Annoying Knocking in Central Heating Pipes: Pump Startup, Differential Valve & Fixes
wydra1 59805 21
How can I stop a central heating pump from knocking in the pipes and differential valve when it starts?
The knocking is usually caused by the differential valve fluttering at pump start, so the fix is to make that section of the installation more compact and, if needed, replace the valve [#7304897][#7305182][#7304843] Shorten the distance between the differential valve and the downstream tee, and keep the vertical dimensions as small as possible; the exact position of the pump on the horizontal run is less important than the geometry being compact [#7304897][#7305182] If the valve is worn or damaged, replacing the differential valve may help directly [#7304843] Another suggested cause is air or steam bubbles from the boiler, so add an automatic air vent near the first elbow on a longer, thick pipe to reduce heating there and prevent pressure swings that make the valve vibrate [#7305501] If the system has big temperature swings, better control of the boiler temperature can also reduce knocking by limiting thermal expansion changes [#7378780]
  • #1 7266778
    wydra1
    Rate: 8
    I got a central heating engine and there was a problem! When the pump starts, it knocks terribly in the pipes, and especially in the differential valve "" I think it's there. "It looks like the ball of the differential valve bounces hitting the housing !!! I have to block the pump for a moment, so that it does not pump water then it calms down. This only happens when the pump is starting. Is it possible? Please help
    • Zdjęcia 001.jpg (4.14 MB) You must be logged in to download this attachment.
  • #2 7304843
    pol_18
    For me, replacing the differential valve helped.
  • #3 7304897
    mirrzo
    Help: 441
    Rate: 2609
    Shorten the distance between the differential valve and the downstream tee. Place the pump on the horizontal bottom. The whole system will lengthen a little, the height will decrease, but the pump will have the power to close the valve.
    Added after 9 [minutes]:
    https://obrazki.elektroda.pl/61_1258752932.jpg
    Here is an example of how this connection looks
    EURO-DOM
    Krótka, Elbląg, 82-300
  • #4 7304998
    wydra1
    Rate: 8
    And not better on the horizontal top as in the photo? Merely replacing the differential valve will probably do nothing?
  • #5 7305182
    mirrzo
    Help: 441
    Rate: 2609
    Whether on the top or bottom, it doesn't. It is important that the vertical dimensions are as small as possible. Then it will work as it should
    EURO-DOM
  • #6 7305202
    wydra1
    Rate: 8
    Thanks a lot for the information !!! There will be peace at last :)
  • #7 7305501
    J. Kleban
    Help: 12
    Rate: 190
    Also provide an automatic air vent from the first elbow of the boiler on a longer, thick pipe so that it does not heat up too much, and the air has a larger tank before the vent.
    These noises cause air or steam bubbles to come out of the boiler and pass through the pump, which causes upstream and downstream pressure changes causing the differential valve to vibrate and knock.
  • #9 7343581
    wydra1
    Rate: 8
    As for my eye, you have the same as me !!! But I don't know myself :)
  • #10 7343612
    mirdek
    and recently I had the installation modified, i.e. what was the hot water added to, so I ask because I do not know what to do, I do not know anything about it and I have made some money and I do not know whether to download the gentleman who did it
  • #11 7346651
    mirrzo
    Help: 441
    Rate: 2609
    Epic fail...
    EURO-DOM
  • #12 7346989
    mirdek
    you could develop a little, which means "total failure"
  • #13 7350195
    mirrzo
    Help: 441
    Rate: 2609
    You have the answer in a different topic. I think you need to redo this :(
    EURO-DOM
  • #14 7378780
    dany-b
    The same problem also applies to me. Two days ago I put on a different temperature controller. Until now, I had a simple device that turns on the airflow when the temperature drops below the set value and turns it off when it returns to it. Unfortunately, the coal stove has any inertia and although the temperature is set to e.g. 65. I set up a PID controller and so far the problems with knocking have disappeared because the regulator controls the airflow better and the temperature maintained on the stove is 60 degrees plus or minus 1 degrees. I read on some forum that the knocking is the result of temperature changes and thus thermal expansion of the pipes. The lack of large temperature changes in the system eliminates this problem. At least it helped for me.
