Smart switch - will it work in an old L+N 'short' installation?
Shlizer 468 1
  • Smart switch wiring question for always-live lamp feed
    #1 21652192
    Shlizer
    I have the typical old conductor wires (L, N) in the room in a box to control the main light. I want to install a wall lamp and 'make' a second switch.
    My idea is:
    - put a smart switch in the box (say something such ).
    - at the main lamp, a switch (extra-socket type this ).
    - in a wall lamp, as above.
    - light switch only on the L and N lines (without lighting control - I will control the scenes and the above switches with this).
    Does such an arrangement have the right to work? I.e. will this type of switch normally continue to give voltage to the main lamp?
  • #2 21652208
    hindoos
    Level 36  
    Help: 292
    Rate: 667
    Perhaps you would like to draw this out on a diagram? :) surely it will be clearer to understand it better
