Step-by-Step Guide: Align Antenna for Hot Bird 13E with Technisat DigIt S2 Tuner & V-21 LNB
azor77 78280 8
  • #1 6183431
    azor77
    Rate: 20
    I searched the forum under this thread and to be honest I don't understand anything and am completely green at it.
    Can you please explain step by step how to set it up to catch Hot Birde 13E.
    I bought a prepaid TV set and cannot set it up.
    Technisat Degit S2 tuner
    Canopy 80.
    Monoblock Single Gold Class V-21 LNB
    I set the antenna and the tuner shows me that it only catches: Astra 19.2E / Astra 25.5E / Eutelsat 13.0E / Eurobird-Astra 28.5E.
    And I also want to set up on Hot Birde 13E because probably only from this satellite are these pre-paid programs broadcast.
    I am asking colleagues for any suggestions and advice on what to do and how.
  • #4 6183516
    azor77
    Rate: 20
    this link is not working
  • #5 6185293
    bogi
    Help: 103
    Rate: 244
    EUTELSAT 13E TO HOT BIRD 13E
    Good luck
    karola44-81
    Help: 69
    Rate: 242
    I want the simplest description I've ever seen. As for the beginning, it's definitely enough. http://telewizjanakarte.pl/fileadmin/contents/tnk/documents/in Konstrukcja_antena.pdf
    Once you find out what this description is about, the descriptions given by your colleagues will be much easier to make.
  • #7 6188783
    azor77
    Rate: 20
    okay
    I set it up, the problem was that I had the antenna up to a strong signal from the Astra and Hod Birde had a weak signal. I have corrected the signals for the best possible and everything is. But it doesn't catch the Astra 25.5E and Eurobird-Astra 28.5E anymore :cry:
    Thank you for all your help.
  • #9 6189446
    lero1
    Help: 7
    Rate: 8
    Unfortunately, you can't do everything at once.
The discussion revolves around setting up a satellite antenna to receive signals from Hot Bird 13E using a Technisat DigIt S2 tuner and a V-21 LNB. The user initially struggled to catch the desired satellite, receiving signals from Astra satellites instead. Several forum members provided links to resources for antenna alignment and emphasized that Eutelsat 13.0E and Hot Bird 13.0E are closely related, suggesting that proper alignment should allow reception of both. The user later reported success after adjusting the antenna for a stronger signal, although they lost reception from Astra 25.5E and Eurobird-Astra 28.5E in the process. Additional advice included ensuring the antenna is positioned straight and provided various links for further guidance.