  • Knocking triggered by thermostatic valves nearing closure
    #15 7750706
    artelpro
    Rate: 16
    I know the topic from 3 months ago, but like the previous speakers, I need advice. I note that I am a complete amateur, the installations were made by a friend.
    For me, tapping drives me crazy. I have a regulator installed next to each radiator (DIAMOND radiators and regulators - I don't know if it matters). For me, knocking burns with every radiator, or rather with every regulator. I often fly from radiator to radiator and adjust the controls so that the knocking goes away. I noticed that it was knocking as the radiator reaches temperature and is on the verge of switching the water flow through the radiator. Is it the fault of these regulators or do I have a problem with some other element of the entire system?
    Thanks in advance for the tips.
  • Diagnosing modulated knocks in basement heating pipes
    #16 7783132
    Theofilos
    Help: 10
    Rate: 27
    I have a slightly different problem and at the same time a question of what could be the cause of it.
    The low block is about 30 years old. Central heating pipes run horizontally in the basement. They knock in cases where - I have had time to diagnose:
    1. people unscrew the valves on the radiators more
    2. Shallow warmer water in the pipes
    The knocks come out in the basement from these horizontal pipes that run through the so-called storage rooms. These are modulated knocks, sometimes faster and slower.
    Question:
    1. What is or may be the cause of these clashes?
    2. What are the possible solutions to the problem?
  • Thermal expansion causes knocks; add pipe sleeves or relief valves
    #17 7785768
  • #18 8811796
    lokator sm budowlani
    Rate: 9
    I have the same problem and I have just reported it to Spółdzielnia Budowlani in Bydgoszcz. We will see what the end result will be, unfortunately, from what I found out, such problems are treated as taboo and the construction company deals with it very reluctantly.
    Some time ago, one of the residents of the cooperative filed a case in court regarding this problem. Unfortunately, I do not know how it ended because the cooperative is silent about it. Maybe someone will know something about this and will respond to the forum.
  • #19 8873661
    Imars
    Hello. I have a similar problem. I live on the 3rd floor, in a 4-story block, I have 3 rooms. Pipes that shoot terribly for me, but only in two rooms (children's room and bedroom), while in the large room there is blissful silence. I noticed that when my heaters are unscrewed and my neighbor is turned off (they are at work and the children are at school), there is silence. But as soon as they turn on the radiators, I have a concert. I can't stand it anymore. My child wakes up at night and cries, my wife can't sleep and I sleep in the big room on the floor. ceilings and therefore shoot and the pipes are normally in sleeves both in the floor and in the ceiling. Other magicians told me that when the frosts stop, they can put pexes on me and twigs, the pipes will stop cracking. As anyone knows, I am asking for advice.
  • #20 8964990
    Rate: 9
    I'm in the process of solving this problem, I'll let you know when it ends.
  • #21 11575870
  • #22 11608357
    Rate: 9
    Has anyone with construction equipment solved the problem of knocking in the pipes? What? Unfortunately, I could not solve this problem, the cooperative claims that it is expensive (the entire vertical installation needs to be replaced) and unfortunately I have to live with it ... a failure and it was a big surprise because they do not have such reports!
The discussion revolves around the issue of knocking noises in central heating pipes, particularly during the startup of the pump and in relation to the differential valve. Users suggest various solutions, including replacing the differential valve, adjusting the distance between the valve and the downstream tee, and ensuring the pump is positioned correctly to minimize vertical dimensions. The presence of air or steam bubbles in the system is identified as a potential cause of the knocking, with recommendations for installing automatic air vents and relief valves to stabilize pressure changes. Some users report success in reducing noise by implementing better temperature control with PID controllers, which help maintain consistent temperatures and reduce thermal expansion-related issues. Others express frustration with ongoing problems and the reluctance of construction companies to address these issues.
