Connecting an Outlet to a Lamp for Switch-Controlled Power Supply
bobo21 26296 12
Can I wire a mains outlet in parallel with a lamp so the outlet is powered only when the lamp switch is on?
Yes, you can connect a socket in parallel with the lamp so it gets power only when the lamp switch is turned on, and there are even ready-made E27-thread sockets for this purpose [#6688750][#6688769] However, you must check that the lamp wiring cross-section and the switch current rating are sufficient, because typical lamp wiring is often too thin for adding a socket [#6688769] Do not overload the switch; otherwise you can damage it or even create a fire risk [#6688750][#6688910] If you use it at all, keep the load small, such as a radio or laptop [#6688910] For a proper solution, make a separate socket circuit behind a main switch or add another switch [#6688910]
  • #1 6688666
    bobo21
    Help: 19
    Rate: 30
    I have this question for experienced electricians. Is it possible to connect an electrical outlet parallel to the bulb in the lamp. Then the voltage in the socket will appear only when I turn on this lamp. Theoretically this could be the case but I don't know if this is done in practice. I don't have access to the box and the closest to my workstation (that's where I want to bring power to) is this lamp.
    Please respond.
    Thank you and best regards.
  • #2 6688689
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    You can. Just do it with your head.
  • #3 6688692
    luiskon2009
    This is how the current will appear in the socket when the lamp is turned on.
  • #4 6688732
    bobo21
    Help: 19
    Rate: 30
    Thanks for the quick answers.And how do the standards apply to such a connection?
    Good luck.
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    What standards. There are even to buy ready-made sockets with E27 thread for just such purposes. Just remember not to overdo it and plug in everything you can, or your lamp will catch fire without a bulb:idea: :D .
  • #6 6688765
    bobo21
    Help: 19
    Rate: 30
    Thank you very much for your answer and clearing my doubts.
    Greetings.
    GBW
    Help: 123
    Rate: 293
    I am not aware of any standard that prohibits having a socket at the lamp, while you should be aware of the cross-section of the wire and the current of the switch. In typical lamps, it is too thin to fit a socket.
  • #9 6688773
    Darrieus
    Help: 406
    Rate: 289
    It's just that standard switches can withstand a few amps, how you connect there a welder or unknown what...
    Maybe a contactor ? But that's already overkill.
    You can't , because you'll burn the switch at the first opportunity.
  • #10 6688883
    bobo21
    Help: 19
    Rate: 30
    And if the load that I connect to the socket is not large, I think the switch should not happen to anything?
  • #11 6688908
    ajpier
    Level 37  
    Help: 363
    Rate: 480
    What should be connected there.
    Darrieus
    Help: 406
    Rate: 289
    bobo21 wrote:
    And if the load I connect to the outlet will not be large, I think the switch should not happen anything?
    This is enough for a radio and a laptop...
    You can always insert another switch....
    On what you have now is: "a drill from the poor and it is only 400-500Watts..."
    Make a cube, two circuits , "light"
    a circuit of sockets separate behind the main switch.
  • #13 6691554
    bobo21
    Help: 19
    Rate: 30
    Thanks to everyone for their help. I probably would have wired in the bulb myself and then wondered why the switch doesn't work. But a man learns from his mistakes. :D
    Greetings to all forumers and thanks again.
The discussion revolves around the feasibility of connecting an electrical outlet in parallel with a lamp to enable switch-controlled power supply. Participants confirm that it is possible, noting that the outlet will receive voltage when the lamp is turned on. However, they caution about adhering to electrical standards and the limitations of typical lamp wiring, which may not support high loads. Some suggest using ready-made sockets designed for this purpose, while others highlight the importance of considering wire gauge and switch ratings to prevent overheating or damage. The conversation concludes with the author expressing gratitude for the insights shared.
