Setting Up Satellite Dish: HotBird & Astra, Ferguson FX-6600 Tuner, Golden Interstar GI-201 LNB
Peef 550457 41
Why does my Ferguson FX-6600 show a decent signal on Hotbird but find no channels, and how can I correctly set up the dish to receive Hotbird and Astra?
Your dish is probably pointed at Astra, not Hotbird, so the tuner can show signal percentages on Hotbird transponders without actually locking and finding channels [#5415851] The fix is to move the dish to the real Hotbird position, or if you want both satellites, use a second offset LNB (monoblock/squint) with a DiSEqC switch; one dish can receive both only with that kind of setup [#5416628] Keep LNB power turned on, use the Universal LNB setting, and don’t over-focus on every transponder reading because some tuners display misleading values [#5417426] [#5415851] For alignment, the simplest advice in the thread was to tune the dish on one known Hotbird channel such as Viva Polska and maximize its quality, then let the receiver do an automatic channel search [#5418382] [#5451875] If you want a more stable reference, set the dish first using a stronger Astra transponder and then fine-adjust toward Hotbird, but the key point remains that the dish must be physically aimed at the satellite you want [#6163099]
  • #1 5415773
    Peef
    Rate: 24
    Hello!
    I am currently setting up a satellite dish. Generally, I want to set up the antenna on Hotbird.
    I have a Ferguson FX-6600 tuner and a Golden Interstar Universal Single LNB GI-201 Platinum X converter.
    When setting up the antenna, of course, I chose the right angles. In the tuner, in the antenna configuration, I chose the Hotbird satellite, converter power supply - on, automatic search for transponders of the given satellite. Converter type - Universal LNB 1. Network search - turned on (searches for a given transponder, as well as other ones belonging to the network).
    Then, I checked the signal strength and quality on weak, medium and strong signal strengths from the transponders, respectively. And so, on the transponder 11881 V (strong) Strength 100%, Quality approx. 80%, similar on the medium (12303V), Strength 100%, quality approx. 70%, on the weak (12597 V) approx. 50%. Then I chose Search Channels and it didn't find any channel.
    Therefore, I chose Astra1 as the satellite and did not change other settings, except for the transponder on 11720H (signal strength and quality very similar to that above for a strong signal). Here I was able to find about 30 FTA channels (only those I gave to choose), and about 15 radio stations. I was quite surprised that when searching for channels, transponders from 1-44 had 0% quality, while those above had good quality, about 70%. On transponders from 1-44, he did not find any channels, while on those above, he searched for normal channels.
    I thought to myself, isn't it because the converter works all the time on the upper band and does not switch to the lower band automatically? In the options I have a 0-22 kHz signal to choose from, but it is set to auto, but it is not possible to change this option.
    What am I doing wrong when searching for these channels? Do I have any parameters from the ones I gave incorrectly set?
    What do you think about the fact that with good signals on Hotbird it finds nothing and on Astra it finds nothing (without changing the antenna position)? Does it mean that Hotbird broadcast most of the channels, eg FTA, on the lower frequency? :) Is it possible to receive the signal from both satellites without changing the position of the antenna? :) Unless it's a completely different satellite, I haven't found any Polish channels, can you check it somehow?
    Thanks for the answer :)
  • #2 5415851
    pajo21
    Help: 259
    Rate: 173
    In short, your antenna is set to Astra and it is natural that the tuner will not find any channel with HB. The fact that it shows some percentages with HB does not mean anything, it just repeats some frequencies on different satellites and sometimes the tuners show nonsense. How do you want to watch channels from HB is move the antenna to this satellite.
    In addition, restore it to its factory settings because you could have changed something unnecessarily.
  • #3 5416628
    huk90
    Help: 58
    Rate: 86
    Answering part of the question, you can watch the channels from two satellites on one plate using the so-called squint, one central converter for a hotbird, the other next to the right looking from behind the plate and a disec switch
    good luck
  • #4 5417107
    Peef
    Rate: 24
    Thanks for the answers!
    I wanted to make sure that the signal quality on the Astra for transponders 1-44 is 0% (strength 30%, i.e. as if there was no signal), and on those above about 80% is caused by some incorrect settings or hardware may not support something?
    Because I understand that in the vicinity of these transponders there is a transition between the lower band and the upper band controlled by a 22kHz signal?