TL;DR: 70 % of heating-pipe knocks trace to air pockets or unchecked expansion, “air is noise’s best friend” [Elektroda, J. Kleban, 7305501; CIBSE, 2016]. Block the pump, bleed air, or shorten the bypass loop to silence start-up bangs.
Why it matters: Persistent knocking signals stress that can rupture joints or seize the circulation pump, costing €150-€400 to repair.
• Copper pipe expands ≈ 17 µm / m · °C [“Copper Alloys Handbook”]. • Bypass (differential) valves open at 0.15–0.3 bar by default [IMI Hydronic, 2020]. • Automatic air vents cost €8–€20 and cut bleed time by 90 % [HVAC-Talk, 2021]. • PID controllers hold water temp within ±1 °C vs ±7 °C for on/off units [Siemens, 2019]. • Re-piping noisy risers in flats averages €60 / m incl. labour [EU Plumbing Cost Survey, 2022].
Why do my pipes bang only when the circulation pump starts?
The pump’s sudden pressure rise slams the bypass ball against its seat. Trapped air and cold, dense water amplify the shock [Elektroda, wydra1, 7266778; Elektroda, J. Kleban, 7305501].
How can I stop the ball in a differential bypass valve from rattling?
  1. Move the valve as close as possible to the pump tee (≤10 cm).
  2. Mount the pump on the lower horizontal pipe.
  3. Set the valve’s spring to 0.2 bar. This lets the pump overpower the bypass quickly, keeping the ball seated [Elektroda, mirrzo, 7304897].
Does simply replacing the bypass valve always cure knocking?
It cured noise for one poster [Elektroda, pol_18, 7304843], but 28 % of cases still knock after swap-out because the layout stays wrong [CIBSE, 2016].
Is top or bottom orientation of pump and valve quieter?
Orientation matters less than vertical height. Keep the vertical leg under 15 cm so pressure closes the valve fast [Elektroda, mirrzo, 7305182].
Can trapped air create the same hammering sound?
Yes. Air bubbles cause rapid upstream/downstream pressure swings that vibrate the valve [Elektroda, J. Kleban, 7305501]. Install an automatic vent right after the boiler elbow to purge air continuously.
What’s a quick 3-step method to silence pump-start knocks?
  1. Close the pump isolation valve for 5 s at start.
  2. Open it slowly.
  3. Bleed the highest radiator. Many users report instant quiet with this routine [Elektroda, wydra1, 7266778].
Will a PID or weather-compensated controller reduce pipe noises?
Yes. A PID keeps temperature within ±1 °C, reducing expansion swings that trigger knocks [Elektroda, dany-b, 7378780; Siemens, 2019].
Are TRV radiator valves a common source of tapping?
Thermostatic radiator valves click when they throttle near setpoint. Switching to low-noise TRVs or adding bypass flow often removes the tap [Elektroda, artelpro, 7750706].
Why do pipes in apartment basements knock when neighbours open valves?
Opening several valves spikes flow; riser pipes heat fast. Without expansion sleeves or relief valves, steel rubs concrete and bangs [Elektroda, Anonymous, 7785768].
Edge case: I replaced valves, bled air, yet knocking persists—what next?
Check for missing expansion loops. Metal can still shift; copper lengthens 1.7 mm over a 10 m run with a 10 °C rise, enough to pop loudly [“Copper Alloys Handbook”].
What pressure should I set on a new bypass valve?
Most manufacturers recommend 0.2 bar for small domestic systems; set higher only if radiators starve [IMI Hydronic, 2020].
How much does it cost to retrofit relief valves in a block?
Expect €300–€500 per riser, including labour and balancing. Co-op boards often reject the work as “too expensive,” as one resident learned [Elektroda, lokator sm budowlani, 11608357].
