Laskomex CD2502 Intercom Door Opening: Seeking Code for Visitor Access Without Apartment Unit
Hrabia322 114549 17
How can I get a code for a Laskomex CD2502 intercom so visitors can open the entrance door when my apartment has no uniphone installed?
You cannot reliably create that access code yourself; the intercom’s service/programming mode is protected, so you need the installer or the building administrator to program or provide one [#6087201][#6087299][#6944739] The administrator should know who installed or maintains the system and can request the code table from them; the installer can then assign you a code, ideally one outside the apartment call range so other tenants’ uniphones do not ring [#6243163][#6944739] One reply says the installer should not charge much for this, roughly 50 PLN, but the exact fee depends on the installer [#6087299] If someone has access to the electronic cassette, the last 4 digits of the code may be readable, but this only works if the installer did not change the default code [#6137245][#6243163] Do not use a neighbor’s apartment code, because it will trigger their uniphone whenever someone enters with it [#6241660][#6944739]
  • #1 6087115
    Hrabia322
    Rate: 38
    Hello, as in the topic, I have such an intercom in the block and I need a code to open the door. I do not have an intercom in my apartment because the owner said that it will not be installed because it is too expensive. And if someone wants to visit me, I have to go down and open the door for him, it is a hassle, I need a code that I would enter and we could open the door.
  • #2 6087201
    davidos_77
    Help: 13
    Rate: 62
    Hello, you have to somehow get in touch with the installer of the intercom. Only he can program a code for you, thanks to which you will be able to open the door. greetings
  • #3 6087233
    Hrabia322
    Rate: 38
    davidos_77 but it will cost me quite a lot, probably because just installing an intercom is 250 PLN and where should I get this administrator?
  • #4 6087299
    davidos_77
    Help: 13
    Rate: 62
    I think the installer should not delete more than 50 PLN for entering the code. You will not do it yourself, because entering the control panel service mode is protected with the installer code. Best if you ask who installed this intercom. It is possible that one of the tenants or the administration has a bearing on the installer. Then get in touch and present the matter.
  • #5 6137186
    79misiek
    well, unless you find an intercom, it has a code needed to enter the installation procedures. unless the installer changed it to only known to him.
  • #6 6137245
    davidos_77
    Help: 13
    Rate: 62
    It is true that you can read the code from the electronic cassette to enter the programming mode (the last 4 digits), but usually each installer changes it :) .
  • #7 6241660
    ultrra
    Rate: 9
    there is one more advice to see the neighbor entering the code to his apartment, but there is one more thing when the code is used to signal this tenant in the uniphone, unless this function is turned off. Alternatively, see if the postman is entering the code :D
  • #8 6243163
    Nowart
    Help: 26
    Rate: 105
    hmm, giving everyone the input code (assuming that it can be obtained, which is not so difficult, contrary to appearances), is like giving away the input keys. Probably not such an idea was paid by the tenants a lot of money. Determine in ADM who installed or who maintains the cage. This guy definitely has the so-called code table. For the proverbial "flach" he will give you a code from outside the range of apartments so that it does not confirm entry at the neighbors. Although the installer, the installer is not 100% sure, so I am not 100% sure. As a last resort, try to get this 4-digit code from the electronic cassette and call me private.
  • #9 6313338
    kris185
    Rate: 22
    If you know where the electronics from the intercom and you have access to it, you will read the last 4 digits of the code, if the code installer has not changed it, you will do it yourself because it is very simple. Only you need to know the procedure for entering the service mode, if you do not have the code yet, I will be happy to help you.
    How what is it for pw.
  • #10 6929295
    adamschodowy
    Rate: 10
    I have an identical problem with this system, in my case, after dialing my apartment number, the display shows oUo (out of order? And if - how to interpret it? Number out of use? Terminal failure?) The handset is powered, I hear noise, after a minute " pick-up "intermittent signal, or rather a rectangle because you can hear regular popping sounds), 6-wire installation, completely different than in the manufacturer's PDF files. In the handset you cannot hear the key button toggling anything.
