Zexel DCW 17D Compressor Oil: A4 B5 Bearing Replacement, ZXL 100 PG 250cc - Quantity & Type
Robert695 7152 11
What oil should I put into the compressor chamber of a Zexel DCW 17D after bearing replacement, and how much should I add?
Use the same air-conditioning compressor oil: PAG100 (polyalkylene glycol), and the compressor sticker “ZXL 100 PG 250cc” points to that oil [#16219506] [#16225130] The green color is from a UV leak-detection dye, so it does not mean a different oil type; new oil is normally clear [#16220222] The oil quantity must be exact, because too much or too little can damage the compressor [#16220222] [#16235273] One reply notes that 250 ml is the amount for the whole system, not just the pump/compressor itself [#16225130] [#16225238]
  • #1 16217508
    Robert695
    I had a bearing replaced on my A4 B5 in the Air Conditioning Compressor.
    there was little oil in it.
    I would like to pour new oil to the chamber where the piston drive is.
    the screw on top is the filler.
    Not to be confused with air conditioning oil.
    Question: what oil should I pour in there and how much ??
    in the photo, on the green sticker:
    Oli ZXL 100 PG 250cc
    is this the oil I mean ??
    • Zexel DCW 17D Compressor Oil: A4 B5 Bearing Replacement, ZXL 100 PG 250cc - Quantity & Type IMG_20170121_200156.jpg (665.44 KB) You must be logged in to download this attachment.
  • #3 16219506
    123nowy
    Help: 55
    Rate: 101
    This oil circulates throughout the air conditioning system, it is the same oil.
  • #4 16220156
    Robert695
    I have green oil in the air conditioning system.
    Can I pour yellow into the compressor too?
  • #5 16220222
    123nowy
    Help: 55
    Rate: 101
    Green is because a UV dye has been added for leak detection new is transparent, you should know that the amount of oil is strictly defined excess is very harmful
  • #6 16221608
    Robert695
    how much and how should i pour the oil into this compressor?
    No system flushing.
  • #7 16225069
    123nowy
    Help: 55
    Rate: 101
    did you just have a broken bearing or something else
  • #8 16225130
    milejow
    Help: 1563
    Rate: 5149
    It's the same oil. On the plate / sticker on the compressor you have information on what oil it works on.
    PAG100 olive oil, comes in 250ml.
    Działalność własna
    Mętów 99, Lublin, 20-388
    123nowy
    Help: 55
    Rate: 101
    but I have 250 ml in the entire system and not in the pump itself, I sent a note
  • #10 16227090
    Robert695
    Bearing on the pulley.
    and a broken arc washer in the center
  • #11 16235273
    gajdek419
    Help: 24
    Rate: 90
    Remember that the amount of oil in the system is neither too much nor too little.
    In both cases, it may damage the compressor
  • #12 16274702
    Robert695
    thank you all for the information.
    I've already found out everything :)
The discussion revolves around the appropriate oil to use for the Zexel DCW 17D compressor in an Audi A4 B5 after a bearing replacement. The user inquires about the correct type and quantity of oil to add, specifically referencing "Oli ZXL 100 PG 250cc" from a green sticker on the compressor. Responses clarify that the oil used in the air conditioning system is the same as that required for the compressor, specifically PAG100 oil, which comes in 250ml. Participants emphasize the importance of maintaining the correct oil level, as both excess and insufficient oil can damage the compressor. The user confirms they have gathered the necessary information.