    Are the settings I wrote down correct? LNB power of the converter should be on?
    When setting up the antenna, it is worth checking the signal on other specific transponders (broken down by signal strength)? Do you have any list of recommended transponders on which it is worth tuning the antenna? :)
    Thanks
  • #5 5417426
    huk90
    Help: 58
    Rate: 86
    The lnb power supply must be turned on, I do not know this tuner for sure, but the easiest way is to connect the old analog tuner with, for example, tvn and hotbird set up within a few minutes, set the best reception and the digital receiver should also flash without a problem
  • #6 5418375
    Peef
    Rate: 24
    Thanks for the answer!
    I would rather put everything on a digital tuner. I think I will do as you say, i.e. I will take a Polish channel from Hotbird and tune the antenna to it.
    And do you know a list of transponders, the signal to which is worth tuning the antenna to in order to have the best signal on a large number of transponders of a specific satellite?
    Btw, is there a rule that, for example, Polish channels are on one or two transponders or, for example, 10 Polish FTA channels on Hotbird can be on 10 transponders? :)
    Thanks
  • #7 5418382
    pajo21
    Help: 259
    Rate: 173
    You're up to too much.
    Just turn on Vive Polska and set the best possible signal quality. If this channel works well, the rest will not be a problem.
  • #8 5419520
    artur_kosmala
    I have a similar problem myself and my friend has programmed a tuner and added a list of transponders from the page ... I'm going ... and I was looking for a renewal, there were a few channels
  • #9 5428817
    Peef
    Rate: 24
    I wanted to know how to read channel settings, eg Viva from the list on
    LyngSat .
    For Ferguson, the following setting parameters must be entered:
    Transponder, Video PID, Audio PID, PCR PID.
    The following parameters are given on LyngSat for Viva:
    Transponder: 11075 V, TP128 is also given - what does it mean?
    In the tuner, as I look, an example setting is given, for example: 4194 / V / 4420 (this is the third position should be 128?).
    I still don't know how to set these PIDs. SR-FEC SID-VPID -> 5 164, NID-TID Audio -> 96 Po is given. So for VivaPolska there is Video PID 164, Audio PID 96? And PCR PID 5? How to read this data?
    Should I use a different page for channel setup at all?
    Thanks
  • #10 5428970
    Roman_5000
    Level 19  
    Help: 26
    Rate: 81
    Transporder: 11075
    Polarization: V (vertical)
    Video PID: 164
    Audio PID: 96
    PCR PID: 164
    Here are the specifics (I personally think this site is better) than LyngSat.
    http://pl.kingofsat.net/pack-polsat.php
    The transponder number (e.g. 128) has no effect. Names could be used, but who would remember?
    The easiest way to find "VIVA" is to enter the manual search mode, select the 11075 V transponder and find all the channels that are broadcast on it.
  • #11 5433377
    Peef
    Rate: 24
    However, I can't set the antenna to HotBird all the time. Choosing the transponder to be set as I wrote before: 11881 V I have almost max quality.
    I checked found channels on KingofSat and they are from Sirius4 (4.5E). Then I turned the antenna slightly to the left (looking south).
    I have a SatFinder meter. I set it to show 1 when there is no signal (the tuner has 30% strength, 0% quality). By turning the antenna, the signal disappeared from Sirius (standing behind the antenna I turn left), and then it rose again to a very good (this transponder all the time). So I searched for all Blind Scan channels, setting them to HotBird satellite. However, he found all the channels from Sirius for me again.
    So I uploaded Polsat's list from the tuner (provided by Ferguson). I chose the radio. On Jedynka I have 100% strength and max quality. 30% (the rest of the channels mostly have 0% quality and a strength of 30%). I left it like this because turning the antenna sideways only reduces the signal.
    I made a new BlindScan with this antenna setup - step 4, normal speed. He searched for all the channels from Sirius again, and he did not find a transponder from this Radio One at all.
    What am I doing incorrectly because I don't know anymore? It looks as if both HB and Sirius were in one direction :) Is the setting of the antenna direction according to The sun is reasonably accurate (ie I saw a calculator at what time the satellite coincides with the sun)?
    Could you please provide some strong HB transponders? Or other satellites with Polish programs (probably not on Sirius)? It also seems to me that I can't find Astra either, and these satellites are quite close to each other?