  • #11 6944739
    telrad
    Help: 30
    Rate: 48
    adamschodów and where do you get the 6-wire installation in the CD2502 system? Maybe when the installer changed the intercom from analog to digital, he forgot to replace you with a digital one?
    - Regarding Hrabia323, it is an installer, although he did not install a uniphone for you because the owner did not want to, he is obliged to provide you with the code free of charge to open the bolt so that you can get to the apartment. And handing out someone's code is very inappropriate because the neighbor's code will sound every time that someone enters the block with his code. Go to the block manager and tell him that you want the code to enter and he will contact the installer and give it to you. Each time after installing a new system, I make a copy of the code table and leave the original to the block administrator. Greetings.
  • #12 6945178
    Nowart
    Help: 26
    Rate: 105
    The oUo badge in Laskomex intercoms means that a conversation has been established, but as for the 6-wire installation, it is actually 6, but from the panel with the keyboard to the electronic cassette. Only two L +, L- wires can enter the uniphone. If your apartment was excluded from the calling range, OFF would appear on the display.
  • #13 6963556
    bercikwwo
    Rate: 11
    Hello. I had a similar problem. namely, in the building where I have an apartment and I do not live there at the moment, the residents made a contribution for an intercom and a new door. and after some time, when I came to visit the flat, I look and the cage door is closed. I called some number and it was opened. I started to ask where is my key, where is my code and most importantly, where is my handset. I got the handset and in addition a bang. later I got a phone call from some neighbor who assumed it all. he gave it the code, I asked how to connect it and which of these six cables to connect. I got a hint with red under plus and blue under minus. so i did. I also had to set the sum of jumpers in the handset so that the number was 7. I combined and nothing, even I can not hear any signal in the handset. I was fed up and reported to this guy asking him to plug it all in. He gladly replied that he would do it, but he does not know when and I have been waiting for two months. Fortunately, I don't live there. And what is the subject, the building administrator is obliged to take care of everything and can not delete anything for it. good luck
  • #14 6964425
    telrad
    Help: 30
    Rate: 48
    bercikwwo connect the plus and minus set the number 7 (your apartment) and call from the bottom. This system has an anti-eavesdropping lock, and you have your earpiece turned off. When someone calls your uniphone, the receiver is turned on for the right time and then it turns off. When you connect + and - you can check it with the door opening button, when you press it and let it go, you will hear such a quiet puffing in the handset.
    As for the deletion, my opinion is different, you haven't paid, you don't have it, you want to have it. If everyone was composed except you, now divide this amount into all the premises and take to each of them a little, and then the judges will not look askance at you.
  • #15 7005610
    bercikwwo
    Rate: 11
    telrad you misunderstand me, I own that I paid my share. How do I set the number 7, i.e. my number. flats. There are a few jumpers in the handset and unfortunately I don't know how to connect them?
  • #16 7005919
    Nowart
    Help: 26
    Rate: 105
    Put jumpers on 1,2,4. ;) That's seven altogether.
  • #17 7147626
    bercikwwo
    Rate: 11
    tomorrow I will connect these jumpers if I succeed and write if it works. Thanks
  • #18 7318585
    bercikwwo
    Rate: 11
    everything is taken care of. The intercom fitter came and connected everything and it works. Thank you for all your help.
    Topic is closed
The discussion revolves around the Laskomex CD2502 intercom system, specifically the challenge of obtaining a code to open the door for visitors without having an intercom installed in the user's apartment. Users suggest contacting the intercom installer or building administrator to obtain the necessary code, as it is typically protected and cannot be accessed by the user directly. Some responses mention the possibility of retrieving the code from the electronic cassette or observing neighbors to learn the code. There are also discussions about installation issues and technical details related to the intercom system, including wiring and jumper settings for proper functionality.
