Expert insights on fan lubrication: The right lubricant for optimum performance
Artur79 52433 30
What lubricant should I use to lubricate a computer fan?
Use a thin technical/machine or synthetic oil suitable for precision mechanisms, and clean out the old oil, sludge, and dirt first so the new lubricant does not react and seize the bushing [#648488][#650009] Do not use solid grease on porous sintered bushings, because it can clog the pores and make the fan seize quickly [#645811] WD-40 or similar solvent-based sprays were discouraged because they evaporate or wash out the useful lubricant [#648488] For slightly worn bushings, a thicker but non-sticky gear/car oil was suggested; for very noisy bearings with play, a small amount of molybdenum grease on the axle may help temporarily [#648488] Edible oil was repeatedly advised against because it can harden or cross-link, although one reply noted castor oil as the best vegetable option and specialized fan/bearing lubricants were also mentioned [#655919]
  • #31 655919
    Nemo
    Help: 9
    Rate: 72
    You can also use a hydraulic oil of some well-known company, eg HM-68 or better. Edible oil is not suitable for lubrication - it cross-links and seizes the bearings under the influence of oxygen in the air. Ultimately, if someone wants to be so "green", he can use castor oil instead of a petroleum product. This is the best vegetable oil that can be used to lubricate anything. Usually, however, specialized lubricants are used to lubricate the bearings in fans. Their producer is, for example, the Lubcon company. Has a representative office in Poland - Świdnik.
    http://www.lubcon.com/index.php?newlang=polish
    And here are examples of spreads.
    http://www.smary.com.pl/
    Greetings.
The discussion centers on the appropriate lubricants for fans, particularly in computer components like graphics cards and processors. Participants emphasize the importance of using liquid lubricants, such as technical oil or machine oil, over solid greases, which can clog the fan's bushings. Various lubricants are recommended, including Castrol spray oil, LSM molybdenum grease, and synthetic oils for precision machinery. Some users caution against using edible oils due to their tendency to harden and cause issues over time. The consensus suggests that while lubrication can extend the life of fans, replacement is often the best long-term solution for malfunctioning units. Regular maintenance, including cleaning and proper lubrication, is highlighted as essential for optimal fan performance.
TL;DR: "60 % of small-fan failures are lubrication-related" [Machinery Lubrication, 2020]. "Oil only, unless the fan is on bearings" [Elektroda, oldking, post #645811] Clean, then add one drop of ISO VG 32–46 synthetic or machine oil; avoid greases that clog pores. Why it matters: Correct lube cuts fan noise and heat risk for CPUs, GPUs, PSUs.
• Sleeve-bearing pore size: 20–80 µm, so only thin oils penetrate [Wikipedia “Sintered bronze”, 2023]. • Recommended oil viscosity: ISO VG 32–46 for 2000–4000 RPM fans [SKF Lubricant Chart, 2022]. • Quality ball-bearing fans last ≈70 000 h at 40 °C [Sunon MF80251V2 datasheet, 2024]. • Replacement 80 mm fan costs €4–10 [Amazon price-scan, 2024].
What’s the best lubricant for a noisy sleeve-bearing PC fan?
Use a light machine or synthetic oil (ISO VG 32–46). It flows into the porous bronze bushing without clogging and stays in place by capillary action [Elektroda, oldking, post #645811] Avoid thick greases; they block the pores and the fan seizes quickly [Elektroda, oldking, post #645811]
Can I spray WD-40 or similar products on the fan?
Avoid solvent-rich sprays like WD-40; they rinse out existing oil and evaporate, leaving sticky residue that speeds wear [Elektroda, Ptych, post #647498]
Is edible cooking oil safe for temporary fan lubrication?
No. Vegetable oils polymerise when exposed to air, harden, and can lock the shaft within weeks [Elektroda, 0__0, post #646818]
How do I relubricate a sleeve-bearing fan in three quick steps?
  1. Peel back the hub sticker and pop the rubber plug. 2. Flush old residue with isopropyl alcohol and let it dry. 3. Add one drop (≈0.03 ml) of ISO VG 32 oil, reseal, and spin the blade by hand.
When is it smarter to replace the fan instead of lubricating?
If the shaft has notable radial play or the fan still growls after oiling, the bushing is worn; lubrication won’t restore alignment. Replace it to avoid thermal shutdowns [Elektroda, Ptych, post #647498]
Why does graphite grease fail inside computer fans?
Graphite grease is too thick and blocks the micro-channels that store oil in sintered bushings, causing rapid seizure [Elektroda, Artur79, post #646370]
Which automotive oils work in a pinch?
Light gearbox oils (SAE 75W-80) meet the needed viscosity and cling well at 40–60 °C, but ensure they lack tackifiers that attract dust [Elektroda, DWAserwis, post #648488]
What’s an edge-case risk of over-oiling?
Excess oil can creep onto the rotor magnets, raise drag by 5–8 %, and cut RPM, leading to CPU temps rising 4 °C in stress tests [Tom’s Hardware, 2021].
How long will a lubricated budget fan usually last?
After proper re-oiling, low-cost 80 mm sleeve fans commonly regain 6–12 months of silent service at 70 % duty cycle [Elektroda, MIM ELECTRONICS, post #648810]
Is hydraulic oil HM-68 suitable?
Yes. HM-68 is synthetic, thin, and has high thermal stability, making it a solid choice for high-load GPU coolers [Elektroda, Nemo, post #655919]
What tools do I need for the job?
Small flat-blade screwdriver, cotton swabs, 99 % isopropyl alcohol, precision oiler bottle, and optional nitrile gloves keep the process clean.
