Central Proel CD1803: Standard Entry Code for Striker, Tenant Setup, Intercom Instructions
markode 37066 6
  • #1 3761299
    markode
    Rate: 140
    Hello, I bought a Proel intercom, which is the standard code for the entry of the striker, I can not find in the instructions that I have to set up for each tenant, I have to provide the current one, it is a new exchange, but the code in other companies is 1234 or 0000, here I cannot read the code of opening the lock and the operator
  • #3 3762938
    nikspol
    Help: 72
    Rate: 85
    Common code - 240361 and the installer code and apartment codes should be attached to the purchased switchboard on a piece of paper and printed in the form of a table. No. table is the code of the inst.
    And this is the case with the SLAVE switchboard
    MASTER assigns SLAVE codes.
    Call us, give the control panel number, it is glued on the housing or on the board inside, it is also sometimes an installation code. If not, let them send you. Knowing this code, you will set the user codes yourself. page 45 of the manual.
  • #4 8014851
    Erni1
    Help: 15
    Rate: 45
    I have a similar problem, I cannot enter the programming procedures
    I knock in (key) 240361 and the installer code and unfortunately it does not work
    I have a question:
    Is the installer code the one with which I can open the door after dialing 100 (key) XXXX?
    Is it something completely different
    Can the control panel be reset to some factory settings?
    How to get this installer code and from whom if it's not the 100 (key)
    Regards
  • #5 8031648
    piotrula
    Hello, If we cannot enter the control unit's procedures, it means that the 4-digit code of the installer is changed or we are performing the 6 + 4 operation too slowly. The code 240361 plus the four installer digits are not used to open the bolt, only to enter the control panel procedures, of course, we can use the P-8 procedure to force the bolt to open, but only to check the correct connection of the control panel to the lock. The apartment codes of which we have 255 are available to open the lock. Switchboards after 2001. they do not have a factory reset (i.e. reset) function. Similarly, they do not have the famous code (100XXXXXXXXX).
  • #6 8815026
    Ircys
    Intercoms specialist
    Help: 1342
    Rate: 2085
    After all, XXXX is the individual code of the installer or the factory number of the code table of this intercom, how do we know it? It's like finding an ATM card and writing on some forum: I found an ING bank card, can someone provide a PIN for it?
    Regards
    www.alfatech.net.pl
The discussion revolves around the Proel CD1803 intercom system, specifically regarding the standard entry code for the striker and tenant setup instructions. Users are seeking the default installer code, which is commonly noted as 240361, and clarification on how to program tenant codes. It is mentioned that the installer code is distinct from the door opening code and that the control panel may not have a factory reset option. Users also express difficulties in accessing programming procedures, suggesting that the installer code may have been changed or that they are entering the sequence too slowly. Additionally, a workaround involving a magnet to operate the intercom is shared.
