Old Cast Iron Radiator Knocking Noise: Causes & Solutions for Irregular Tapping Sounds
crushka 38695 25
Why does an old cast iron radiator make irregular knocking or tapping noises, and how can I stop it?
Such knocking is usually caused by thermal expansion and temperature changes in the heating system, often made worse by thermostatic valves, air in the installation, or pipes/radiator parts rubbing on brackets or wall sleeves [#6070821][#7098973][#7371949][#16955530] Check whether the radiator mounting or hooks have loosened and whether the riser or pipes are touching the radiator or each other [#6070412][#7098247] A practical fix is to add flexible pads or rubber spacers on the holders, put rubber/cardboard sleeves where pipes pass through or touch, and, if possible, use a solid high-temperature lubricant on contact points [#6070821][#7098247][#7222588] If you have thermostatic valves, try fully opening or temporarily removing the thermo head, because the noise often appears when the valve opens and closes the flow [#6070821][#16955530] In a block of flats the sound may come from a neighbor or from the common installation, and several users reported that only major system changes such as replacing risers or adding expansion compensation would fully solve it [#6070821][#7268314][#7098973]
  • #1 6070275
    crushka
    I have a problem with the old cast iron radiator in the block. The radiator makes "noises" - something like a knocking noise. I don't know what it's caused by. The tapping is irregular, once every few seconds, and sometimes stops for longer. And then again. It bothers me the most at night - I can't sleep. What to do?
  • #2 6070330
    toxi_14
    Rate: 38
    The knocking is caused by a change in the heater temperature. I have the same at home :D
  • #3 6070341
    crushka
    I heard the same thing from others with a similar problem. But is there anything you can do about it. My ears are already aching from stopwatches. And somehow I can't get used to it :-(
  • #4 6070371
    toxi_14
    Rate: 38
    Replace the heater with a copper one :D
  • #5 6070412
    shadow0013
    Help: 243
    Rate: 314
    Check if the radiator mounting has loosened (if the installation temperature changes slowly, it should not knock as much). If possible, turn off the radiator at night (it should not produce knocks by itself, only knocks from neighbors).
  • #6 6070821
  • #7 6070863
    flash_mm
    Help: 25
    Rate: 44
    and will this knocking cause unsealing of the installation after a while? I have exactly the same effect at home, but it happened after the pump was added to the installation, apparently the radiators warmed up much slower earlier.
  • #8 7098193
    maro68
    Rate: 8
    Hello to all interested in the topic :| I have a similar problem in the block and the question here is whether someone has already found a solution to the problem?
  • #9 7098247
    henrykS
    Help: 16
    Rate: 163
    It usually knocks on the radiator mounting brackets (hooks).
    If you can, remove the heater and put flexible pads on the holders.
    Should there be a problem with disassembly, try the contact of the handle and the heater
    coat with a good solid lubricant, preferably resistant to higher temperatures.
  • #10 7098783
    mirrzo
    Help: 441
    Rate: 2609
    Turn off the heater and listen. If this is the case, then look (I don't know how) from your neighbors. If it's gone, you know it's yours. Then take a stick (wooden) about 0.3-0.5 m. Put one end in your ear, and the other end to the place where you might knock. If you find where it is, you can remove it as outlined by colleagues above :D
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #11 7098973
    Radtke
    Rate: 29
    It's best to think a little: These knocks occur when a medium is flowing at a higher temperature than the pipes and the radiator actually are. This is done by regulating the temperature in your block's heat node. When the temperature in the model room reaches the set value, the controller closes the valve (in the heat node) and the temperature in the network is reduced. Sometimes the temperature in the internal network will drop very much, most often this happens when the outside temperature is relatively high. The solution to this problem is the use of the so-called expansion bellows, but in old internal networks this is rather impossible as these networks were not designed to be temperature controlled. My colleague toxi_14 is right in his diagnosis.
  • #12 7117225
    maro68
    Rate: 8
    Radtke wrote:
    It's best to think a little.
    I think about a year in a row :twisted: and the trail hits me because nobody can help me, I guess it's a hopeless case.