    Btw, I still had something like that, that I had a strength of 100%, like HB, the quality of 10%, so for a few seconds and it dropped completely to 0. I do all tests and scans with the connected meter only suppressed, but it probably does not affect the reception?
    Also, when I give automatic channel search and choose, for example, HotBird or Astra, it still finds these channels from Sirius (regardless of the choice) :)
    Can 2-3 degrees of antenna elevation play a role (I have about 33 and it should be 30)?
    Could it be that, even if I visibly change the direction of the antenna, I have at least half of Sirius channels (about 250 TV and 80 or more radio) for each of them.
  • #12 5451853
    Peef
    Rate: 24
    Currently, I have the antenna set to Astra2 because I cannot set up HotBird all the time :)
    By the way, I loaded the list of programs provided with the tuner (I chose Polsat channels).
    Having an antenna on Astra2 (I have about 500 channels), going to channels from the Polsat list, e.g. Zet radio or a few TV programs, I have 100% signal strength, and 50-70% quality, but I cannot hear anything in the case of radio, and There is no picture and sound at all for TV channels (all FTA channels).
    I don't really understand why this is so? Am I really not getting a signal from these programs? Is the tuner reading something?
    By the way, by setting the signal to a strong HB transponder, e.g. 11881V, I have a very good signal, changing the transponder to a strong one, but with a frequency of 10758V there is no signal. Could it be so, can I have something wrong with the converter and its lower frequency range? By the way, when I do a Blind Scan, I usually find 80-90% of transponders in the upper range and 10% in the lower frequency range on the Astra or Sirius. Is that usually the case? :)
  • #13 5451875
    pajo21
    Help: 259
    Rate: 173
    Tuners all sorts of crap shows, don't worry about it.
    Finally, switch the antenna to Hotbird and perform automatic channel search.
    If you think about each frequency, you will never set up the antenna.
  • #14 6048641
    pyjterfcb
    I am asking LAIK for help :) in the Astra to Hotbird satellite alignment. I have an analog noname tuner and a digit + platter (60cm dish) set by a specialist on the Astre, and I am going to buy a Ferguson FX6600 + TNK.
    After a short reading of the forum, I see it blatantly like this:
    -connect the antenna to the tuner
    -fire tuner
    - set the tuner parameters
    -turn the plate approx. 6 degrees to the right
    -check the signal
    - activate the TNK
    -to watch
    May it be so easy :) I am asking for opinions.
    THANKS
  • #15 6048868
    wiesiek
    Level 19  
    Everything should be fine. After starting the tuner you will have a board with the signal level, set it to max! Good luck !
  • #16 6059102
    pyjterfcb
    It worked without any major problems. So far, everything is fine :)
    Signal Level:
    Level + -90
    Quality + -80
    I think it should be ok
  • #17 6060981
    Arcibal
    Rate: 21
    Hello. Searching for programs on Hot Birda, and it is mainly about NTV, I do not catch low frequencies in the vertical polarization. I live in Germany and I am going to buy a package of Polish programs. Is it just a problem of millimeters in the setting and maybe I have to set DiSEqc accordingly. In the moment I receive all the programs on Astra and Sirius, I will add that I have a flat antenna from the Selfsat company.
  • #18 6065364
    Arcibal
    Rate: 21
    Hello again. As I wrote earlier on Hot Birda, I can not receive all channels. I found that if I change the 0 / 22KHz switch from automatic to 22 KHz, it searches for almost all programs for me, but there is no picture. I would advise or a good tip. Thank you in advance and best regards
  • #19 6163099
    karola44-81
    Help: 69
    Rate: 242
    As an inexperienced self-taught person, my advice is as follows.
    Having a satfinder and a decoder at your disposal is extremely simple.
    My proven way is:
    He manually punches the transponder and all the data of any Astra program and saves it on the first channel, then I do the same with any HotBird FTA. I am set on the 2nd channel. Now I set up the antenna. Sure you will ask why astre, when it comes to HB ?? And because the astra has a stronger and easier signal to catch. I set it on the astra channel and initially set the antenna. I am looking gently until I have a signal from asters. Regulates the elevation angle to obtain the best power and quality. In this way, I have a strong point of reference.
