel Golf 4 TDI tank?
Do not flush the system for such a small amount of gasoline; the thread’s consensus is that an older diesel like a Golf 4 TDI can tolerate a few percent petrol, so you should just dilute it with diesel and keep driving normally [#10820146][#10820353][#10820689] Several replies say that around 5% gasoline in diesel has not caused problems, and that similar mixes are even used in winter to help prevent paraffin separation [#10820146][#10824891][#10894557] One later reply recommends draining only when the contamination is much larger, such as 20 L of gasoline in a 55 L tank, which is far more severe than this case [#17086211] If the engine already runs and starts normally, the advice in the thread is to leave it alone rather than open the fuel system and create extra work [#10820689][#10826701]
  • #1 10820119
    blader1234
    Hello, as in the topic, instead of oil, I poured 2L of gasoline; there were about 6 -7 liters of oil in the tank (I did not move from the place), when I found out - I called a mechanic I know, whom I do not trust a little ... I added 44L of oil, I got home, but there was a problem - after consultation, the second mechanic told me not to drive it, but to pour it - WTF ?! what to do what do you advise? The car is GOLF 4 (2001) TDI 101KM (pump-injectors). What to do, the car is not mine, I don't know whether to admit what I did or not !? Father's car is coming back on Monday; if something goes wrong I'm dead !!! Please advise something ...
  • #2 10820146
    Cowboy zagrabie
    Help: 159
    Rate: 502
    Do not panic! 5% of gasoline has not hurt any diesel so far, it is even recommended to add "Pb" during the winter so as not to precipitate paraffin.
  • #3 10820154
    REVISOR
    Help: 58
    Rate: 57
    Hello, I personally wouldn't worry about it, as long as you put what you need under the cork, at these times you don't even know what is poured in at the stations and sometimes it is such a crap that a few percent of gasoline in crude oil will not do anything wrong. Probably the second mechanic wanted to be safe and he did not want to be bad, so he advised to drain the contents of the tank in order not to endanger the engine. it's good that you added oil to dilute the mixture, for sure the specialists will also confirm that, once you have ridden such a drug, a lot should not hurt the engine. Maybe someone else will advise who is deeper in the topic.
  • #4 10820168
    blader1234
    I have to decide something, how something is left for me - Sunday and almost all Monday to some reaction. Then Father comes back ... I have ... totally. If no luck, then no luck, 3 days ago - I had a bell in my car, Father is not here, so I borrowed him and I have ... since I had a car, it's always a "gas" ... And I know, you have to be a total retard, but too many worries and trouble lately ...
  • #5 10820353
    zerolinux
    Rate: 10
    Don't worry and keep driving calmly. I always add 5 liters of gasoline to a 60 liter tank in the winter to my Peugeot 307 when the temperature drops below -15 degrees.
    I have never had problems, and I have been driving this car for 8 years now
  • #6 10820365
    Cowboy zagrabie
    Help: 159
    Rate: 502
    If you still have concerns, I will elaborate on what can happen when we run our diesel engine with gasoline. As petrol is a lighter fraction of crude oil distillation than diesel fuel, it burns faster and at a higher temperature (however, it is a derivative of it), which in most cases ends with overheating of the piston crown and head and, consequently, mechanical damage to the engine. The conditions for the production of fuels are described by standards regarding many parameters, such as calorific value, calorific value, heat of combustion, but it is not a pharmacy recipe and some spreads are allowed. Unfortunately, fuel producers, then transport companies and finally sellers do their best to stay at the lower end of these ranges, so adding petrol is like refining the fuel. An example may be the comparison of fuel consumption at Polish stations with the well-known signboard and similar stations beyond our western border. I know from my autopsy that the consumption of German fuel is about 8-10% lower, so its energy value must necessarily be that much higher.
    You just have a Diesel V-power in your tank. ;)
  • #7 10820614
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Don't worry about anything - nothing will. I worked abroad and we brought something there every day because the client had filled up with gasoline instead of diesel. We emptied the tank to the 5l diesel tank and the starter. He flickered a little and fired - no one was cleaning anything there. It happened that we did not even replace the filter. The customer was going to the station, refueled and the problem was gone. The cars were different (even the police cars).
  • #8 10820689
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    Don't do anything more than what you've done. This is an older generation diesel and it can digest such fuel without any problems. I repeat: do nothing or you will make some other mess. Just think about what you will say when your father asks you why you gave him such a gift and you filled it up :) :)
  • #9 10824891
    serviceme
    Treat it as a winter where you need to add a little more so that the paraffin does not separate from the oil.
  • #10 10826701
    blader1234
    Okay, thanks to everyone who wrote me something and advised me ... I traveled a bit of fuel, so that Father would not guess ... Golfik seems to run like before, well we'll see ... for now I'm taking the bus :) I'm waiting for my BUNI to be made, but I feel something ... that if I run something for oil, it will remain the BUS. Thanks again for the advice, best regards.
  • #11 10894557
    MinisterQ
    Help: 17
    Rate: 16
    If you treated the abovementioned petrol with oil, you would only be left with a tow truck and cleaning the system. Flooding the diesel with such a small amount of pb will not hurt him. In winter, such a thing is the norm, in the winter older diesels consumed even 50/50 proportions - and to make it funnier, this was even recommended by the manufacturer (Mercedes in the case of w124).
    Moderated By Pawel wawa:
    Warning. Not only that the topic ended a month ago, but your chatter does not add anything to it. 3.1.11. Posting non-substantive posts with harmful advice, non-troubleshooting advice, and posting identical posts that replicate or repeat information from discussions.
  • #12 17086115
    adawys
    Rate: 13
    Hello, a topic not discussed for a long time, but I have a question yesterday, I mistakenly flooded about 20 liters of gasoline for golf 4 1.9 tdi 110 km year 2000 jedi normally start to spin longer I went to the cpn I added 10 liters he is full tank full while driving, nothing interrupts or as I will he rode and he refilled it to the full and maybe the mixol will burn and it will be normal ??? thank you in advance for your quick reply
  • #13 17086211
    Cowboy zagrabie
    Help: 159
    Rate: 502
    Golf 4 tank has 55 liters 20/55 = 36% Pb. If you have the option, drain 20l from the tank and refuel with diesel fuel again, and this will be drained into the tank at the next refueling.
  • #14 17086214
    adawys
    Rate: 13
    a mixol or something lac also to the tank
  • #15 17092300
    cyborg39
    Help: 105
    Rate: 546
    You can, Mixol in a reasonable amount will not hurt and it can help diesel
The discussion revolves around a user who mistakenly added gasoline to a diesel tank of a 2001 Golf 4 TDI, prompting concerns about potential engine damage. Responses from various users suggest that a small amount of gasoline mixed with diesel fuel is generally not harmful, especially in older diesel engines. Many users recommend not panicking, as such mixtures can be common in winter conditions. Some advise adding more diesel to dilute the gasoline, while others share personal experiences of similar incidents without significant issues. The consensus is to avoid drastic measures like draining the tank unless the gasoline content is excessively high. The user expresses anxiety about the situation, especially with the impending return of the car's owner.