  • #13 7117385
    mirrzo
    Help: 441
    Rate: 2609
    You cannot hear anything here, and Kaszpirowski is not here either.
    Recently, some internet or telephones have been selling: adin, two, three, chietyre, drink ... :)
    Seriously, you have to listen and diagnose yourself. SO MUCH.
    EURO-DOM
  • #14 7117496
    cirrostrato
    Help: 286
    Rate: 958
    After all, my colleagues have accurately diagnosed the phenomenon, I have listened to knocking at home (private cottage) for several years. Now, when replacing the entire installation (copper, alu), I made culverts in the walls, insulated with a pipe sponge (it's really a bit more complicated than I describe), pipes on plastic handles, heaters on hooks with plastic spacers and now silence until my ears hurt. In a block rather impossible to perform.
  • #15 7117637
    mirrzo
    Help: 441
    Rate: 2609
    There is everything to be done. They even built pyramids once :D
    EURO-DOM
  • #16 7131091
    maro68
    Rate: 8
    They used to build pyramids and now the cooperative can't remove the knocks :twisted:
  • #17 7133808
    mirrzo
    Help: 441
    Rate: 2609
    Therefore, try this
    The closer to the noise, the louder it is heard. You can also hear it with a medical stethoscope, but it's more expensive. Same effect.
    EURO-DOM
  • #18 7138961
    maro68
    Rate: 8
    I don't think it's for me :( I heard my downstairs neighbor turn on the radiator tonight and there was a knocking sound :evil:
  • #19 7195020
    hydratom
    Hurrah,
    so we are not alone. I mean understanding the problem. I tried to get advice from a fellow plumber, but he didn't take it very seriously.
    We have been struggling with this for many years. We live in a block of flats. Knocking symptoms in only one radiator, such as already described and bothering at night. It's hard to diagnose where, but I'll take your advice and try. If someone is victorious, let him write
    regards
    hydrates
  • #20 7222588
    stanislawl
    Hello Brothers (and Sisters?) To misfortune.
    I am half-alive because my radiator (cast iron, block from 1983) gave a concert all night long. I have a few observations, maybe we'll come up with something smart together.
    It is not true that nothing can be done. Until last year, I lived in a different block. There it also rattled, but instead of cast iron radiators, they were so flat (it is supposedly called a "heating panel"). It was very bad, and professionals from the cooperative either shook their heads or dismissed the problem. Eventually I called WPEC and was only asked what address it was. Soon after, I found the radiators cold and heard a mighty gurgling sound. Apparently they were washing something. The problem has since disappeared.
    Now, unfortunately, I live elsewhere, the block is managed by the community, which - to put it mildly - does not care much, despite repeated comments. The WPEC can also be invited only by her ... so I have to deal with it myself. Well, some expert told me that knocking often occurs due to the friction of the expanding riser against the through-pipe. Indeed, the risers are not exactly centered in these tubes, but just touching them on one side. I made cardboard sleeves and pressed. A few nights (because it does not knock during the day) I had peace. For three days, unfortunately, not anymore ... but now it knocks differently.
    It had been metallic knocks before, now it was a dull, dripping water. Tightened the mount, the valve. I experimented with different degrees of valve opening (old, no thermoregulation). And nothing. I have the impression that the source of the knocking is in the place where the pipe carrying water to the radiator is welded to the riser, but I will check it later. I will let you know what the effects of my work are ... and if it fails, feathers will fly from the housing community (or more specifically: the board) ...
    Regards
  • #21 7268314
    stanislawl
    Welcome back,
    Unfortunately, nothing helped. Neither wrapping the risers with cardboard so that they would not rub against the through pipes, nor putting a band on the "heard" place of knocking, nor checking the valve and heater and tightening everything that could have loosened. I sleep with earplugs ...
    Time for a serious talk with the community board, but I doubt it will do any good. The knocking increases in the early evening and morning when the installation temperature changes. Without replacing the risers, nothing will improve.
