What Type of Plug Is Used on Creative Inspire A200 Control Cable and Can It Be Replaced?
jan0404 24082 16
What type of plug does the Creative Inspire A200 control cable use, and can it be replaced or remade?
It uses a 9-pin mini-DIN-style connector, referred to in the thread as MD-90 / MD-90SM or MDC-009, and yes, it can be replaced or remade [#9953867][#9989007] One user reported buying a new plug, matching the wires with a meter, and getting the speakers working again, and another said a replacement plug cost about 6 PLN [#9954772][#9755637] If you cannot find the connector, another workable fix is to solder the cable permanently to the PCB inside the subwoofer [#7392460][#10888054] A pinout for Creative T3100 was also linked as a reference for wiring the replacement connector [#9989007]
  • #1 6615270
    jan0404
    Rate: 10
    Hello, I am the owner of creative inspire a200 computer speakers, I have a problem with the plug on the control cable not only that it is loose in the socket, but one of the rods in the plug is broken, someone knows what the type of plug is, is it possible to buy such a cable or how to remake it .Greetings .
  • #2 7392253
    robotwls
    I join the question. In my case, the cable is broken somewhere or something with a plug, because the speakers do not want to play, only when I move it.
  • #3 7392460
    jan0404
    Rate: 10
    I desoldered the socket in the subwoofer and soldered the cable permanently, and everything works fine.
  • #4 7406474
  • #5 7406734
    jan0404
    Rate: 10
    I did not have a schematic, but I had a plug, so I cut the cable at the plug, put the plug with a piece of cable into the socket with a meter, measured the transitions from the cables to the PCB and then soldered the cable to the PCB using the colors.
  • #6 7409330
  • #7 9755637
    dips
    Rate: 8
    You may need a color description cable / plug from the satellite to the sub.
    I fought for some time myself, until I managed to borrow a different pair and now they are playing (the plug costs PLN 6)
  • #8 9953867
    Sasni
    Help: 23
    Rate: 57
    Were different cable colors used on the same speaker model (A200)? Strange. If not, it looks like your schedule is different, strange, incorrect?
    Unfortunately, I don't see a yellow wire or an orange wire.
    It's time to clearly indicate the answer where to connect these cables in the A200 set.
    Also:
    The subwoofer jack is named: MD-90SM ( see specification )
    The plug for this socket is called: MD-90 ( see specification )
    Colors on the plug:
    Colors of the cables on the PCB:
    REMARKS:
    No. 9 - white cable
    No. 4 - Empty - Not used
    No. 5 and 1 can be short-circuited or connected only to 5, and 1 should be left unused
    No. 2 and 3 can be short-circuited
  • #9 9954772
    dips
    Rate: 8
    On the basis of one pair of A200 that I unscrewed and tested with a meter, I repaired another pair of hence a drawing that may be useful to someone.
    I don't know if Creative has released a different color scheme in an earlier or later release ....
    My two pairs were identical and I was able to easily replace the second pair with a new plug bought on the Allegro, everything sounded as it should.
  • #10 9988747
    kev21
    Rate: 27
    I can't find such a MD-90 plug anywhere, do you have any information about the store / auctions ??
  • #11 9989007
    jan0404
    Rate: 10
    Hello, I found something like this link below and the plug is called MDC-009.
    http://www.tme.eu/pl/katalog/index.phtml#clea...eters%3D1%26search%3DMDC-009+%26bf_szukaj%3D+
    http://sklepelektroniczny.com/product-pol-2961-MDC-009-Wtyk-mini-DIN-9pin.html
    And below is a description of the pins for the CREAIVE T3100. Greetings.
    http://pinouts.ru/Home/creative_t3100_speakers_pinout.shtml
  • #12 10017194
    kev21
    Rate: 27
    Thanks
    In my set, the t3100 turned out to be a plug, only I had different colors, I called the meter and I have something like that
    view of the plug from the "plugging" side into the socket, not from the soldering side ;-)
    "copper" cable ground, solder to the border of the plug
    It's hard to see the old tip yourself because it is flooded with glue from the gun,
    It works, maybe it will be useful to someone
  • #13 10887845
    Arctic66
    Sasni wrote:
    The plug for this socket is called MD-90
    jan0404 wrote:
    Hello, I found something like this link below and the plug is called MDC-009. (...) http://sklepelektroniczny.com/product-pol-2961-MDC-009-Wtyk-mini-DIN-9pin.html
    Hello and I apologize in advance for playing archaeologist, but I have a problem with my Creative a200 speakers, i.e. the plug broke.
    Sasni wrote that the name of this plugin is md-90, jan0404 and that it is mdc-009, mini. Don't hit me, I'm a complete layman, but the mdc 009 plug from the given link will not fit the a200? Will there be?
    Today I was in an RTV and household appliances repair shop, the Lord with a stupid smile asked for PLN 50 for the repair, stating additionally that I would not find such a plug anywhere. My penis may not be dangling between my legs, but I can tell when someone is trying to roll me out.
    Please tell me how it is with these plugs.
  • #14 10888054
    jan0404
    Rate: 10
    Hello, I propose to do the same as I just solder the cable permanently to the board, some familiar electrician or DIY enthusiast will do it for the proverbial beer. As for men in (household appliances repairs), they have EU rates. Regards.
  • #15 10888236
    Arctic66
    I managed to straighten the wires by hand so that they fit into the socket. Which does not change the fact that it would be appropriate to dig in the plug (some cable is probably not touching, one speaker does not work), I do not know what it looks like inside, so far I am not doing it. For now, it is enough for at least one subwoofer and one speaker to work. Unfortunately, I was so stupid that I cut the plug with a piece of cable, unaware that I would not get something like this in the store.
    And now I'm sitting and sticking the cables together, and every single one is smaller ...
    Unfortunately, I don't know any DIY enthusiasts, or anyone who could help me, so I just have to figure it out.
    Thanks for the quick reply, best regards.
  • #16 10893840
    Sasni
    Help: 23
    Rate: 57
    The three-dimensional model of the MD-90 plug can be found under the following. lookup. Link
    Arctic66 - if your colors are the same as in my list, you have to somehow try to fix the cables permanently to the board.
  • #17 11727696
✨ The discussion revolves around issues with the Creative Inspire A200 speakers, specifically related to a faulty plug on the control cable. Users report problems such as loose connections and broken pins. Solutions include desoldering the existing socket and soldering the cable directly to the PCB, with some users sharing their experiences and methods for identifying the correct wiring. The MD-90 plug is identified as a common connector for these speakers, with alternative suggestions for sourcing or replacing the plug, such as the MDC-009. Users also share color coding for the wires and provide links to diagrams for reference.