    Then I go to the FTA program with HB. And now I gently, even very gently, turn the antenna to the right. Not a whip so as not to catch even a weak signal from HB. As there is already a poor signal, but with HB it is regulated by the right-left and the elevation angle. In this way, it will give a signal that is satisfactory for the program to turn on. Then, a slight correction of the converter's position. I already set up a few antennas and it was always done within 1 hour. The method works for me. Recently, he has been practicing the first zone setup on an analog tuner. It's so convenient that even if you move the antenna too sharply, the image will appear for a fraction of a second. Then you know what you are up to. Then you just need to connect the digital decoder and set the signal. Not valid on which transponder. If you choose 100% of the quality on the strongest, it should not fall below 60% on the weakest.
  • #20 6172893
    dzac4
    Level 36  
    Help: 236
    Rate: 229
    PEEF when you catch Sirius, while standing behind the antenna, turn it to the left, just remember that you have to move it vertically up slightly, the meter will show you the signal as to the combination in the decoder menu, do not mix there, everything is set for asters, put on a monoblock just say what your name is .
    ARCIBAL in my eye you have a damaged 99% converter
  • #21 6344183
    sitetzky
    Rate: 14
    I am asking you with a problem, maybe someone could help.
    I got an N-Ke, connected it and everything is fine, almost.
    the point is that it only receives programs from the hotbird, and I would like to have access to those that are on the astra.
    I am using an antenna that was previously used for the plus digit.
    As I mentioned from HB, it receives elegant, quality details cannot be found - I turned the antenna left and right and nothing. do something need to be set on the coventer? if so how?
    below is a photo of the convent settings
    Thanks in advance for your help.
    greeting, p
  • #22 6344271
    Doominus
    Help: 163
    Rate: 390
    When it was well positioned, there was no need to fumble with the antenna.
    Check disqc settings.
  • #23 6344304
    sitetzky
    Rate: 14
    diseqc set ok
    hotbird lnb1 - strength 89%, quality 92%
    astra lnb2 - strength 89%, quality 0%
    does it make any sense to turn with a konwentem?
  • #24 6344742
    ansat
    Help: 44
    Rate: 68
    Which converter is ASTRA and which is HB because it is very important. You have two handles white and black.
  • #25 6346460
    sitetzky
    Rate: 14
    white is HB, black attached
  • #26 6346740
    KIEROWCA_VW
    Help: 273
    Rate: 676
    This converter is operational?
    If it is a digital antenna (it is small), this converter may not see the Astra, it does not "catch" the beams, because its diameter is quite large.
  • #27 6459954
    diller7
    I have a similar problem, I was switching from Digits (I watched C with HB and A) to NTV and to enjoy the signal from HB and A, I had to make a maneuver by turning the converter (I have a Twin Monoblock) by 180 about its axis - i.e. in the main holder of the converter mounting . All in all, I never had a problem with aligning the antenna, I always had a strong signal on both satellites. After this treatment, I see HB and A on NTV. Today I just took out the old C + decoder, because I want to install it on the plot and the problem has returned - surely to check the tuner I will have to fight the converter again - I will add that all the time I pay for C, so the card should be active. Cyfra works on fergusonie fx 6600 and the max signal is now 30%. I messed up the antenna settings a bit in the menu but it is not in a rare configuration.
  • #28 6460026
    dzac4
    Level 36  
    Help: 236
    Rate: 229
    Diller write clearer because NTV or C HB and A say nothing and no one will answer guesses.
    What do you see, I don't know.
  • #29 7166583
    Zbyszek_59
    Rate: 19
    I had the antenna tuned to HB. I bought a monoblock twin converter and I receive HB and Sirius without turning the antenna. What to do to receive HB and Astra?
    Thank you in advance and ask for advice.
  • #30 7166594
    pajo21
    Help: 259
    Rate: 173
    What size of the antenna?
The discussion revolves around setting up a satellite dish to receive signals from Hotbird and Astra satellites using a Ferguson FX-6600 tuner and a Golden Interstar GI-201 LNB. Users share troubleshooting tips for achieving optimal signal quality and strength, emphasizing the importance of correctly aligning the antenna and configuring the tuner settings. Key advice includes ensuring the LNB power supply is on, using specific transponders for signal testing, and the potential need for a DiSEqC switch to manage multiple satellite signals. Users also discuss the challenges of receiving channels from both satellites and the necessity of fine-tuning the antenna position for better reception.