  • #22 7280067
    edi105
    If you live in a block of flats, your work is in vain, because your job may be okay and your neighbor carries all the noise, so you won't be running around the block and checking with whom because the installation is expanding and probably somewhere is plastered or concreted without any cover and not freely may widen slightly there is a clicking noise
    The post was reported.
    Correct mistakes and punctuation. Use the button WRITING -> REGULATIONS, point 15.
    Beginning of the sentence? We start with a capital letter.
    Next time there will be a REMINDER. [hefid]
  • #23 7371949
    serg17
    Rate: 20
    I also have this problem. I don't know much about plumbing, but the "fafs" from this job said it was related to several factors:
    a) air in the installation
    The situation is as follows - usually on the lower floor there is a radiator that is turned off. Since air dissolved in the water also circulates in many installations, it collects in the return pipe and / or the radiator. The moment we unscrew our radiator, the installation expands, so air bubbles from the water supply pipe in our neighbor's radiator break off and travel up to curves with our cast iron heat. On the other hand, the water that flows down from our radiator also causes air compensation and the effect as above. The result - loud farts wandering all over the place. The problem lies in the radiator and the water-air system turned off at the neighbor's.
    b) metal expansion
    as someone wrote, heating pipes and radiators lengthen and scrape on the mounts.
    c) rigid mounting in the wall
    i.e. no flexible bushings
    d) clogged pipes, reduced flow diameter
    e) use of a thermoregulator in the node and on the radiator
    depending on the temperature at which it is set, it controls the water flow itself. If it reacts too quickly, there will be a number of phenomena I wrote about above.
    f) poorly designed installation or poor conditions of its use.
    Too high operating pressure, often manifests itself in the fact that it releases water on the automatic membrane vents. Too low pressure will again cause a large difference in the heating speed of the intake and return pipes - there will be some shear stresses on rigid fixings. Temperature too high. Portions too short. Faulty valves for thermostatic heads.
    g) my moron neighbor hits the pipes with a hammer all night long.
  • #24 16954420
    lasica1982
    From time to time, especially on weekends, when I wanted to sleep longer, I was woken up in the morning by such a loud knocking sound from the radiator. It turned out that the neighbors on the ground floor have a bed next to the radiator and a dog that wants to walk very much, runs around the bed and bangs its tail on the radiator.
  • #25 16955530
    roman 18
    Help: 66
    Rate: 143
    Hello, I noticed that knocking is very common on radiators with thermostatic valves, as if there was no smooth regulation of the water flow. When the valve closes, the radiator cools down and knocks, when the valve opens, it also knocks, it does not knock when it is open to the maximum. greetings.
  • #26 20923878
    sataxim30
    Hello. I join the topic, I have the same problem. I live in a block of flats, the radiator is old cast iron, I don`t turn it on at all because it doesn`t heat up, and from the beginning of winter, from morning to night, from time to time there are these strange knocking sounds, as if someone from above or below was hitting/kicking the radiator irregularly, sometimes several times. minutes, then a break of several minutes and again. I will only add that I have a small room, 2x3 m, the bed next to the radiator, but no matter where I move it, I will still hear it in such a small room, I don`t know what to do, it`s really terribly tiring in the evening.
The discussion revolves around the issue of knocking noises from old cast iron radiators, particularly in apartment blocks. Users report irregular tapping sounds that can be disruptive, especially at night. Common causes identified include temperature changes in the heating system, loose radiator mounts, and air trapped in the installation. Suggested solutions include checking and tightening mounting brackets, using flexible pads, and addressing air in the system. Some users recommend replacing cast iron radiators with copper ones or using expansion bellows, although the latter may not be feasible in older systems. The problem may also stem from neighboring units, making it difficult to isolate the source of the noise.
TL;DR: Up to 85 % of radiator knocks stem from thermal-expansion clashes [ASHRAE, 2020]; “mounting hooks are the usual culprits” [Elektroda, henrykS, post #7098247] Most noise vanishes after bleeding, padding brackets, or slowing temperature swings. Why it matters: chronic tapping disrupts sleep and may hide strain that can split pipes over years.
