P11 2.0 Petrol Primer: How Much Air Conditioning Oil After Compressor Removal & Leakage?
primera 91159 9
How much air-conditioning oil should be refilled after removing the compressor and losing some oil?
You should not assume the vacuuming process removes all the compressor oil; it only carries away part of it, so the refill should be based on the oil that actually leaked out plus any oil lost from replaced components [#6205694] If possible, the most correct method is to drain and measure the compressor oil, but in practice people add the lost amount back and usually top up a small blind amount of about 10–15 g [#6205694] The car should also have a sticker under the hood with the factory refrigerant and oil data; one reply gives 600 ± 50 g of refrigerant and 200 ml of oil [#6197718] [#6198370] If the system was opened during a major event/accident, the advice was to add much more new oil, about 60–80 g, because shortage is more dangerous than a slight excess [#6205694]
  • #1 6196701
    primera
    Help: 6
    Rate: 55
    The last wife rang the bell and the air conditioning cooler went off. On the occasion of sheet metal repairs, the air-conditioning compressor was also removed and it was lying on the shelf. The compressor holes were clogged but some oil had leaked out. After putting everything together, I went on the load and they wanted to pour me only 10 grams of oil (apparently it is done as standard) but as I told them that some oil spilled from the compressor, they poured me 20 grams. In the book, he writes that 200 ml of oil enters the compressor and now I do not know if there is the right amount of oil in the compressor, I would not like to rub it off. How is it with this oil? The car is a P11 2.0 petrol primer.
    Thank you in advance for your response.
  • #2 6197718
    Dudi2007
    Help: 10
    Rate: 76
    Oil, like R134 for the air conditioning, you fill, depending on the car, as provided for in the procedure, these data should be in the plant, such data should be under the hood on the sticker, if you do not find them, enter what car it is about
  • #3 6198370
    primera
    Help: 6
    Rate: 55
    The refrigerant should be 600 ? 50 grams and the oil in the compressor 200 ml, this is what it says on the sticker on the car. When vacuuming in the system, is all the oil from the compressor drawn out, because the mechanic said that only part of it?
  • #4 6198713
    Dudi2007
    Help: 10
    Rate: 76
    and when you suck up the oil from the engine you pull it only a little or the whole? after all, it is normal that the manufacturer provided these values so that the servicing engineer would know how much.
  • #5 6199339
    radek-n
    it often happens that the air conditioning system is pouring oil over the eye. in every car with air conditioning there is a sticker with the amount of refrigerant and oil (unless it fell off)
  • #6 6199364
    primera
    Help: 6
    Rate: 55
    The drain is for the oil and the oil is taken out, and in the climate, the coolant is removed and I do not know if all the oil from the compressor is also removed when the refrigerant is sucked, the mechanic claimed that only part of the oil is taken out, so I ask how it is.
  • #7 6199743
    Marcin_ca1
    Help: 14
    Rate: 278
    I have an air-conditioning machine, I have been working on it for over a year, I use air-conditioning.
    Even immediately after filling the air conditioning with gas and oil, it will pull it out again and so, not a half of the oil can be recovered.
    The machine didn't even get 10ml of oil :)
  • #8 6203013
    primera
    Help: 6
    Rate: 55
    Well, how is it actually with this oil, because I see contradictory answers.
    kybernetes
    Help: 426
    Rate: 1488
    The simplest and most appropriate way to do this would be to measure the amount of oil you have in your compressor. For this purpose, unfortunately, it would be necessary to remove the refrigerant from the system, dismantle the compressor, pour out the oil, measure, etc. (you had the compressor removed from the vehicle and it was time for such checks). However, in practice it is rarely done and as long as it is certain that a catastrophe did not occur and that a large amount of oil was not poured out of the system, the amount of added oil is calculated as a guide.
    1) You say that the oil spilled "a little" - so I assume that you know more or less how much and this amount needed to be refilled while filling the air conditioning.
    2) Additionally, when replacing components, the oil that has been removed from it in the parts (e.g. condenser 20g, drier 15g, evaporator 20g, one conduit 5g, etc.) must be introduced into the system.
    3) When extracting the refrigerant, some of the oil is entrained with the refrigerant. A small part, certainly not all of it, or even most of it. The spreads are large here, from practice I observe from 5 to 35 g - so you should write down how much oil you have pulled off and add the same amount when filling. It has been assumed that 10-15g is always added "blindly"
    4) if there was an emergency leakage of the air conditioning during an accident - when filling, add 60-80g of new oil.
    5) Some excess oil is not harmful, it will slightly reduce the cooling performance but will not cause a failure. The shortage, on the other hand, is threatening - so it's better to transfer a bit if not to add
    To sum up - 20g for the oil poured out, 20g for the replaced condenser, 10g for any losses - together you should load 50g of new oil.
    If the air conditioning was unsealed during the breakdown, add 80g + 20g poured from the compressor on the pole = 100g of new oil.
    Regards
  • #10 6206163
    primera
    Help: 6
    Rate: 55
    Oh, and that is a specific answer. The air conditioning was not turned on at the time of the accident. Does it change the amount of oil refill required? Your answer shows that I have 80 grams of oil too little?
    Regards
The discussion revolves around the correct amount of air conditioning oil to add after the removal of the compressor in a P11 2.0 petrol primer. The user experienced oil leakage from the compressor during repairs and was unsure if the 20 grams of oil added was sufficient, given that the manual specifies 200 ml of oil for the compressor. Responses highlight that the amount of oil removed during refrigerant extraction can vary, and it is common for not all oil to be recovered. The best practice suggested is to measure the oil directly from the compressor after disassembly, although this is rarely done in practice. The user also inquires if the compressor being off during the incident affects the oil refill requirements.