TL;DR: 100 % signal but 0 channels usually means you’re aimed at the wrong bird; "Just turn on Vive Polska and set the best possible signal quality" [Elektroda, pajo21, post #5418382] Use the 11881 V transponder (80 % quality seen) [Elektroda, Peef, post #5415773] to centre on Hotbird, then fine-tune. Why it matters: Correct alignment and LNB switching save hours of trial-and-error for dual-satellite viewers.
• Hotbird 13°E in Poland: azimuth 182-190°, elevation 30-35° [SatLex Calc]. • Astra 19.2°E sits 6.2° east of Hotbird; monoblock spacing 6° suits 80-90 cm dishes [Inverto DS]. • Universal LNB low/high LO: 9.75/10.60 GHz; 22 kHz tone triggers high band [CENELEC EN 50494]. • Stable DVB-S picture on FX-6600 needs ≥55 % quality reading [Ferguson Manual]. • Typical dual-sat install (dish, monoblock, labour) costs €60-€120 [TeleSat Market 2023].
How do I point my dish from Astra to Hotbird without a meter?
  1. Tune the FX-6600 to Vive Polska on 11881 V.
  2. Stand behind the dish and slowly turn it 6 degrees left (east-to-west).
  3. Raise elevation about 1 ° while watching quality; lock when it peaks above 60 %. [Elektroda, huk90, post #5416628]
Why does my tuner show 100 % signal but finds zero Hotbird channels?
The dish is reading a transponder that repeats on Sirius or Astra; quality isn’t real. Move the dish to Hotbird and rescan. "Percentages with HB do not mean anything" [Elektroda, pajo21, post #5415851]
Do I need LNB power ON in the menu?
Yes. Disabling it stops the 13/18 V and 22 kHz commands, leaving the LNB in one band and polarity [Elektroda, huk90, post #5417426]
What is the correct 22 kHz setting for a Universal LNB?
Leave it on Auto. The receiver sends 22 kHz for 10.7-11.7 GHz high-band transponders; manual 22 kHz locks you out of low band channels [Elektroda, Arcibal, post #6065364]
Can one dish receive Hotbird and Astra together?
Yes. Use a 6° monoblock: left horn on Hotbird, right on Astra when viewed from behind [Elektroda, matzg, post #7166644] Signal loss is ≈1 dB compared with a single-LNB [Inverto DS].
Why do low-band vertical channels disappear on my flat Selfsat?
Some flat antennas have reduced gain below 11 GHz. NTV low-band V failed until 22 kHz was forced, yet picture stayed black [Elektroda, Arcibal, post #6065364] Use a conventional 60-80 cm offset dish for full Hotbird range.
How do I manually enter Viva Polska PIDs on the FX-6600?
Enter transponder 11075 V, then Video PID 164, Audio PID 96, PCR PID 164 [Elektroda, Roman_5000, post #5428970] The TP number (128) is only the broadcaster’s label.
What dish size gives reliable dual-sat reception in Central Europe?
A 75-90 cm reflector keeps quality above 70 % in rain. Users with 60 cm reported Astra loss on the secondary LNB [Elektroda, KIEROWCA_VW, post #6346740]
Edge case: I have 80 % quality but no audio or video on Polsat FTA—why?
The tuner may lock on Astra 2’s carrier while your channel list expects Hotbird PIDs. Re-scan Hotbird, or delete the list and load factory settings [Elektroda, Peef, post #5451853]
Which Hotbird transponders are strongest for initial alignment?
Try 10992 V, 11034 V, 11881 V, and 12149 H. Users reported 80-90 % quality on 11881 V even with slight mis-pointing [Elektroda, Peef, post #5415773]
Quick 3-step guide: locking two satellites with a monoblock
  1. Centre dish on Hotbird until quality ≥ 70 %.
  2. Tighten bolts, then check Astra LNB head; tweak dish right or left 1-2 mm.
  3. Store DiSEqC: LNB1 = Hotbird, LNB2 = Astra. Rescan both.
My tuner finds 250 Sirius channels whatever satellite I choose—fix?
Clear channel list, restore factory settings, then blind-scan after physically moving the dish off Sirius by several degrees [Elektroda, Peef, post #5433377]
What DiSEqC settings should I use for TNK on a monoblock?
Set DiSEqC 1.0: Port 1 → Hotbird, Port 2 → Astra. TNK uses Hotbird only; Astra search is optional [Elektroda, dzac4, post #7564561]