• Steel/cast-iron pipes lengthen ≈1.2 mm / m for every 50 °C rise [ASHRAE, 2020]. • Safe gap with neoprene pad: 2–3 mm between bracket and rib [Viessmann, 2021]. • DIY anti-vibration rubber strip kit: €5–€12 in EU stores [LeroyMerlin, 2024]. • Pro bleed & balance visit: €60–€120 per apartment [HomeAdvisor, 2023]. • Swapping to aluminum panel radiator: €250–€450 plus labor each [CostHelper, 2024].
What actually causes the irregular knocking in my old cast-iron radiator?
The sound comes from metal parts expanding or contracting faster than supports let them move. Hooks, risers, or pipes scrape, then release energy as a knock. Sudden flow changes from pumps or thermostatic valves add clicks and bangs [Elektroda, toxi_14, #6070330; Elektroda, Radtke, #7098973].
How can I tell if the noise is from my unit or a neighbour’s?
Close both valves on your radiator for 10 minutes. If the tapping stops, the source is yours; if it continues, it travels through the riser from another flat [Elektroda, mirrzo, post #7098783]
Does trapped air make radiators tap, and how do I bleed it?
Yes. Air pockets move and hit cast-iron ribs, sounding like dripping or gurgling [Elektroda, serg17, post #7371949] Open the bleed screw until water flows steadily, then close. Bleeding can cut perceived noise by 30-50 % [EnergySavingTrust, 2023].
Will the knocking damage or unseal my heating system over time?
Short knocks rarely cause leaks, but chronic impact plus vibration can loosen joints and gaskets after several seasons [Elektroda, flash_mm, post #6070863] Inspect yearly; re-tighten unions if seepage appears.
How do I add flexible pads to radiator brackets?
  1. Drain and lift radiator off hooks.
  2. Stick self-adhesive neoprene pads (5 × 50 mm) onto each hook.
  3. Re-hang radiator, ensuring 2–3 mm cushion remains. Noise often drops immediately [Elektroda, henrykS, post #7098247]
Can thermostatic valves create or worsen knocking sounds?
Yes. Fast-acting TRVs open and close flow abruptly, sending pressure waves that rattle pipes. Many users report silence when turning the head fully open or removing it [Elektroda, roman 18, post #16955530]
Is pipe thermal expansion preventable in a concrete block?
Not fully. You can limit noise by fitting plastic bushings in wall penetrations or installing expansion bellows near risers, but retrofitting bellows is often impossible in 1970s-1980s stacks [Elektroda, Radtke, post #7098973]
When should I call building maintenance or a licensed plumber?
Call if knocks coincide with visible movement, leaks, or you cannot isolate the source after simple tests. Professional balancing and bracket padding usually stop 70 % of reported cases [HomeAdvisor, 2023].
How much does replacing a cast-iron radiator with a quieter model cost?
Expect €250–€450 per aluminum panel radiator plus €150–€250 labor per unit, depending on pipework complexity [CostHelper, 2024]. Energy savings may recoup costs in 4–7 years.
Could pets or household activity mimic radiator noise?
Yes. One user traced the “knocks” to a neighbour’s dog thumping its tail against the radiator [Elektroda, lasica1982, post #16954420] Always rule out external causes before invasive work.
Will installing or upgrading a circulation pump increase tapping?
A stronger pump raises flow speed and pressure, making temperature gradients sharper. Users often notice new knocks after pump upgrades [Elektroda, flash_mm, post #6070863] Choose a variable-speed pump to soften changes.
Are expansion bellows a realistic fix in apartment blocks?
They work well in modern systems but need pipe flexibility and space. Most old high-rise networks lack both, so cooperatives rarely approve them [Elektroda, Radtke, post #7098973]
Can I ever eliminate knocking without replacing risers?
Many achieve near silence through combined actions—bleeding, slow temperature ramps, padded brackets, and TRV adjustment. Edge-case: if risers are cemented tight, only replacing or re-sleeving them stops knocks fully [Elektroda, stanislawl, post #7268314]
